The screen has cracked on the hp paviallion latop but the remote monitor will not work in any other mode than safe mode. is there a work around where i can get the computer to work in normal mode with the remote monitor through the vga external port
  • 4,806 Answers
Yes the monitor should work in normal mode and is a keyboard toggle.
The toggle is performed by holding the Fn key and hit the F8 key, you may have to tap the F8 key a couple of times, also wait a for few seconds for the switch to take place.
Good luck.
Posted on Sep 08, 2009
  • Lee Hodgson
    Lee Hodgson Sep 08, 2009
    Disregard my previous post.
    Yes alc03 could be onto something, now because you can only get the monitor working in safe mode means there could be a bad display driver stopping the monitor working in normal mode, the screen on the laptop would also suffer from the same problem too.
    Start the laptop in safe mode, right click on "My Computer" for XP or "Computer" for Vista, select "Manage" from the list and then select "Device Manager".
    Look down the list for "Display adapters", click on the + icon next to it and uninstall the driver by right clicking on the adapter.
    Restart your computer after the uninstall is complete, you should now be able to use the external monitor. The drivers will reinstall themselves once you are in the operating system but it would be a good idea to update the display drivers just in case they go bad again.
    Good luck.
  • 40 Answers
Check if VGA driver is install properly or even check for update on the driver, you should be able to work on normal mode. To check if the driver is install properly : right-click on my computer - properties - then go to hardware tab and press device manager button. A list of device will appear, check under Display adapter if there is an exclamation mark on it, it means you need to udate it but even tough I would go on HP site and download the newest driver for it.
Not booting hp presario f700
hit the f5 key then follow the screen from there that is in safe mode
Mar 21, 2014 | HP Compaq Presario F500 F700 and G6000...
My HP A735W is turning on but stays in power save mode and no key board or mouse function
I think the issue is your monitor. If the monitor constantly says Power Save Mode and not let anything else display then the monitor might be bad. See if we can isolate the problem by the steps below.
Try booting up in Safe Mode and see if the monitor works ok.
Turn off the computer, then hit the power button to turn it back on and immediately start hitting the F8 key repeatedly until you see SAFE MODE. Take the Safe Mode option and let it boot up. Safe Mode will look different to you, the screen will be darker and the icons bigger, this is normal. If it works ok in safe mode then the monitor is ok and we might have an issue with a setting.
Try connecting another monitor to your computer. Borrow a monitor from a neighbor, friend, relative or co-worker and connect it to the computer. If the Borrowed monitor works ok, then your original monitor is bad. If the Borrowed monitor does the same thing as your original monitor then the issue is with the computer (possibly the video card).
May 20, 2012 | HP Pavilion a735w (PL308AAR) PC Desktop
I have a attention input not supported recanagle that continually scrolls around and around my screen and i cannot acces the menu or do anything. I disconnected it from my modem and then from the monitor...
This is most likely because your computer is trying to display a screen resolution higher then tht monitor can support. Turn your PC on, and press F8 until you see a black and white menu. Select safe mode. Run safe mode and when windows loads, goto your control panel. Select Display and navigate to the resolution / settings tab. The screen resolution should be set to 1440 x 900 for this monitor to display video correctly.
If you need more detailed information on where to find the display resolution settings in windows I will need the name of the OS you are running... XP, Vista, Win 7 etc..
Regards, Chris
Jul 01, 2011 | HP w17e Monitor
I have a hp latop and when i turn it on it load but then comes up a blue screen and wont let me on to any of my files it just says there was a problem and windows shut down ect.. how do i resolve this...
Try booting the computer into safe mode...this is accomplished by turning it on and just after the bios screen you press F8..here you will see a list of options..go to safe mode and press enter...once in safe mode you may be able to figure out what is causing the system to shut down...a common problem is that you changed some hardware or installed software that is not compatible with the system...in safe mode you can remove the software or hardware that is causing the conflict
Apr 25, 2011 | HP Computers & Internet
Hp f2105 monitor goes immediately to sleep mode
Sounds like your monitor is not processing the resolution signal from the graphics card. Reboot the computer in "safe mode with networking", from there you can play around with the resolution, start low resolution and work your way up to test the monitor.
Sep 07, 2009 | HP f2105 21" LCD Monitor
Computer having touble booting up
Try going into safe mode (VGA mode) and see if this works. If you cannot go into safe mode you may have a problem with your video card. Also if you set your resolution too high for the monitor, you will get this problem. If you have another computer and remote desktop is enabled on your problem PC try to Remote Desktop in from the working comptuer and change the resolution settings to a lower setting on the problem computer.
Sep 06, 2009 | HP Compaq Presario S3000nx (DC475A#ABA) PC...
HP Pavillion 9000 Display Problem
Hi i seem to have solved the problem using a seperate display and running in safe mode, using safe mode i was able to run "spyware doctor" and "reg edit" both found problems, spyware doctor found a trojan in a hidden folder with a deep scan that took over an hour and a half, it was critical and could not be identified,
Regedit had backup files and found 200 problems that it fixed i changed the PC to start in default configuration and then restarted without the external monitor and all seems ok
Jul 23, 2008 | HP Pavilion dv9000z Notebook
Monitor
When your computer is starting up, hit F8 and you'll see the safe mode, safe mode with networking, etc. screen...You should see a choice that says "enable vga mode". Select that and windows will start and the os will select a screen resolution for you. After that, everything will work fine...I hope.
Good Luck!
Anonymous
Mar 15, 2008 | Acer X193W LCD Monitor
Emachine 15' lcd monitor
Your query - "can the monitor work with an older HP computer?"
Normally yes, assuming that there is no hardware fault. The message is an indicator that somehow the settings of the display of the old HP computer does not match that of the Emachine 15' LCD monitor.
Perhaps what you can do is to run the old HP PC in Safe Mode (press F8 before Windows starts), using the arrow keys, select top mode setting in the Menu which is Safe Node, hit enter. Windows should then start and normally should be viewable no matter what settings the monitor can handle. On Safe Mode Windows, right click on any clear area of the desktop, click on properties, Settings tab, move the Screen resolution to the left most position, set the color quality to the lowest possible choice. Click on Advanced button, click on Monitor tab, set Screen Refresh Rate to lowest possibler, OK, OK, reboot.
Hope that this be of some help/idea. Pls post back if things worked out or should you need additional information.
Good luck and kind regards
Dec 09, 2007 | E-Machines eMachines Monitor E15T4
Booting up
what is happening is that the screen resolution of the notebook is not matching the capabilities of the monitor and is therefore going into power saving mode, unfortunately you wont be able to change it as the screen is damaged, that is why it works in safe mode as the resolution is only 640 x 480 without any graphics drivers
Aug 29, 2007 | HP (D7580-60003) Motherboard
Computers & Internet Logo
43 people viewed this question
David Payne
David Payne
