Machine stuck on F08 what is solution? Hotpoint WT965
  • 3,230 Answers
F08 indicates "Heater Relay stuck or Pressure Switch stuck on full".
You'll need a multimeter to be able to carry out some checks.
Check the heater for continuity, you should get a reading of around 25 ohms.
Check the pressure switch connections on the main pcb, usually J3
Check the pressure switch wiring and connections.
Chek the wiring at the heater for internal breaks. (The wire looks ok but when pulled snaps easily).
Check the pressure tube and chamber.
Unplug the appliance from the wall socket.
Take the lid off and locate the pressure switch.
Take off the thin tube attached to it and blow down the tube to try and clear any restrictions in the pressure hose or chamber.
Refit the tube and try the machine again.
If everything checks out ok, it would suggest that the main pcb will require replacing and the software written to it.
Thanks
Posted on Sep 08, 2009
Error code F08 FLASHING WILL NOT SPIN
The pressure switch is stuck and the machine thinks it is full of water. You need to remove the top, look for the pressure switch and unplug the hose on it and blow air through the hose. Then replace the hose on the switch. It looks like this: http://www.yourspares.co.uk/parts/hotpoint/washing-machines/wt960p/parts/ys56011/hotpoint-wt960p-pressure-switch-spares-C00194160.aspx
Feb 06, 2016 | Hotpoint Ultima WT960P Washer Front...
Leaking hotpoint ultima washing machine
Hotpoint ultima wt965 washing machine This video will show you how to find that leak on any front loading washing machine
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
Jul 16, 2012 | Hotpoint Washing Machines
My hotpoint WD640 is flashing F08 error message. What do I need to do to fix it? Thanks N
For most Hotpoint (and other named) models 'F08' means 'heater relay (possibly) stuck'. 'Check power supply connections to the heater, wiring and module (i.e. PCB) connections' (apparently poor PCB connections are often the cause)
So- if you are not electrically confident and competent yourself, which you may be, you need to employ the skills of a partner, friend or service engineer ;-0)
Sorry we cannot be of more help!
Good luck, John C
Mar 14, 2011 | Washing Machines
What does "f08" mean on
The error F08 indicates that the heater relay is stuck. This could be a fault with either the pressure switch, heater or the module connections.
Think you need to book a service call from engineer.
Feb 06, 2011 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint Aquarius Fault Code F-08. What does this mean?
F08 means Heater relay stuck: check pressure switch, heater & module connections..
Dec 10, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Wd640 showing f08
Code F08 indicates heater relay stuck.
  1. Check pressure switch connections.
  2. Check heater connections.
  3. Check control connections.
  4. Check and clean pump filter.
Please rate my sol;ution.
Thanks.
Nov 15, 2009 | Hotpoint Aquarius WD640 Front Load...
Hotpoint 1600 wt965 washing machine it has f-18 error message
Not good news - need to book an engineer, F18 is
Communication error the main module could be at fault (PCB)
This is located byhind the switches under the top, don't attempt to have a look though
Oct 25, 2009 | Washing Machines
Ive got a ultima WT965 and it keeps saying F-08?
F08 HEATER RELAY STUCK CHECKPRESSURE SWITCH /HEATER + MODULE CONNETIONS
Mar 21, 2009 | Hotpoint Ultima WF860 Front Load Washer
Test on display cant use washer
turn the machine on while you press the start and on buttons at the same time until dOFF appears.
Dec 17, 2008 | Hotpoint Ultima WF840 Front Load Washer /...
F08
your heater relay is stuck check all wiring connections to and from heater
Sep 14, 2007 | Hotpoint Ultima WF840 Front Load Washer /...
Washing Machines Logo
171 people viewed this question
Top Washing Machines Experts
