One likely cause is a blocked optical sensor . Try these three things, in order, and check the printer after each: - Pick up the printer, turn it upside down, and shake it. If 40 pounds is too much for you to lift, get a friend to help. Or, better yet, get a friend to do it without your help. - Using an air compressor with a blow gun attachment, direct air to the paper path entry and exit, and to the sides of the platen. Then look for torn-off tractor feed bits of paper in the crevices. You may need tweezers or needle-nose pliers. - Take the cover off and repeat the previous step with the air compressor. This is tricky. Use this as a last resort, as the printer may not be usable after a troublesome disassembly. Do this only if you're going to have to replace it otherwise.
Hi, Iam Having problem to work with tally 4.5 in xp giving the error message that insufficient dos...
(More)
Hi, Iam Having problem to work with tally 4.5 in xp giving the error message that insufficient dos files. Kindly show me the solvation
Describe your Tally Matrix T2280 : power up printer comes with THS ERROR 001. but still able to come...
(More)
Describe your Tally Matrix T2280 : power up printer comes with THS ERROR 001. but still able to come online
I have a tally printer that needs setting up. Can someone help with the procedure for setting up...
(More)
I have a tally printer that needs setting up. Can someone help with the procedure for setting up this printer. It is a T2280 printer
