Question about HP 1010 Plain Paper Inkjet Fax
Transmition problem fax sends but only sends the image one inch in from each margin. possible that the optical reader is shot?
    Novelist:
  • 208 Answers
Yes. If you can print an internal report, but not copy or fax properly then the scanning unit is the problem
Posted on Dec 11, 2007
Whenever i send a fax, the machine confirms by viewing 'TRANSMITTING OK' but the addressee receives a blank document
Check the baud rate of your transmissions. Slow them down to the slowest setting and send a test fax to a helpful person. Slowly increase the baud rate (communication data speed) and send the fax test. When the fax doesn't show up on the receive site, then step one baud rate speed back, and save the setting.
It could also be your fax that is faulty, or even the receive sites fax, also being faulty.
To test your copy-head, insert a document into your loading section of the fax and press copy. If the copy prints out fine, then you know the head is reading correctly.
It is also possible that the receiver fax (the other end) has a printhead failure.
Nov 25, 2013 | Canon FAX-JX200
When I send a document the receiver gets a large image. I want the receiver to get a letter size image. How do I do this?
The image would have to be resized before sending to less than 8.5x11 inches. You will have to open the image and click resize.
Dec 30, 2009 | Sharp FO 4450 Laser Fax
When i send a fax they are really faint when recieved
This is an indication that the scanner or "optics" of you fax is dirty. It's just the opposite of what you would think...on many fax machines, dirty optics produce a light image on the reception machine.
Nov 17, 2009 | Office Equipment & Supplies
Okifax 5680 - transmit resolution issue
You can change the Transmit Resolution but not the resolution or the quality of the faxes received.
If your machine makes goog copies and prints, the problem is on the sender's side.
This is an excerpt from the troubleshooting section of your machine manual:
The image received on your fax machine was very poor. Contact the person sending you the fax and ask them to change their Transmit Resolution and Type of Original settings. Ask the person to make a copy of the document on their fax machine to ensure that it is working properly. Then ask them to send the fax again. If you still have a problem, try making a copy of a document on your machine to make sure it is working properly
Aug 14, 2009 | OKIFAX 5680 Led Printer
Ricoh fax 2050L displays: "Check paper size", and also shifts image or text toward bottom margin by 3 inches or so. Sometimes locks up during printout.
Thru user tools check what size is said to be in the fax and if it has the optional tray that size too. -Carl
Apr 14, 2009 | Ricoh 2050L Laser Fax
Printing Borderless at 42" width?
Set the roll size to 44 inch, set your left margin to 0 (in your preprint software), experiment. With margins set at 0, using Onyx Productionhouse 7.3, the 9800 will print approx 41.8 inch image on 42 inch roll 43.8 on 44, etc. This is considered borderless printing. No matter what size roll you tell the printer it has in it, it will print to about an eighth to a sixteenth of an inch short of the paper's actual edge (that's the left side of the roll paper coming out of the printer - the right side of the print). If you load, for example, a 36 inch roll, tell the printer its a 44 inch roll, and send a 40 inch wide print, with a left margin of 0 it will print around 35.8 inches, cutting off the image just before it would overprint and get ink on the machine (1/8 - 1/16inch before the edge of your 36 inch stock). It is possible that these tollerances will be different depending on what software you send your images with... hope this helps!
May 08, 2008 | Epson Stylus Pro 9800 InkJet Printer
Fax question
You want a TX (transmit) Report. You can have the report printed after each fax is transmitted, including the first page of the fax sent if desired. Follow these steps to turn on the report.
1. Press Menu button
2. Use (left or right) arrows to FAX SETTINGS, press Set button
3. Use arrows to REPORT SETTINGS, press Set button
4. Use arrows to TX REPORT (may be there already), press Set button
5. Use arrows to OUTPUT YES, press Set button
6. If screen says REPORT WITH TX IMAGE, press Set button
7. Use arrows to ON or OFF, as desired, press Set button
8. Press Stop/Reset to exit the menu
May 05, 2008 | Canon FAXPHONE L170 Plain Paper Laser
Canon CFX-L4000
suggestion...the modem is shot! OR remove modem, shut MFC down, install modem, restart. sounds like it has a hair ball.
Jan 19, 2007 | Canon CFX-L4000 Plain Paper Laser Fax
HP 1010 Plain Paper Inkjet Fax Logo
mukhtar21 shaikh
mukhtar21 shaikh
