Question about Samsung CLX 3160fn All-In-One Printer
We are trying to find out what does the following error message refers to on a Samsung CLX-3160FN MFP: Internal Error wer off/on 401548a03T 915 Had tried Samsung and other local Services Shops and nobody knows. Please help.
Samsung CLX-3160N Document jam Scanner Error
the printer samsung clx 3160nprinter to check the any papper part .to clear the papper jam then will be the adf scaner sencer hang.so you can change the adf paper senser or correct fix the senserliver. best wishes
Apr 05, 2013 | Samsung CLX 3160fn All-In-One Printer
My Samsung printer CLX 3160FN has an error message - Low Heat Error - Cycle Power. Is there any way I can fix it?
Probably you have damaged thermofuse in fusing section. It can be easily replaced with new one and it's very cheep and ordinary
pifonski
Feb 22, 2011 | Samsung CLX 3160fn All-In-One Printer
Transfer belt error samsung CLX-2160 help
The first thing to try is to turn the printer off, unplug it from the wall, then plug it back in and turn it on. If the error message goes away, you can resume normal operation. If the error message still appears, you'll have to call your service technician.
Feb 09, 2010 | Samsung CLX 3160fn All-In-One Printer
Internal Error WER OFF/ON DRAM_FUNC.C 58 R how to be?
samsung printer clx-3160fn error DRAM_Func.c 58 R wer off
Dec 21, 2009 | Samsung CLX 3160fn All-In-One Printer
Internal error with my xerox phaser 6110 MFP
I have tried all the tips but my problem remained so I took the front panel off then I unplugged the battery for one minute and then replugged the battery and reassembles the printer. After that it works and I don't have the problem back untill now. May be it's a bit risky but instead of discarding the whole printer I tried it. Just a little courage!
Sep 09, 2009 | Samsung CLX 3160fn All-In-One Printer
My Xerox Phaser 6110MFP got error "Internal Error WER OFF/ON DRAM-FUNC.C 58 R". Cannot get solution from any sites. Can't use printer. Please help, thanks. weichen81@msn.com
DRAM TEST
Use this feature to test the machine's DRAM. The result appears in the LCD display.
If all memory is working normally, the LCD shows << O K >>
Jul 04, 2009 | Samsung CLX 3160fn All-In-One Printer
Samsung clx-3160fn change image unit
Kindly take out the imaging unit out of the printer and take out and put it properly.
If this did not fix you may try using the imaging unit from other printer.
If this did not solve then visit a service center or buy its Imaging unit.
May 07, 2009 | Samsung CLX 3160fn All-In-One Printer
Deve Home sensor Error as occur cannot get printer to work
The web does not offer alot on this error. However the users manual indicates it is a fuser issue. Try a new maintenance kit. That should include the fuser and all rollers.
Dec 16, 2008 | Samsung CLX 3160fn All-In-One Printer
Internal Error DRAM-FUNC.c 58 R
Under warranty ring samsung to confirm, the error relates to comunication with the ram chip, probally not seated, but I think you might find in has a "in house" warranty which means they will come to you.
Dec 22, 2007 | Samsung CLX 3160fn All-In-One Printer
Internal Error 923 with Sending or Receiving Fax
I've just got my CLX-3160FN and found the same problems. Could go around the sending error, but can't receive faxes yet, always error 923.
Sending: make sure you press the "On Hook Dial" button before entering the recipient's number. Stupid, very stupid, but it's how it works.
Oct 12, 2007 | Samsung CLX 3160fn All-In-One Printer
Samsung CLX 3160fn All-In-One Printer Logo
358 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
