Question about Crosley Washing Machines
Specs for crosley heavy duty 22 lb rated-3/4 hp motor--model #cw22b5v
5 Suggested Answers
larryyb
  • 291 Answers
SOURCE: Speed Control only works in Heavy Duty
sound like your motor is going out ,,,, the wiring at the motor may also be loose from out of balance loads
Posted on Nov 24, 2008
SOURCE: admiral mega 22 plus heavy duty 2 speed washing machine
I think my set i just got today used is a 3 speed.Seems to be alright for now.There is a thing i was told called a harmonic balance it might be off or messed up.Tina.A(nc)
Posted on Apr 27, 2008
  • 714 Answers
SOURCE: kenmore heavy duty 70 series model 110-8237012
probably your drain pump leaking it has a seal right where it attaches to motor,,,,mine is leaking there but haven't replaced it yet! lol
Posted on Feb 28, 2010
jumptrout51
  • 3361 Answers
SOURCE: where is the model number
Either in the door of the dryer or on the top of the dryer.
Posted on Apr 19, 2011
Crosley heavy duty dryer blows out heat but will not spin
Check the dryer drum drive belt it may be broken or the dryer drum drive motor may have failed
Oct 18, 2016 | Crosley Dryers
We have a heavy duty crosley and recently it's starting to squeak and when when started and running
Hello amber mallette, thank you for your post!
From my understanding your Crosley dryer is squeaking once it starts running. This could be a possible problem with your belt, pulley, or motor. You may need to disassemble your dryer in order to access those components. This is not a simple DIY job. I would highly recommend having a professional technician out, this will help to avoid any future issues or personal injury. Hope this information is helpful. -Matt
Feb 25, 2015 | Crosley Dryers
..torque specs. rod bearings. f-350 2008 diesel 6.4
6.4L Power Stroke Diesel V-8 ... 350 hp @ 3,000 rpm. Torque. 365 lb-ft @ 3,750 rpm. 457 lb-ft @ 3,250 rpm ...
Feb 24, 2013 | 2008 Ford F-350 Super Duty
Crosley washer ddtergent dispenser for top loading
Hello - What exactly is your concern? Is it dispenseing or not dispensing?
Sep 30, 2012 | Crosley Washing Machines
I purchased a 1875 watts Timex Heavy Duty timer Model # 12-881 to connect to my 1200 watt water distiller. The timer is burned and has melted where the distiller was plugged in. We were furtunate...
Timex 12-881 timer has 3-prong outlet and is rated 15amp 1875 watts.
The timer melted because too much amperage was drawn across the connection and timer got hot.
Different things can cause this.
Phony rating, and/or mis-manufactured timer.
Defective timer.
If distiller has a motor, then it will draw more amps at start-up.
Timer is rated for incandescent light bulbs only.
Many timers say 1875 watts resistive, but instruction sheet will show 1000Watts incandescent and 1/4 HP horsepower.
Timer is plugged into extension cord.
Cheaply built product, not meant for constant use.
Timer outlet and distiller plug did not meet firmly, so connection heated up.
Turn off distiller before plugging into outlet so no spark is at the connection point.
I recommend appliance timer for operating appliances.
For example Intermatic HB 113 timer.
http://www.smarthome.com/25071/Intermatic-HB113C-120V-20A-Heavy-Duty-Mechanical-Appliance-Timer/p.aspx
Also heavy duty portable timer like Intermatic P1121
http://waterheatertimer.org/Intermatic-timers-and-manuals.html#appliance
Take a moment and rate answer:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Sep 01, 2011 | Timex Heavy Duty Appliance Timer
What is the HP capability of the intermatic TM12DOLB timer?
1 HP is max for 1875 watt timers on 120Volt circuit.
754 Watts per HP, but the motor start-winding takes much more initial wattage with a surge of high amperage and high heat.
http://waterheatertimer.org/Woods-timers-and-manuals.html#TM12
See general HP ratings for hardwire countdown timers
http://waterheatertimer.org/Countdown-timer-horsepower-ratings.html
I'm not sure that Intermatic makes that timer for Westek and Utilitec.
Since the timer is sold at Home Depot, I suspect GE is behind the design and manufacture.
Intermatic makes heavy duty portable pump-and-motor timers for 1HP application.
http://www.poolandspacontrols.com/products/portable%20outdoor%20timers/heavy%20duty%20outdoor%20timers.aspx
Add a comment for more help.
Upvote the help.
Jun 05, 2011 | Heavy Duty Westek TM12DOLB Decorative ...
Nov 23, 2008 | Kenmore 24032\24036 Top Load Washer
Chevy 5.7 17 bolt heads tork specs
Cylinder Head Bolt (Preferred Method) All Bolts First Pass in Sequence 22 ft.lb Long Bolt Final Pass in Sequence 75 deg. Medium Bolt Final Pass in Sequence 65 deg Short Bolt Final Pass in Sequence 55 deg. Cylinder Head Bolt (Optional On-Vehicle Strategy) First Pass in Sequence 26 ft.lb Second Pass in Sequence 44 ft.lb Final Pass in Sequence 66 ft.lb
Oct 13, 2008 | 1999 Chevrolet C1500
Printing faded color text on my color paper...
That stock might be too heavy for a bizhub.
Specifications state the following:
Plain paper (16 lb to 24 lb),
thick paper 1 (24-1/4 lb to 40 lb),
thick paper 2 (40-1/4lb to 55-1/2 lb),
thick paper 3 (55-3/4 lb to 68 lb),
thick paper 4 (68-1/4 lb to 72 lb)*, OHP transparencies*, postcards*, letterheads,
colored paper, envelopes*, label sheets*, banner paper (24-1/4 lb to 55-1/2 lb)*
Duplex: Plain paper (17 lb to 24 lb), thick paper1/2/3 (24 lb to 68 lb
*Can only be fed through the bypass tray.
These specs are directly from the user guide.
Is the paper running through the bypass tray?
Jun 09, 2008 | Office Equipment & Supplies
Washing Machines Logo
372 people viewed this question
Top Crosley Washing Machines Experts
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
Karl H
Are you a Crosley Washing Machine Expert? Answer questions, earn points and help others
