Question about Refrigerators
Door seals damaged model DMPP160011.Where can i obtain new?
  • 2,237 Answers
Www.partsselect.com make sure to get all of the info off of the name plate inside your fridge. usually located on upper right wall or ceiling.
Posted on Sep 09, 2009
    Sergeant:
    Champion:
  • 214 Answers
Sir, go to the nearby service centre of the refrigerator and ask them for your seal. i'm sure that they will give you.
Posted on Sep 08, 2009
DOOR NOT CLOSING CORRECTLY AND LEAKING ON LEFT SIDE
Is it level? Could have been damaged during shipping if its new. If its not new it could be a worn out door seal.
Apr 18, 2014 | Maytag Dishwashers
Hi, I think the seal is damaged on my fridge freezer. It is a CB18m/1c/fan whirlpool fridge freezer. Where do i look for a replacement seal? Thank you
Is a package/or a shelf blocking the door? If a gasket is required & damaged it would be noticeably different than the look of the rest of the gasket. The door originally was held straight by the screws behind the gasket & a undamaged door liner(cracked with weight of packages will cause it to twist), if it is twisted than it can be realigned by twisting it straight & may have to loosen the screws a little first & then snug them back up after it has been twisted straight. Gaskets generally have a flat magnet in them to pull the door up to the body of the fridge & with a model number(or take the gasket to them is the worse scenario) can be obtained from a Major appliance store or they can order it.
Dec 12, 2013 | Refrigerators
We have a Lofra dual fuel cooker 5 years old which needs a new rubber door seal on the gas oven but cannot find anywhere to obtain this part. Can you help? Pip Bedford
Hi I also had difficulty in obtaining a Lofra oven door seal but after searching and searching the internet I obtained an email address and now the problem has been solved. I received my oven door seal from the Italian Lofra company direct this morning. I dealt with a lady named Donatella and I found her very helpful. She can be contacted on donatella.talpo@lofra.it just give her the make of your cooker and she will let you know if she has one mine cost around £14. Good luck Suzie :)
May 03, 2011 | Lofra MXGC96AMF/CV Dual Fuel (Electric and...
Iceline upright freezer model "de
That is not that hard to fix and you can easily buy the parts yourself online...
Here is a tip that will help you with the online buying...
How to Buy
Appliance Parts Online
heatman101
Jan 16, 2011 | Refrigerators
Door does not seal properly which causes inside to ice up. Can this be fixed. Can you purchase a new door?
Check the door seal for splits or is it deforming. A door seal can be uasually obtained and easilly fitted. I would also check the door for alignment problems if so it could be the hinges,
regards
pete
Nov 06, 2010 | U-Line 75R Refrigerator
Door rubber keeps falling off
Hi and welcome to Fixya. Once a door seal starts coming off it begins to deform and tear away from the mounting points on the inside of the door. Most of the time the only option is to replace the door seal You did not mention if it was the freezer or food section seal that was falling off.
The replacement parts can obtained from this source"
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5218035
Freezer section door seal is Item 14 ( there is a 5 - 6 day wait for shipment)
And for the food section door seal (Item 103)
Available now.
Feb 06, 2010 | GE Adora DSS25KSTSS Stainless Steel Side...
Instructions for changing a door seal on an
There are videos of how to change a door seal on you tube. Not necessarily for your particular model but changing them is virtually the same for all machines.
Jan 27, 2010 | Washing Machines
Rubber seal damaged. needs to be replaced kenmore model 970-c44052-00 How do I remove sides to get at it?
there is no need to remove the side to replace the door seal, just behind the door seal there is a spring clip undo this and fold the seal into the drum were you should see another spring clip undo that as well and the door seal comes out from the front through the hole in the door, to refit a new fold the seal till its inside out and fitted on the inner drum first fit the inner clip then pull it through the door hole and fit the outer spring clip out side the door
Dec 06, 2009 | Kenmore 43142 Front Load Washer
FROST BUILDS UP IN ICE CHUTE FROM STORAGE BIN, AND BUILD-UP BLOCKS RELEASE OF CUBES....ALSO WATER LEAKAGE OUTSIDE LIKE WARM AIR IS COMING UP FROM OUTSIDE...
As a suggestion:
Check the trap door that opens and closes each time you obtain ice cubes. The water leakage may indicate a damaged seal allowing air from outside to enter. This will cause increased frosting and blockage.
The trap door may not be closing all the way or the magnetic seal around the freezer door may be damaged or not sealing completely.
You may also need to check the thermostat.
Temperature may be set too low. If you make an adjustment allow the unit to stabilize for 12 hours before attempting another change.
Oct 04, 2009 | GE Refrigerators
Frigidaire dishwashers FDB2810LDC0 bottom of door leaking where do I find a new seal?
You can obtain a new seal through an appliance parts store. You will need the make and model number of your dishwasher to get the correct seal.
Oct 03, 2009 | Frigidaire 24 in. FDB126RB Built-in...
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
