I have a laptop that will not boot up and all 3 lcd indicators are lit
Will it boot from cd with the recovery disk? more than likely it is a virus or a hardware issue.
Posted on Sep 08, 2009
What would be the probable cause of a sony vaio fs830/w of starting up & the 3 green leds on top stayed lit
You were FORMATTING it? Meaning... you were erasing the operating system? If that's the case, then... you have no operating system and the computer cannot boot up because it has no operating system to boot into.
Jul 30, 2014 | Sony VAIO VGN-FS830/W Notebook
Plug into outlut but screen and power buttons dont light and dvd player doesnt work
Do you get any indication that the laptop is trying to boot - do you have a Power LED that is lit, any other LED indicators that flash at all?Have you tried to connect the laptop to an external monitor and if so, do you get any error or progress messages shown on that display?If the laptop will not power on at all, then try removing the battery then plug back in the power supply and see if it will boot with the battery pack removed.
Dec 26, 2011 | Dell Inspiron 15 Laptop
I have a Dell D600. It starts up to boot page and after 3-5 seconds the picture disappears but the laptop is still running. The indicator light near the power button with a 9 on it stays lit.
I have a similar problem currently. Boot and try pressing Fn+Up arrow repeatedly to raise brightness. Then flick the little button right above your volume control that tells the laptop youve closed it. If you see the screen flicker on/off then its the button. Otherwise reboot and try shining a light at the screen from different angles and see if you can see dark images. If you can see windows boot up but dark, then it is almost certainly your LCDs backlight. If you can't see dark images, next try using the VGA output plug at the back of your laptop to connect to a different monitor. Within less than 1 minute you should see the image on the external screen. If not, try pressing Fn+F8 a few times to toggle the output. If still no picture on the external screen your video card might be fried. If you do get a picture on the external with or without seeing dark images on the laptop, then it is a problem with either the LCD screen, it's inverter, or the screens flex cable. Check Dell support for your systems original parts list HERE. You will need your laptops Service Tag number, which is on a sticker on the bottom of your laptop.
Hope this helps, Good luck.
Mar 06, 2010 | Samsung Dell Latitude D600 14.1 LCD SXGA+...
Motorola S805 headset worked fine with T60 laptop
Solution I found with the same devices is to properly par the devices.
Refer http://direct.motorola.com/ens/s805/QuickstartGuide.pdf
It basically states :
1.Ensure the headphones are turned off (L indicator light not blinking).
2.Press and hold L button. After about 6 seconds, the L indicator light becomes steadily lit.
3.Release the L button. The L indicator light remains steadily lit.
If the L indicator light is flashing or not steadily lit, repeat steps 1 through 3
Now on the T60:
Search for Bluetooth Devices as you would normally.
The T60 lists Bluetooth devices it finds.
Select Motorola S805.
Select OK or Yes to pair your headphones
with your phone.
Enter the passkey: 0000
Select OK.
When your headphones successfully pair
with your phone, the L indicator light
changes from steadily lit to rapidly flashing.
That's it next time you start a audio program on T60 output will be sent to Motorola Headphones
Nov 13, 2009 | Motorola Mobility S805 Wireless Headset
When i switch on my laptop it does not display anything on the screen but it is on? why
does it sound like it boots up? if yes problem with the LCD screen. does the LCD lit up? if no problem with the inverter or lamp.
Jul 07, 2009 | Acer TravelMate 240 Notebook
Notebook will not boot up
First take out your battery. Now plug in the AC adapter and turn on the unit. If it comes on, then let the battery "Rest" for a couple of hours. If it does not come on then your unit needs to see a reputable repair person.
Apr 08, 2009 | Acer Aspire 3680 Laptop
Display problem
If the laptop appears to boot up and the hard disk is spinning and the hard disk LED is flashing then the hard disk is OK.
Then the fault could be a faulty video cable or connector or CCFL lamp or inverter.
Try reseating the video cable/connector that connects to the motherboard first.
If this doesn't work then to determine if you have a LCD screen, inverter or video card problem, read this and follow these instructions.
Defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out
www.lcdparts.net
for parts, repair service and DIY info.
Jan 21, 2009 | Sony VAIO VGN-FJ270/B Notebook
Laptop will not boot and screen is blank
3 beeps means the RAM or memmory problem, check it by yourself or consult to a technician.
Dec 17, 2008 | Computers & Internet
Computers & Internet Logo
David Payne
David Payne
