Question about Logitech EX100 967499-0403 Keyboard
Had keyboard/mouse since July. No problems (except heavy battery use) until yesterday. It just stopped responding. Two sets of batteries later and no luck. Had to plug in my old wired keyboard. Have repeatedly tried to connect with no luck. Is this correctible - or should I just toss it.
  • dquinn2600 Sep 08, 2009
    Apparently my post was not clearly explained. The keyboard just stopped working. It was not a battery issue. I tried two sets of batteries thinking I might have bad batteries. No luck. Keyboard is dead and will not reconnect.
  • 512 Answers
If you bought this new and it has a warrenty, send it back to them and get a new one.
Battery use for a keyboard and or mouse should be months, not days, my set uses them for about three months then need changing, have gone as long as six.
Posted on Sep 08, 2009
Wireless desktop 6000 keyboard problem
Check the inside of the battery chamber to see if there is corosion on the spring or front pip for the + ve.Batteries leak ands should be chaged every 6 months regardless
Jul 27, 2009 | Microsoft Wireless Laser Desktop 6000 V2...
Slow or none response time for HP Wireless Keyboard
You might want to check the batteries being wireless, also check the device conected to your tower that reads the keyboard, make sure its pushed in all the way or not being disturbed by any objects.
Apr 21, 2009 | HP Keyboard & Mouse
Mx3000 stopped working, read forums, reset receiver now dashes only when pressing any key. rebooted computer ... now keyboard not responding agian
I got a used MX3200, got the mouse working right off, but no keyboard. This solved my problem: with the wireless mouse working took out the keyboard batteries, pressed connect button on the receiver, replaced the keyboard batteries, pressed connect button on the keyboard. Voila!
Feb 03, 2009 | Logitech Cordless Desktop MX 3000...
Microsoft Wireless Optical Mouse 2000 stops responding
i would agree that a new one may be needed. i have a desktop set that, the mouse had failed. i got a better microsoft mouse, and i was able to use it with the desktop set.and have all of the functions of the new mouse through the original receiver. hope this helps! good luck.
Jan 21, 2009 | Microsoft Wireless Optical Mouse
Microsoft wireless optical mouse frozen
I've sorted it! Tried 2 sets batteries 1st then thought, maybe I should try a different set - 3rd time lucky...it worked
many thanks
Aug 17, 2008 | Microsoft Standard Wireless Optical Mouse
Dell Wireless Keyboard stopped responding, please help.
The keyboard should have a button underneath it. Press the button on the usb controller first and then the button on the keyboard. Repeat a few times to see if it connects. If you are still having trouble try another set of batteries as some batteries are not designed for wireless products.
Aug 15, 2008 | Dell Wireless Keyboard Optical Mouse w0147
Logitech rx650 installation problems
the difficulty is that while the usb cable/reciever works to attach a usb flash drive to the system I am unable to get the mouse to connect or be recognized by the system. have used several different new set of batteries and the laser light on the bottom of the mouse lights up and responds to proximity
Apr 24, 2008 | Computers & Internet
Keyboard not responding
Solution. My wireles keyboard stopped working except for the F-Lock key, the Media key and the sleep key. It wasn't batteries, even though I tried, communication was there because the above keys were working. Remove the batteries from your keyboard and let it sit for about 10 minutes. Press the red connect button a few times and other various keys every few minutes during that time. This may be the whole "capacitor discharge" trick, but I tired that with someone elses instructions and my keyboard did not work after 2 minutes of key pressing. I think it just needed more time to clear out the secure settings. Good luck, I was about to trash this keyboard until I tried again
Nov 26, 2007 | Elite Logitech Media Keyboard(KB9675590403
Keyboard wont respond
Often this is simply because the radio link between the receiver and the mouse/keyboard has been broken. Some possible reasons for this are: flat batteries, insertion of new batteries, connector to the computer removed, etc.
In the first instance, you should restore the Logitech devices to a defined status (reset). To reset the device:
Remove the batteries from the mouse/keyboard for approximately ½ hour.
Press and hold the "Connect" button on the receiver for 15-20 seconds. Make sure that the receiver is connected, the PC is switched on and that there are no batteries in the devices. After resetting, insert new batteries and restore the connection as follows:
  1. Press and hold the "Connect" button on the receiver for 1-2 seconds.
  2. Then immediately press the "Connect" button on the bottom of the mouse (locate this button before you start, all cordless mice have a "Connect" button)
  3. Move the mouse around to check that the connection is working correctly
  4. Press and hold the "Connect" button on the receiver again for 1-2 seconds.
  5. Then immediately press the "Connect" button on the bottom of the keyboard (locate this button before you start, all cordless keyboards have a "Connect" button)
  6. Use the keyboard to check that the connection is working correctly
  7. Both devices should now be working correctly
If one or both of these devices is still not working, try them on another compatible PC system to ensure that the fault does not lie with your PC system.
Nov 09, 2007 | Logitech Cordless Desktop MX 3000...
Logitech EX100 967499-0403 Keyboard Logo
238 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
