Question about Juki MO-644D Mechanical Sewing Machine
How do I thread my ddl-555? - Juki MO-644D Mechanical Sewing Machine
  • 46 Answers
Hi, email me & I will send you the machine manual and parts book. sewingmachines@gmail.com
Posted on Sep 19, 2009
    Brigadier General:
  • 3,513 Answers
Hi..
thread the upper looper first, then the lower looper. Next thread the needles. Always thread in this order.
Make sure you have the right needle for the thread you are using,and same thread is also in the bobbin.
. CHECK UPPER TENSION, BY PULLING SLIGHTLY, IF IT'S TIGHT, LOOSEN THE UPPER TENSION.your thread may be of the wrong size or chek the type of speed of your sewing, and the needle your are using.
thanks for contacting fixya.com
Posted on Sep 08, 2009
Hi I just purchased a used Juki DDL-555. 1) It will not catch the bobbin thread. 2) it will not sew forward and feed the fabric along (it sews in reverse just fine). Can someone please help?
the material movement is set by the forward/ reverse knob or lever
not picking up the thread can be needle thread tension too loose
it can be needle hook timing
Apr 20, 2017 | Juki Sewing Machines
Manual needed for juki ddl 555 also need bobbins for this machine
go to the Juki website and ask them about a manual and bobbins
Mar 15, 2015 | Juki Sewing Machines
I need a manual and a bobbin case for a new home model 764
http://www.sew4less.com/index.php
I don't know if the link will work for the bobbin case, if it doesn't
go to sew4less.com
Bobbin Case # 52237 NB, Click for model info.
p_4754_1148578825.jpg Product #: 4754
Price: $ 19.95
Bobbin Case # 52237 NB, No backlash type.
A bobbin case, also known as a bobbin holder or bobbin shuttle, holds the bobbin that is filled with thread.
Each machine has a specific bobbin case. # 52237NB
Brother 755 Brother B714 Brother B735 Brother DDL-227 Brother DDL-555 Brother DL-5550 Consew 103 Consew 104 Consew 210 Consew 230 Consew 231 Consew 7360R Consew 99 Consew CN 223OR Janome / New Home 764 Juki DDL-227-L Juki DDL-5530 Juki TL98E Kenquilt 622 Singer 1300 Class Singer 1400W Singer 188K Singer 191U Singer 195K Singer 196K Singer 241 Singer 245 Singer 251 Singer 281 Singer 291U and more!
here are is a site that have manual
http://www.sewingpartsonline.com/
Jun 09, 2012 | White Sewing Sewing Machines
What needle type is used for the juki ddl 555?
Regular sewing machine needles. Choose the needle type and size according to the type fabric or thread being used.
http://www.euronotions.com/pdf/Schmetz_Sales_Guide.pdf
Mar 18, 2010 | Juki DDL-8300
I have a Juki DDL-555. I think there is a problem with the timing. The thread on the top keeps coming out from the needle and in the bottom thread is loose and puckered. Some stiches are ok but most are...
Try putting the bobbin in the other way, you may have it backwards, also you have to pull the threads out at least 6-inches from the needle before you start sewing or the thread uptake lever can pull the thread out of the needle.
Mar 16, 2010 | Sewing Machines
How to fix timing on a juki ddl-555 sewing machine
Hi, if your ddl-555 sewing machine the needle doesn't grab the string from the top and bottom; and it can't sew the fabric. Do you know what to do/
Sep 14, 2009 | Juki DDL-8300
Juki Sewing machine DDL-555. After 4-5 hours use feed not moving
Sounds like as the machine builds up friction from extended use, some vital part is lacking lubrication and is seizing up. A good service person will remove ALL of the covers and thoroughly air clean and oil every moving part. Sometimes these dry points are hard to find and patience is required.
You can get a sewing machine oiler with a long applicator and put a drop of oil on anything that moves, but over oiling can be messy.
Jun 17, 2009 | Juki MO-644D Mechanical Sewing Machine
My thread is breaking when I'm sewing on my Juki DDL 555
MAKE SURE YOU HAVE THE RIGHT NEEDLE FOR THE THREAD YOU ARE USING, AND THAT THE SAME THREAD IS ALSO IN THE BOBBIN. CHECK UPPER TENSION, BY PULLING SLIGHTLY, IF IT'S TIGHT, LOOSEN THE UPPER TENSION.YOUR THREAD MAY BE THE WRONG SIZE OR TYPE FOR THE SPEED YOUR SEWING., and the needle your are using( sorry about the caps lock)
Oct 18, 2008 | Juki MO-644D Mechanical Sewing Machine
Juki MO-644D Mechanical Sewing Machine Logo
85 people viewed this question
Top Juki Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a Juki Sewing Machine Expert? Answer questions, earn points and help others
