Question about HP DeskJet 6122 InkJet Printer
I have replaced both ink cartridges & black is not printing well
I've replaced both the color & black ink cartridge (the black I've replaced twice). Color is printing well, but black is not printing clearly. I've cleaned the cartridges and I'm not seeing much of an improvement.
Why won't a new tri-color cartridge print red?
Tri color cartridge contains Cyan,Magenta & Yellow color inks, mono cartridge contain black ink, combination/mixing with these inks desired color out put will prints on paper.. If any one or more inks are missing/dried, result mis matched print outs on paper.
In your case I feel it's Magenta ink is not firing..,nozzles may clogged, try to clean the nozzles with solvents & try it...If no result ,. replace the color cartridge..
Mar 28, 2015 | HP PSC 1315 All-In-One InkJet Printer
When I print from the internet my copy prints my color comes out a different color I think it might be my black ink is off I have a dell 946 all-in-one printer.
Are you using Dell Series 5 ink cartridges?
Can you copy a document under the glass? Black & White and color? Do they look ok?
If you unplug the printer from the wall and remove the power brick for 60 seconds, this will reset any error messages the printer has. I would then plug everything back in.
Power on the printer.
Open the printer(with the power on) and take out the Dell Series 5 black cartridge and then reseat it. I would then take out the color Dell Series 5 ink cartridge and reseat it. Now close the printer and it will print an alignment page.
Any error messages?
black cartridge = black side(left side) color cartridge = color side(right side)
photo cartridge = black side(left side) color cartridge = color side(right side)
Dell Series 5 ink cartridges have a sensor in them that cannot be reset. Article on refilling Dell ink cartridges .
Dell Series 5 ink cartridges can be purchased at Staples, Walmart or Dell's Website.
It's possible to get a Dell Series 5 ink cartridge with a bad sensor. I would that these back to the place of purchase for a replacement or a refund.
Rick
Jul 27, 2011 | Dell 946 All-In-One InkJet Printer
Printer won't print B&W even though black cartridge is full but 2 colours are empty.
Although you are only trying to print a B & W picture, the color print cartridge/cartridges must also contain ink in order for the printer to work. All print cartridges must contain ink for printing of any type to take place.
Load the color print cartridges and the B & W picture will print.
If you were trying to print a color picture and the B & W cartridge was empty, the printer also, would not print.
I hope this helps you out.
Good Luck
Jan 25, 2011 | Office Equipment & Supplies
Why can't I print black and white, without colored ink?
I have the same problem & have been searching for weeks for a replacement printer that will print B & W with one or more colors empty. I haven't had any luck yet - I did run across a post that said: For black and white images and photos, a blend of colors called "composite black" may be used to achieve significantly better image quality and smoother gray tones than can be accomplished with black inks alone. I'm still searching...
Jul 28, 2010 | Epson Stylus CX5000 InkJet Photo Printer
Error message that color cartridge has low ink, so printer won't print. How do I override this? This message occurs when only one color is low and requires replacing the entire cartridge.
No way 2 override the message. Printer works on a combination of both black and color ink to print those perfect pictures and documents. If it is showing color ink needs replacement,you ve 2 change it in order to print even in black and white.
Jan 13, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
Can printer print with one cartridge only?
Аs far as I remember this printer can printing with only one cartridge inside it.Just pull out the color cartridge and try print in black only mode.
Nov 10, 2009 | HP DeskJet 5150 InkJet Printer
Changing the black cartridge also require change of color
The printer is very good.I ve been using it for approx 1 year now.The printer works on a combination of both black as well as colour ink cartridges.If any of the cartridge is empty,printer will not print.Kindly call Kodak with your problems at 1800 421 6699 and they will take care of the issue for you.
Oct 04, 2009 | Kodak ESP 5 Printer
Lexmark 2500 printer won't print after replacing black cartridge
Unfortunately the printer wont print unless there is ink in both cartridges
Jan 01, 2009 | Lexmark All-in-One Printer with PictBridge
Not printing after color cartridge ran out - new black cartridge installed.
Yes, this printer has fixed printheads and must have ink in each color to prevent damage to the printheads. Even when printing black only each color is spit in the servicing area to keep the printhead unclogged.
Regards,
Bob Headrick, Microsoft MVP Printing/Imaging
Jul 18, 2008 | Epson Stylus C60 InkJet Printer
Cartridge error
How I solved this problem was, I took out the color cartridge (which seem to be the one giving the error message) and worked only with the black ink (and chose print black and white )
My color ink cartridge had been refilled at Walgreens. The Black ink cartridge is an original Lexmark
Oct 22, 2007 | Lexmark X3480 InkJet Printer
HP DeskJet 6122 InkJet Printer Logo
383 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
