Question about RTO Automatic Transmission And Engine Oil Pressure Tester
Rear seal automatic transmission leaking, trying to repair, need to know how to replace bushing in 1986 chevy pickup
  • 59 Answers
Remove the rear tail shaft from the trans. remove the speed sensor or cable first, then press the bushing out or have a machine shop press it for you.
Posted on Sep 08, 2009
How to replace a rear main seal in a 2001 chevy 2500
several things, the rear main seal is accessable by removing the transmission. if this vehicle is standard transmission, then would recomend new clutch at this time given the amount of labor involved. if automatic, remove drive shafts, transfer case, transmission, and flexplate ....replace rear main. approx 5 hrs.
DW Mylin
Nov 29, 2012 | 2001 Chevrolet Silverado 2500HD
How to tell which transmission is in my 1994 gmc 2500 van
On most vehicles the transmission information is inbeded the VIN # or vehicle identifation number . Unfortinatly on GMC and CHEVY its not . It is stamped on the passangers side of the transmission at the rear of the oil pan just above the pan gasket you will likely have to clean it off to read it it will be a 9 digit # with letters being in it . The most common transmission for an automatic is the 4L60-E If the forth digit is D thats what it is . As far as the leak goes you need to deturman where its leaking from the pan gasket or the rear oil seal or is it comeing from in front . Transmission do not normanly leak so make sure that its not engine oil you are seeing that is being blowen back witch is much more comon . Transmission fluid is red and smells differant then engine oil and is thinner . Check the oil level on the transmission see if its red and dose it smell burnt if so it will be more black witch is vary bad . Do you have any shifting problems .Also check your engine oil to compare the 2 oils . In a nut shell its your vehicle and your the olny one that actully look at it and looking saves money and blindly replaceing parts costs a lot and rearly fixes the problem
Jun 09, 2012 | 1986 GMC G2500
My transmission leaks what should i replace
There are at least 5 places on the Automatic transmission that can over time, and mileage develope fluid leaks. Front converter seal at the front of the transmission,pan gasket in the center,dipstick tube o ring at the center on one side ,speed sensor o ring,and the tail shaft seal at the rear,of the transmission.
Place a flat piece or huge card board,under the engine and transmission,after driving you will see where the fluid,red in color is dripping. Its easier to spot exactly where the leak is comming if you can look under the car,while it is running, The easiest leak is the pan gasket,the dipstick tube, and the speed sensor,then the rear housing tail shaft bushing and seal.
If the front seal(converter seal) is leaking the transmission will need removed,and the seal,and maybe even the front pump bushing Replaced,it would be a good idea to replace the bushing esp if it has high mileage,80,000 or 100,000 miles of use.Change the fluid and the filter,while repareing the leak or leaks.Is a good idea.
Sep 17, 2010 | 1995 Chevrolet Camaro
Clutch replacement instructions for 1986 VW Jetta
The release bearing goes in the back of the transmission. You'll need to remove the round "VW" cap on the end of the transmission. I would need to see the pilot bushing to know for sure. It could be the starter bushing or the clutch pushrod bushing.
Apr 25, 2010 | 1986 Volkswagen Jetta
I need to replace the rear main seal on my 95 chevy pickup with a 350. do i need to drop the tranny?
Yes, either pull the trans or pull the engine. No way to get in there with out having one of the two out!
FYI it's very rare for a rear main on that engine to leak, Most all of the time it's the oil pan gasket or coming from higher up like a valve cover or the intake gaskets!
Oct 21, 2009 | 1995 Chevrolet K1500
1986 ford ranger 4x4 2.9l leaks transmission fluid as fast as it will go in not leaking from dipstick tube loks like it is coming from around the flywheel
You are leaking at the converter seal on the pump. Many times this a result of a larger problem and as trans needs to be removed to replace it, have converter neck checked for cracks and support bushing in pump checked as well.
Aug 15, 2009 | 1986 Ford Ranger 2WD
95 ford escort transmission leak
Dont waste your time and money trying to use a transmission stop leak product, they don't work on large leaks, you say the leak is excessive in this case the you must remove the transmission to access and remove the torque converter, after you have removed the torque converter carefully inspect the torque convert imput shaft for wear and also you will need to visually inspect the transmission front pump bushing for wear also, I have seen it all to often people just replace the seal thinking it was just a seal failure, well more times than not there is a reason for seal more than just the age of the seal, excessive wear on trans pump bushing and torque converter imput shaft is usaully the cause, check and repair those as good practice during this repair unless you just like to do the repair over again for free... also check the torque converter run out, sometime when they are repaired they are welded back together somewhat crooked which will cause it to spin off of a true center, this will cause immediate damage to transmission. Check also your engines crankshaft end play for looseness this can cause wobble which will transfer to transmission causing this problem as well... do the repair thouroughly and who ever does it for you have them check all that I listed and you should get a good repair which will last without issues.... please rate my help thanks...
Aug 08, 2009 | 1998 Ford Escort
Rear Seals Blown Out
The rear seal can be replaced but not without pulling the transmission, then you remove the seal holding case knock out-the seal and find the number on the seal and buy one and replace it and the gasket to the seal holder, also buy a speedy sleeve for the crank or you will find it leaking again.
Jun 17, 2009 | 1986 Toyota Pickup 4WD
Manual Transmission Filter?
The Borg Warner T-5 manual transmission has no filter. Assuming the leak is not really the rear main seal of the engine leaking, which is more likely, then it leaking from the front of the transmission. You will need to drop the transmission to get to the front seal on the first motion shaft. Unless you are really mechanically inclined or have a friend who is, leave it to a good shop.
Mar 03, 2009 | 1996 Chevrolet S-10 Pickup
Front Main Seal is blown on the Transmission
You have to remove the transmission, remove the torque converter to access the seal. Most likely the bushing behind the seal is worn out allowing fluid to leak past the seal. After the trans. is out, take it to a trans. shop. It requires a special tool to change the bushing. Seems like a bunch of work for $10.00 in parts. The rear main seal requires pulling the pan to access it. When the trans. is out, this is the time to replace the rear main seal on the engine.
Jun 10, 2008 | 1993 Ford Explorer Limited
RTO Automatic Transmission And Engine Oil Pressure Tester Logo
242 people viewed this question
Top RTO Measuring Tools & Sensors Experts
jdthefixer
Vuk B
Bill Boyd
Are you a RTO Measuring Tool and Sensor Expert? Answer questions, earn points and help others
