Back to:
Tags:
Rainbow E series Canister Wet/Dry Vacuum
How do you get to motor?
posted by lthompson374 on Dec 09, 2007
how do you get to the motor?
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Jan 06, 2008
FixYa! (100)
noworries
Rank:Apprentice Apprentice
Rating: 92%, 9 votes
To get access you need to remove the plastic side cover panels. To remove these, I found the easiest way was to use a small flat screw driver, leverage it under the pastic in the centre at the 'cord end' and lift carefully. There are two lugs at the top and one at the bottom. The plastic panel will 'bow' a little, but with care, it will pop off. The gold looking vents underneath are just a 'facade'. By removing the side plastic panels they will expose three screws either side. Undo these and the top will half of the cleaner will lift off. Good luck!
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on how do you get to motor?:
I don't want to Accept this solution
Can you Help with these Vacuums problems?
Once in a while it will make a real faint noise the...
the silver disks or fans how do they go back together
the power nozzel or main unit of the rainbow e series has...
whenever i try to dispense water out of my wet vac the...
was just using it today and turned it off for a moment and...
Loading problems.
Repair Service
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
