Question about Goodman GMS90703BXA Heater
Model GKS90703BXAA I believe the drain is hooked up wrong. I don't have instruction manual. When I opened up the fan and dumped the water the unit worked fine. How can I find out what is wrong with the drain?
  • 1,420 Answers
Here is a link to get your installation manual http://www.dnmech.com/furnace_info_older.html
It will describe how to hook up the condensate drain.
Good Luck
Posted on Dec 19, 2007
Frigidaire model FFRE1033SI window airconditioner tilt problem.
Water going outside is the important part. The hole is not necessarily the drain, the angle at most is an eyesore!
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Aug 19, 2017 | Frigidaire Heating & Cooling
Not making enough ice
What is the ambient air temperature in the location it is installed??
Aug 27, 2012 | Ice-O-Matic Ice o matic Iceu220a Cube Ice...
DU2100B: Looking for a repair/service manual for this. My problem is that the dishwasher will fill with water, then immediately drains. It rarely does a complete cycle without doing things out of...
I don't believe that a service manual exist i have included a image of the parts breakdown for the pump asm. and while taking look at it i believe the the drain solonoid is hanging up,or the drain flapper in the pump asm is hanging open The solonoid is shown is that image as item #5 it connects to the drain flapper shaft item #13 and the actual flapper is number is item #34 and has a sping thats suppose to close it item #35
one of those is staying open not allowing the water to stay in tub on wash cycle
http://www.searspartsdirect.com/partsdirect/part-model/Magic-chef-Parts/Dishwasher-Parts/Model-DU2100B/1429/0130000/X2905652/00006?blt=06&prst=0&shdMod=DU2100B
Good luck,i hope i have help you to figure out what is wrong with your dishwasher.
Gene
Aug 13, 2011 | Magic Chef Dishwashers
Hi i have km-320-mwh hoshizaki ice machine, this machine is discharging water in drain continuesly except when it is dumping ice is this normal ...too much water is being lost please help many thanks...
By looking at the model number it is a water cooled unit. It will dump water down the drain continuosly as that it how it cools the compressor. If it was a MAH it would be air cooled and no continuos dump of water.
Aug 09, 2011 | Hoshizaki Freezer Commercial Ice Machines...
Just given an older model delonghi portable air, when u open the front there is a container like thing, I don't have any instructions do I fill it up with water? or does that collect the compensation...
No need to fill that with water, it will collect the condensation on it's on. You will be required to drain it periodically, but the unit should let you know when that's needed.
If you can come up with a Model Number of it, I may be able to find an Owner's Manual.
Hope this helps you and thanks for choosing FixYa.
Jul 25, 2011 | Heating & Cooling
I lost the instructions and want to set up a direct drain, however, I don't remember what settings are what...ie fan, the hour glass thing, or how to set the house temperature...help!
Here is a link to the Owner's Manual for your model dehumidifier. You can download and print the manual for future reference. I would encourage you to keep it in a safe, accessible place, as your model has been discontinued. Which also, mean take good are of your unit and do routine maintenance on it. That will add to the longevity to it's use.
http://www.danby.ca/cms/uploads/products/en_manual/DDR586R%20EFOM.pdf
Hope this helps you get the constant drainage hooked up properly.
Jul 13, 2011 | Danby DDR586R Dehumidifier
Ice maker is not making ice and water leaks from bottom.
Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
Ice Maker
Is the freezer cold enough? Should be close to 10 degrees.
Is there water or ice in the ice mold? If not put water in it and see if it dumps the ice after it’s frozen. If there is ice, lift the cut off arm and let it drop to see if it will start.
If it does dump the ice but don’t refill with water.
Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze. You can take the water line off the valve and watch to see if it drips.
Sep 21, 2009 | Hotpoint HSS25GFP Side by Side...
Just replaced freezer fan a couple days ago. Now water leaking into top shelf of fridge. Could drain be clogged ? Frigidaire model FRT8S6ESBG.
Frozen drain
Ice maker water line and wiring
harness openings not sealed.
Seal water line and wiring harness
openings.
Drain trough not properly formed.
Ensure drain trough is at 90° angle to
back of freezer and that lip is up on front
and ends.
Divider (foam block) frozen.
Replace divider. Check drain trough.
Visit my site, I offer free help and model and parts number search feature. Movies and instruction manuals for most brands. seanreezehvac@yahoo.com click on link below, Thanks, Sea Breeze
http://servicepartstec.blogspot.com/
Apr 04, 2009 | Frigidaire FRT8S6ESB Stainless Steel Top...
Replacement
do you want it to be in repair, or you want it to replace...?
Jun 23, 2008 | Panasonic CW-1006FU Air Conditioner
Evapoative air conditioning
sounds like the flaot switch is stuck in the up position. this will be like the drain pan is always full of water. You may need to take the unit apart and check the flaot in order to reapir this problem.
Jan 24, 2008 | Heating & Cooling
Goodman GMS90703BXA Heater Logo
111 people viewed this question
Top Goodman Heating & Cooling Experts
Paul Carew
Dennis Boxerman
vance jones
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
