Question about HP Officejet Pro L7580 All-In-One InkJet Printer
Quickbooks 2009 I printed 2 invoices, then when I print the next one it goes on defaults to 1. it should'nt do that... please help...
Cant email or print invoices error code -20
which versions you use
QuickBooks 2011 versions only
  1. Download and run the QuickBooks Print and PDF Repair Tool.
  2. Once the tool completes, try the .pdf file-related task that originally generated the error.
  3. If the error still occurs, please try rebooting your computer and then try again.
http://support.quickbooks.intuit.com/support/Articles/SLN40733
for more help step by step visit
QuickBooks Online Support
Jun 29, 2014 | Computers & Internet
Zero value invoices dont print description
According to Intuit it occur due to a default setting in preferences. for complete resolution follow Backordered items with zero quantity do not print on progress invoice and if need any help during this tutorial Intuit Tech Support .
Jan 23, 2014 | Intuit QuickBooks Pro 2007 Full Version...
We are a small company who just purchased QuickBooks Pro 2011. Have not entered the software as yet. Have a question regarding forms i.e. invoices, cheques,envelopes,etc. - Question: Does the software...
Hi ibeaton1484,
Invoices and other forms are built in the Quickbooks software and you can just simply print it on a plain sheet of paper. You can simply click on the print icon on top to print the invoice that you have created.
However, If you want pre-customized company sheets (invoice, envelopes) for your company you can order it directly from Intuit together with your checks.
Hope this answers your question.
Good Luck!
Mar 14, 2011 | Intuit QuickBooks Pro 2011 (License Only)
Im trying to print an invoice from Quickbooks but i cant find a online printer
Open QuickBooks. Then go to File at the top left side of the page. Then scroll down to set up printer. Choose the form you wish to be able to print in QuickBooks and this will take you to a place to choose your default printer. Click the arrow next to the name of the printer it has stored as default and choose your printer (hp photosmart) and then close the window and this will save your choices. Repeat the same procedure for each form name you wish to print in QuickBooks.
Jun 23, 2010 | HP Photosmart C3180 All-In-One InkJet...
Can't print reports can print checks and invoices
What is the error?
With QuickBooks open, go to "File" then "Printer Setup"
check the printer settings for "Reports".
Sounds like QuickBooks Reports is not defaulting to the
right printer.
Jan 26, 2010 | Intuit QuickBooks: Pro 2005 for PC
Quickbooks (2008 Premier) invoices sent to print
Hello
Thank you for using
FixYa for your problem
Can you try a different PDF creater
http://en.pdfforge.org/download
this I find to be very good and free
Please rate our solutions and if you still have problems please call back for more ideas to help you
Thanks
Richard Scott
Technical Support
New Zealand
Nov 19, 2009 | Intuit QuickBooks Pro 2007 Full Version...
Printing two of each invoice and estimate when only need one
when you go into PRINT check to see if you have 2 copies selected. Mine defaulted and was doing 2 of everything. including when sending PDF's
(PRINT - LOOK FOR HOW MANY COPIES)
Jul 17, 2009 | Intuit QuickBooks Pro 2007 Full Version...
Quickbooks Pro 2007 Printing Blank Invoices
Go 'Lists' and then open 'Templates', double click on the product invoice and make sure the invoice is 'Active'.
Qbooks saves printer settings for each feature, regardless of which is set as 'default' in Windows...be sure you have the correct printer selected.
If the above are set correctly, go to HP's website and download the latest driver for your printer.
Jul 13, 2009 | Intuit QuickBooks Pro 2007 Full Version...
When I try print invoices from my Quickbooks program, the printer seems confused printing large then small and all out of line
Which quickbooks are you using? Which platform (Vista, XP etc) If you have Vista, only QuickBooks 2008 and 2009 will work.
Feb 02, 2009 | Panasonic KX-P1150 Matrix Printer
HP Officejet Pro L7580 All-In-One InkJet Printer Logo
21 people viewed this question
Seeker5211
Seeker5211
