Question about HP Office Equipment & Supplies
My HP Deskjet 970cxi printer suddenly stopped in the middle of an ongoing printing job. The extreme left red indicator (for ink cartridge ??) is blinking but I did not get a low ink message earlier. What should I do?
    Guru:
  • 1,049 Answers
The red light is a paper jam, the orange light next to it is the ink. You should remove the back panel on the printer, or duplexer if you have one. Then check for paper or obstructions in the back around the two large black wheels. Remove the paper and look for a jam underneath. If you can't find any jams, remove the ink; clean the carriage and cartridges thoroughly, and reinstall them.
Posted on Oct 13, 2009
HI I HAVE A DESIGNJET 1050C PLUS WHIT ERROR 0B0007
Posted on Sep 08, 2009
I just replaced the color ink cartridge on my deskjet 970 and now it only prints in purple. what can i try?
Mostly, printer cartridge error occurs when the printer head is unable to identify the cartridge properly. And the basic reason behind this is that the cartridge is improperly attached. To reattach the cartridge, turn on the lid of the printer and then remove the cartridge from the printer head. Check the cartridge to make sure that there are no scratches or other damaged parts that can contribute to a printer cartridge error report. Take note that the cartridge should not be left open for more than 30 minutes; otherwise the ink will start to dry up and the cartridge will get clogged.
Nov 08, 2010 | HP DeskJet 970cxi InkJet Printer
I just had my ink cartridges refilled, but the ink light keeps blinking and the printer won't print.
probably needs to be reset !! go on the Internet and do a search for "How to reset my HP Deskjet 970cxi" and that will tell you what you need.
Nov 01, 2010 | HP DeskJet 970cxi InkJet Printer
HP 970 Cxi. Problems with colour printing. Ink cartridge is new
I have the same problem. I suspect the ink cartridge part # 78 that you and I bought has problem. I plan to return it today to the vendor.
Nov 15, 2009 | HP DeskJet 970cxi InkJet Printer
The red light on left is blinking. What does that indicate? I have a deskjet 904C. There are three light The left one is blinking, the middle is okay and the right is the green one, that shows me the...
Hi:
If you open the door on the top of the printer, while it is powered on, the ink cartridges will move to a spot that shows you the status of your ink.. There are little cartoon pictures of the cartridges with smiles or frowns to tell you if you have an empty color or black cartridge.
Nov 04, 2009 | HP DeskJet 940c InkJet Printer
Hpdeskjet 970cxi only prints blue and black
When refilling cartridges it doesn't always work. replace the ink for known good or new cartridges.
Feb 19, 2009 | HP DeskJet 970cse InkJet Printer
HP deskjet 970cxi not printing red
Hello, usually the refilled cartridges doesn't work well.
You can try to fix your problem doing this:
1) Put some boiling water into a cup
2) Put the the cartrigde (print surface) close to the water to receive the steam (not inside the water)
Do this just a couple of minutes.
3) Put it back ther cartridge into the printer
4) Align or clean the cartridges with a printer program
5) Try printing again
If still does'nt work buy original cartridges or due the high cost of them buy a new printer.
Please don't forget to rate this solution! Have a great day!
Oct 07, 2008 | HP DeskJet 3325 InkJet Printer
932C Constant blinking ink light
problem here is the orange light blinking- has ink in the cartridge- stopped printing in the middle of the page
Jul 19, 2008 | HP DeskJet 932c InkJet Printer
Printer won't print
Did you peel the piece of paper on the ink cartridge?Or if that doesnt help do this get the cartridge out and then dip some water on the ink leaking part with a piece of paper and well see what will happen.
Mar 25, 2008 | HP DeskJet 5550 InkJet Printer
Deskjet 970 unable to get test
ok...first...low color will do that blue effect..
and, you may need new drivers
remove old ones first
go here for fresh set
then reinstall
Feb 26, 2008 | HP DeskJet 970cxi InkJet Printer
Printer cartridge container doesn't stop in the middle
It appears that the injection may have been lethal, it was still using the ink that it carries in its tubes then it mixed with the injection and is now blocked \ faulty. To repair it you could try getting a new set of HP inks.
Oct 20, 2007 | HP DeskJet 3940 InkJet Photo Printer
331 people viewed this question
Ben Johnson
