Question about HP Photosmart 935 Digital Camera
Camera turns on and shuts off right away ? New batteries
    President:
  • 1,564 Answers
Try cleaning the battery compartment contacts with a Q-Tip dampened not soaked in rubbing alcohol. Also clean the battery and the charger contacts also.
Posted on Sep 08, 2009
My camera turns on then turns right back off again?
Same thing happened to mine, and it had to be sent away for repairs.
May 07, 2017 | Kodak EASYSHARE M763 Digital Camera
After i turn on my Optio E10, it shuts off right away even after i put in new batteries.
Sounds like a memory card problem. Try using A 512mb San Disk SD Card. Not a San Disk SDHC card. see if that doesn;t help you out. Good-Luck
Mar 21, 2011 | Pentax Optio E10 Digital Camera
When I turn on my camera it shuts off right away,i charged it many time for many hours, but no luck,it kees shutting down
by now you may have "cooked the battery!" you can over charge a battery,,,and if you do its then a dust bin job,,,try a new battery in it first,,,,
Aug 30, 2010 | Kodak EASYSHARE M1063 Digital Camera
Camera turns on, and then turns off again right away
My M1033 had the same problem...I found a blog about someone using air to clean around the lens area...I cleaned my lens very thoroughly and noticed some gunk and once I cleaned this off, the camera seems to work like new!
Apr 05, 2010 | Kodak EasyShare M1033 Digital Camera
New batteries are not accepted
put batteries in very carefully - not bouncing them in. If you get the 'change the batteries message' then open the battery cover turn the camera a little gently to reposition the batteries and hopefully it should go away. Test your charger too ... is it charging? is it the same thing with non-rechargeable batteries?remember Batteries don't work well when cold this could cause the camera to shutdown. It might also be that the auto shut down setting is too short unless it is shutting down while you are actually shooting.make sure you are using the correct battery type and match.clean the contacts in the battery compactment.hope this helps
Sep 06, 2009 | Canon PowerShot A430 Digital Camera
Turns off right away
You probably didn't get all the sand out and now it's preventing the lens from opening correctly prompting the camera to shut down.
Aug 16, 2009 | Polaroid T831 Digital Camera
Camera turns off by itself after taking a picture
A friend of mine had the same prob after putting in brand new batteries, it was i bit wierd but i tried some different batteries and it started working , try some new batteries. hope this helps.
Feb 28, 2009 | Panasonic Cameras
My kodak easy share v1233 camera turns on the turns off right away. I have the same camera model with the same problem.I went to ritz camera and was told to buy a new battery.I purchased battery and...
hi i was having the same problem with my polaroid camera my solution was that the bottom lid to the battery compartment was taped shut. and when it came loose i could only keep the camera on by holding the tape in place to keep it shut. now it works fine hope this helped some.
Jan 02, 2009 | Kodak Easyshare V1233 12.1MP Digital...
Help??
Here are some simple things to try first for a camera that won't power on. They won't work for every case, but they're worth a try:
http://camerarepair.blogspot.com/2007/11/simple-fix-for-dead-cameras-that-wont.html
If the above didn't work, then consider the following:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Apr 15, 2008 | Canon PowerShot A620 Digital Camera
HP Photosmart 935 Digital Camera Logo
80 people viewed this question
Top HP Cameras Experts
Fred Sops
teddyboy
Lawrence Oravetz
Are you a HP Camera Expert? Answer questions, earn points and help others
