Question about Weather King 10AJA6001AH Air Conditioner
When unit starts fan doesn't run - Weather King 10AJA6001AH Air Conditioner
  • 396 Answers
Sounds like you have a defective fan. To check the fan remove the fan, attach plug in to wires and plug into 120 cepticleor 220 . .
Posted on Sep 08, 2009
Gas package unit
the bushing or the bearing in the motor may have already worn out. or may need some lubrication. the rotor is trying to turn but it's stiff and won't continue to turn. dont continue to turn on if it wont spin otherwise you'll damage the motor further. it might also be the busted capacitor "if it has"
Jun 04, 2013 | Amana Heating & Cooling
Gateway 500C: Dead. green PSU lite doesn't lite when pressing test switch
Obviously your Power Supply Unit is dead. You just have to replace it.
Feb 17, 2013 | Gateway Computers & Internet
What does message Er IF mean?
LG refrigerator "Er IF" error code is the "Icemaker Fan Error" message.T his error code indicates a problem with the fan that controls the unit's ice production. If this problem occurs because of ice buildup, unplugging the unit for 3 to 4 hours and allowing it to thaw may fix the issue. Call customer service if that doesn't work.
Oct 12, 2012 | LG Refrigerators
Outdoor fan dont start i give it help to starte them the motor start and run.? i think is a bad motor ? ( trane XL 13i ) thanks for help.
Yes could possibly be the fan motor, but before you change the motor, check the capacitor. It looks like a battery and is located in the electrical section of the unit. It may have one capacitor for both the fan and compressor. If the capacitor looks swollen or pregnant it is bad. If you have a ohm meter you can also check to see if the capacitor is open. Take the capacitor out of the unit after shutting off power. Note where the wires go before you take them off. Check across the capacitor with an ohm meter. (turned on to highest ohm setting) If the needle jumps up and then quickly back down, the capacitor is good. If the needle on the meter jumps up and stays up its shorted and needs replacing. If the needle doesn't move at all , the capacitor is open and needs replacing. NOTE : If the fan motor is whining when it is running, the bearings are worn and the motor will need replacing.
Aug 04, 2011 | Heating & Cooling
I have a DDR7009EE and the fan runs continuously even when the humidity in the room is below the setting on the machine. Shouldn't the fan stop when the desired humidity is reached?
Lyle, your particular model is designed for the fan to function constantly. However, the fan running doesn't mean the compressor is always running. The reason the unit was designed this way, is for the air to be continually moving, and when the humidity sensor picks up a rise in the humidity level (above where you have it set) the compressor will turn ON and extract that humidity.
Your unit is working as it should. Thanks for choosing FixYa.
Jul 28, 2011 | Danby DDR5009EE Dehumidifier
Refrigerator & frezzer no longer cooling. Compressor is still running , but condenser fan doesn't seem to be working correctly. Does the fan not working full time when the compressor is running...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jul 23, 2011 | Refrigerators
When the receiver powers up just the fan seems to go on. Resetting by holding the i/o will turn the yellow light off but doesn't turn the fan off and comes back on after you release the i/o...
Hello Joe, my name is Becki, with DISH Network. You will want to make sure that the receiver is in a well ventilated area, and that there is nothing heavy sitting directly on it. The receiver's fan can start running constatntly if the unit starts to overheat. You may also want to try putting the receiver out on the floor for a few hours to cool down. You can also try to unplug the receiver from the power source for 10 seconds, that can be a more thourough reset than holding the power button down. The fan will run while starting the receiver up, for about 5 minutes, then it should stop running loudly. If you continue to have problems, please let me know!
Becki Barned
DISH Network Customer Service
becki.barned@dishnetwork.com
Jul 13, 2011 | DISH Network ViP 612
Compressor doesn't come on...defrosting...only fan and light running.
I would suggest you check the starting capacitor and start relay before you give up on your unit. If it is the compressor, that can get very expensive because it is a sealed unit with freon.
Were your condenser grill clean and free of debrie? Was there air flow over the condenser?
Jul 03, 2011 | Maytag Refrigerators
Runs but doesn't work (no water accumulates)
It sounds like what you hear working is the fan. The unit also has a compressor; if the compressor is bad or the freon is gone, the fan will run but the coils wont cool to remove moisture from the air.
Jun 26, 2011 | DeLonghi DE500P Dehumidifier
HI I have a 30k BTU armstrong unit, compressor runs fine , but condenser fan doesn's start, does it works with the capacitor?
Many outside AC units have just one capacitor that starts the compressor and the fan. Some units however have two. Just follow the wires from the motor to the capacitor, pull it and test it. Make sure you disconnect the power from the unit by pulling the fuse block first. If the capacitor is good the motor may have siezed up or burned out.
Dec 17, 2008 | Goodman CKL36AR36 Air Conditioner
Weather King 10AJA6001AH Air Conditioner Logo
56 people viewed this question
Top Weather King Heating & Cooling Experts
Donni Steen
Tim Whalen
John Tripp
John Tripp
Are you a Weather King Heating and Cooling Expert? Answer questions, earn points and help others
