Question about Kenmore Washing Machines
The agitator in my washer is not working and it is making a weird noise
    President:
  • 1,937 Answers
If you have the model number (lift lid and model, serial # etc. are on the cabinet, you can go to the Sears parts site.
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?pop=true&modelNumber=110.26902691&pop=flush
Enter your model number instead of the 110.26902691
Then look under the heading Agitator, basket and tub.
The problem may be the "agitator dogs" (4 plastic pieces that allow the top agitator spin one direction only.
Beyond that, the agitator connects to the main drive shaft (with one bolt) in the transmission.
If you're reasonably mechanically inclined, and the problem isn't the dogs, you can pull and open the transmission. In it are a number of gears, springs, cams etc.
A Whirlpool manual (posted on a number of sites) gives a diagram and operating flow for the washer showing how the transmission works.
We had a problem with a lot of noise on our Kenmore and traced it to a plastic cam and follower in the transmission that wasn't lifting a gear far enough above the main drive gear so that we were getting a lot of gear clashing noise.
Posted on Sep 15, 2009
How can husband fix grinding noise Whirlpool Washer makes when agitating?
I would check the transmission spin bearing and the tub bearing and washer, sometimes a bad counter weights can make weird noises also
Mar 08, 2015 | Whirlpool Washing Machines
Hav3460aww
It sounds like the motor is heating up and tripping the overload. The squealing is probably coming from you pump. Tilt the washer back and turn the pulley for the pump by hand and if it make the squeal, replace. If it does not you may have a bad transmission.
Apr 28, 2014 | Maytag HAV3460AWW Top Load Washer
Kenmore stopped agitating
broken motor coupling between the motor and tranny cost is about 15 bucks can get from repairclinic.com
Feb 27, 2010 | Kenmore 24032\24036 Top Load Washer
Won't spin makes weird noise.
Could be the motor coupler, transmission, or motor. Will it agitate now?
Jan 03, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool ult care II (plus) washer, agitator makes noise
yes, sounds like your agitator dogs are broken, four beige teeth inside top of agitator part only roughly 4.99 to 29.99 and labor 65.00 - 95 labor depending were u live and who u use. thank you
allbrandsappliancerepair.com
Sep 23, 2009 | Whirlpool Washing Machines
Kenmore Series 80 Washer, Model 20852 - Agitator not turning well, making noise
Hi, If the washer spins properly but the agitator does not work, it could be the dog kit needs replaced. If the washer does not agitate or spin, it is probably the coupler.
Put the washer in wash cycle with no laundry in it and see if the lower prt of the agitator moves. If the agitator moves, try and hold the upper half of the agitator and see if it will only move one direction.The agitaor dog kit is designed to only let the top part of the agiator to grab one way. When they go bad, they can make some noise.
To replace the dog kit in the agitator, remove the top cap/rinse dispenser and the inner bolt cover. Remove the 7/16” bolt and lift the agitator out of the washer. Separate the 2 halfs of the agitator and replace the dog kit inside the upper part of the agitator.
Please let me know if this helps you or if I can assist you further.
Thanks
Vic
Jul 17, 2009 | Washing Machines
Whirlpool washer agitates but makes a very loud noise
It sounds like the agitator teeth, that are plastic, are worn out. To check this, take the agitator cap off with a strong knife or flat-head screw driver, and check the circular teeth inside, to see if they are worn out. These plastic teeth are the agitator part of the washer, where as the spinning part is a metal set of teeth, at the bottom of the agitator. You see the metal teeth, when you take the agitator completely out. You will have to replace the agitator if the teeth are worn out.
Jan 11, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Washing machine noise
check the dogs in the agitater
Mar 25, 2008 | Whirlpool GSC9455 Top Load Washer
Won't Spin the water out...
Hiya WRock04... would be nice to have make and model.. otherwise.. look to replacing the brushes in the motor if the machine has done relatively little work... 3-5 yrs in some cases... otherwise a new motor unfortunately may be required.. specially if you can smell burning!!
regards Faggly
Mar 19, 2008 | GE WBSR3140DW Top Load Washer
Washing Machines Logo
62 people viewed this question
Sal DeAngelo
fordexpert
Mike Squire
