Yes if your phone do not detect any charger than you need to buy a new charger. because whenever you connect a charger, than the mobile displays "battery charging0"
i fell asleep and forgot to put my iphone on the charger and the battery died... i put it on the charger the next morning and it wouldnt charge or turn on. it just had the battery icon with a red line in it with the little bolt underneath. i let it sit on the charger for a few hours and still got nuthing..i thought i was gonna have to connect it to itunes and restore it and lose my jailbreak...but i didnt...i just put my iphone into dfu mode, then took it out of dfu mode and put it back on the charger. after a few minutes the iphone turned back on and i still had my jailbreak and everything. i jailbroke on jailbreakme.com a few weeks ago. i dont think that site is up anymore... hope this helps somebody :)
Yes! the video graphics card is usually built into the motherboard, from the description it took a high static charge in the main board and is causing cascade failures, I would consider a new computer.
You need to remove the battery and check it with some other phone. Otherwise check to see if there is a problem with the charger by charging another phone. Then you can find out the probleem is in which device.
Hi! My phone had exactly the same problem a few days ago! I got a new battery - it worked fine for a couple of days and here we go again... It is dead! Please let me know what you did with your phone! I have a new BB curve! Thank you!
my phone is the same model and did this but when i charged it, after about an hour it would come up with 'charging error stop ' and when i unplugged it, it hadn't even charged at all. and then the other day it just wouldnt charge, i plugged it in, it said it was charging but it wasnt. in the end, it worked by keeping the phone switched off and charging it while i was turned off. so try that, if not then i really dont know sorry
I didn't have the time to find out what was the problem cause i needed the camera immediately so i bought a new battery and a new charger.Thanks for the help!!
Do a master reset of the phone. Sounds like a software problem since both the usb and power jack not working.
Once the handset has rebooted to the Today Screen,
enter the following code: *2767*3855#. The handset should display a
message “Formatting- Please wait a moment”.
The phone will reboot after the Full Reset as this is normal operation.
