Question about Freezers
Which way do you turn knob to make fridge colder
  • 512 Answers
Bigger number is usually colder.
Posted on Sep 08, 2009
Which direction do i turn the temp knob to make it colder? i have no numbers on the unit to go by.
I'm taking a stab at this. But almost every product i have seen, cold is to the left when turning a dial or knob. when it comes to water lines; Hot is almost always left. Hope that helps.Good luck
Jun 21, 2015 | Crystal Cold Propane Refrigerator/Freezer...
How do I adjust the temperature to make the refrigerator cold
usually there is a control knob inside the fridge just turn it to colder and see what happens
Feb 03, 2015 | Samsung RS261MDWP - 26 cu. ft. Side by...
How do you "warm" a Midea fridge do you turn dial higher (5) or lower (1)?
The higher the number, the colder the fridge gets. Is it too cold in the fridge?
Apr 27, 2014 | Midea 1.4cf Refrigerator White
What shld settings be as food is freezing in fridge it has side by side knobs saying colder mid less cold it is a westinghouse fan forced frost free freestyle unit
The settings are "relative". Someone with this fridge in Montana may need to run the same fridge with different settings than someone in Texas to get the same temperatures.
Many manufacturers recommend that the fresh food compartment should be 34 degrees F, and the freezer -10 to 0 degrees F. To set this properly, place a thermometer in the freezer (that can display temperatures as low as the desired temperature). Adjust the thermometer for the correct freezer temperature before going on to the fridge. A fully stocked freezer could take 12 hours or more for temperatures to stabilize after making changes to the thermostat. Once the -10 to 0 degree temperature has been achieved, set the fresh food compartment temperature.
Place a thermometer (that can display below freezing) in a 6 (or so) oz flexible plastic cup of water and place on a shelf in the fridge. A glass of water could break if the temperature gets below 32 degrees if the water turns to ice. The water acts as a buffer to rapidly changing temperatures when the door is opened to read the thermometer. If the fridge is "full", allow 24 hours for the temperature to stabilize before making changes.
If the fridge and freezer are empty, changes may be seen in just a few hours or less. Otherwise, wait the 12 / 24 hours for the freezer / fridge compartments.
I hope this helps and good luck!
Sep 06, 2011 | Freezers
How to make my freezer colder
Hi, some thermostat control knobs and directions to make it colder are different. Here is the best way to find out which way to turn it to make it colder. Make sure you hear it running. Take the control knob and listen carefully while you start to turn it in one direction first. Turn it until you hear the unit shut off. If you turn it all the way to the left and it keeps running, turn it all the way to the right until it stops running. Once you know which way it stops running when you turn it, this will tell you that you need to turn it until it comes back on again and runs. This will be the way it turns to get the temperature to get to a colder setting. When you are doing this, do it very slow and give it about 3 minutes in between each time you start to turn it the other way. On mine it has numbers on it. The higher the number lets say from 1 to 8, the colder it gets, but some are the lower the number the colder it gets. So, you want it to shut off, so wait until you hear it running before you turn the knob. You can open the doors and it will make it come on faster. So when it goes off when you turn the control knob, you will no to turn it the other way for it to come on and it will get colder the more you turn it in that direction. Very easy. PS If it doesn't get colder when you find out which way it goes, you may have a bad thermostat. Please let me know. You can put a thermometer inside to watch the temperature
Good Luck,
Shastalaker7
Jun 30, 2010 | Hoover 9.9 cu. ft. / 280 liter Upright...
How does the control panel work? low numbers warm etc?? I inherited my partners mothers fridge freezer, unfortunatly it didn't include the instrution book,I have had it running on number 2 but it seems to...
Typically the larger the number the colder the setting. Is there an arrow on the knob that points to the left or right that says "warmer" or "colder" I also question your comment "freeze too much" because this is a freezer only, it will not keep things "cool" if you turn it up enough. If you mean there is frost on everything that is humidity and not the freezers fault.
Jun 03, 2010 | Kelvinator 12 cu. ft. / 340 liter Chest...
Temperature control
I have a danby mini fridge and freezer and noticed the same problem. The temperature dial has NO NUMBERS ON IT! it just has a strip that goes from light to dark blue. That's it. I looked in the manual and it doesn't say anywhere which way is colder...it makes sense that the darker the blue the colder the temperature but why keep us guessing?
Mar 15, 2008 | Danby 3.6 cu. ft. / 102 liter Chest...
Freezers Logo
696 people viewed this question
Top Freezers Experts
Dennis Boxerman
AJMAL KHAN
John Tripp
John Tripp
Are you a Freezer Expert? Answer questions, earn points and help others
