Question about Rinnai Toyostove Direct Vent Heater: Toyostove Laser 73 Shipping
Toyo laser 73 Pinging noises during warmup and cooldown
I know The owners manual says it is normal to hear the metal expanding and contracting from the temperature change. But it is very loud. Both my monitors were quiet. Is there anything I can do to lessen the noise. It wakes me at night! Had I known this, I would have stuck with a monitor. This laser is one week old.
  • motorhed Dec 27, 2007
    Still does it. It's coming from inside the cabinet. It sounds like the burner assembly. It's doing it mostly during cool down now. It's better than it was.
  • 625 Answers
Slightly loosen up a few screws on the cabinet
Posted on Dec 14, 2007
  • THOMAS MIERZWA
    THOMAS MIERZWA Dec 28, 2007
    I own a monitor 441. I do mostly all repairs myself as the guy up the road charges an arm and a leg for it. some repair parts I have to purchase from him - and I really regret going to him for parts. I broke the original view port glass and found a replacement from mc master-carr industrial supply. it is a piece of boro-silicate glass that is heat resistant and costs a lot less than MPI products. The gasket material I also got from mc master. got a 3'X4' piece for about $15 that I could cut with scissors to whatever size I needed. The connection between the "pot" and the heat exchanger is a movable tube with a composite gasket. as the pot and the exchanger heats up, the tube moves out a touch, but not enough so the gases escape into the room. when it cools down it moves back into the pot. check here for metal to metal contact.
Where is the flame rod located in a toyo 73
It's the white wire that goes to a metal rod that goes through the can aroind the from of the burner can
Feb 23, 2014 | Rinnai Toyostove Direct Vent Heater:...
Refrig making noiise
They are telling it is normal because they dont want to replace it. When in all honesty it isnt. Behind the inside pannel is a protective layer of insulation with a thin layer of metal. The insulation is either not covering the entire plactic sheild. Causeing the metal to contract. It will also make it run more because it warms up faster than needed. Thats where you hear the loud noise comming from. I would demand they take it back to the store and replace it with a new one or call the better buisness beu. Hope this helped.
Nov 24, 2012 | Samsung Refrigerators
My toyo 73 has started making a loud vibrating noise during startup but gets quiet after running a little while...the fan is not on during start up....
The fan blowing air to the room might not be on but the flue fan would be. I reckon this is where the noise might be from. Fan impellors get coated with dust and this throws the balance out (similar to a car wheel if you loose one of the balance weights). Highly recommend getting it serviced by a good technician. Always good practice every year or so and might fix the problem.
Sep 20, 2010 | Rinnai Toyostove Direct Vent Heater:...
Why does car make constant ticking noise from metal expanding and contracting . Even makes ticking noise when running. Same noise you hear when you turn car off.
The exhaust system on your car is stainless steel, and it heats and cools quickly, there is nothing wrong with this. all your hearing is the joints in the exhaust system expanding and contracting. My 2007 impreza 2.5 does the same thing. And when you turn car off the system is cooling off and contracting.
Sep 25, 2009 | 2007 Subaru Impreza Outback Sport Wagon
Exhaust pinging
it is the exhaust actually cooling down, this is fairly normal especially in brand new vehicles or vehicles with new exhaust. the metal used in the exhaust expands with heat you shut the car off and the heat goes away so metal contracts. nice car by the way, my neighbor around the corner just bought a black one. good luck
Mar 07, 2009 | 2008 Pontiac G5
Ruud heating problem (clicking)
Hi,,this is normal for any heater,,some are more audible than others ,,as metal parts heat up they expand,,and as they cool they contract,,what you hear is the metal expanding and contracting.
Completely normal, no worries.
Jan 19, 2009 | Ruud UAMB Air Conditioner
Toyo 73 makes constant noise when running
Could be the blower or fan motor if you haven't had it cleaned in a while.
Nov 24, 2008 | Rinnai Toyostove Direct Vent Heater:...
Toyostove Laser 73 EE2
The firing sequence for a L73 is blink, blink, blink, on the green burner light, then it clicks up to the medium, amber or yellow light...that's when the pump kicks on. If you hear click, click, click, or thump, thump, thump, that means the pump is starving for fuel. The problem is from the carburaot/sump back to the fuel tank. You may have icing in your line or a line restriction, no fuel, plugged fuel filter or plugged sump screen. You can thaw your fuel line, until you have a free flow of fuel and then push the red restart button on top of the sump. Try to restart your Toyo.
If you follow the firing sequence and hear no click, click, click or thump , thump, thump and your Toyo goes off on EE2 then you can have a dirty flame sensor...the whilte wire running to a U shaped part that is the ground for the entire unit. You can take ythe ytwo phillips screws out, turn the part to the side and wiggle it out. Clean it qith a green scrubby or sandpaper and put it back in. Be sure it points stright down. Then take out the igniter which are the red wires. Put a long screw driver in there and rattle it around real good. You are trying to shake any carbon cxhains off the burner ring that can be "shorting" the flame sensor. You can also removee the 1/2 inch flare nut from the fuel nozzle...brass yellow colored metal part, and put a paper clip or wire down that about 3 inches. That will clear any blockage in front or inside it. Put everything back together, hit the red reset button on the sump and re-fire your Toyo. You might get it going in this manner. If not, you may need a tuneup because your Toyo is too sooted up to run correctly. Try these things and post back!
Nov 10, 2008 | Rinnai Toyostove Direct Vent Heater:...
Ticking noise
It is part of the waste gate just above the gas tank. It periodically checks for leaks and pressurizes and releases. Gives a ticking noise when it does this. Not a problem and GM is aware of this and said its normal on our cars.
Jun 02, 2008 | 2007 Chevrolet Cobalt Coupe
Air ducts are noisy
Many heating/cooling ducts are metal, so they conduct noise quite readily from the air-handling unit to your rooms. To break the conduction of sound, you can have a heating contractor insert flexible insulation ductwork between the heating/cooling system and the ductwork runs. If you hear a pinging or popping sound coming from the ductwork, this may be caused by thermal expansion or by air blowing past a loose flap of metal. Track along the duct runs, listening for the sound. If you find it, make a small dent in the sheet metal to provide a more rigid surface that?s less likely to move as it heats and cools.
Jan 18, 2006 | Haier Energy Star ESA3183 Air Conditioner
Rinnai Toyostove Direct Vent Heater: Toyostove Laser 73 Shipping Logo
311 people viewed this question
Top Rinnai Heating & Cooling Experts
Paul Carew
vance jones
Mack Baxter
Are you a Rinnai Heating and Cooling Expert? Answer questions, earn points and help others
