Question about Kitchen Ranges
I have 2 marco fireplaces model #'s dwf41cf-3 and dwf36cf-3. I am rebuilding the mantle and putting moulding around the surrounding area and need to know the codes relating to how close the mantel and wood work can be to the box.
  • rswoodbury Sep 08, 2009
    I called our building department and they said that manufacture's specs take precidence over code, in fact, for our city, that is code. They want me to find the owner manuels'. Marco no longer has an active web site, and that is why I went to fix it as a source.
  • 15,935 Answers
The simple answer is that clearances are set by local building code, which is enforced by your local building department.
Call them and ask to speak with a building inspector; he/she can tell you minimum clearances over the phone.
Generally: Minimum firebox clearances for noncombustibles. 16" from firebox opening all around. Hearth (floor) minimum 20" forward of firebox and 8" minimum out from sides of firebox.
CLICK HERE for a visual guide for Mantles.
It depends how far the mantle sticks out from the wall.
Your particular city may have different ordinances and codes pertaining to the Surround and mantle.... especially in older cities. Check with them for your exact numbers.
Thanks for using FixYa!!
Posted on Sep 08, 2009
  • blueextc3221
    blueextc3221 Sep 08, 2009
    This is the contact info for Marco
    CLICK HERE
    You can use THIS PDF guide from a different manufacturer to get the number you need.
    Look near the bottom (page 18) for insert clearances for combustables.
    Thanks
Need manual for marco fireplace model MH 9245
This company is out of business due to massive government recall. I could not find a manual online for you.
CPSC Marco Alert Consumers to Gas Fireplace Recall Due to Fire Hazard
Nov 17, 2016 | Heating & Cooling
How to put the mantel and flue parts back on in the fireplace
Fireplace and Chimney Parts: Diagram and Anatomy
https://www.highschimney.com/.../parts-chimney-anatomy-fireplace-chi...
Nov 30, 2011 - A chimney is made up of up to 22 parts. ... Mantle - Also known asmantel piece or mantel shelf, this piece of hardware is more than a .... I have an old Blaze King Fireplace Insert that was purchased back in the mid 1980's.
How to install a wood burning fireplace insert - Hearth.com
www.hearth.com/econtent/index.php/articles/install_insert
A Heatform is a metal firebox which is built into a full masonry chimney. ... The distance to the adjacent wood trim and the mantle. ... All the way back in the fireplace, or out on the hearth? ... Rockford Chimney Supply - We are the best source forChimney liners and Stainless steel chimney liner kits to install your insert or ...
Dec 20, 2015 | Heating & Cooling
Where is the thermocuple on my marco gas fireplace
Fireplace Pilot Light Tutorial - YouTube
? 5:06
https://www.youtube.com/watch?v=Moa7eGlKCr4
Nov 12, 2012 - Uploaded by FogoFox
This video walks you through the process of turning on the gas to your fireplace, lighting ... Lighting a Gas ...
The thermocouple compared to the thermopile. - YouTube
? 6:01
https://www.youtube.com/watch?v=dRjX5m0zHUU
Oct 16, 2013 - Uploaded by grayfurnaceman
I got an 1980 gas fireplace, I just see the pilot and something that look more ... My land lord purchased a ...
Marco Natural Gas Fireplace (Model B36CFI) won't turn on ...
Download MARCO GAS FIREPLACE MANUAL PDF ...
? 0:16
https://www.youtube.com/watch?v=lJyHdPywr0M
Jul 31, 2015 - Uploaded by Roscoe Sikes
Download MARCO GAS FIREPLACE MANUAL PDF ... How to Safely Light Your Pilot on Your Gas Fireplace ...
Dec 07, 2015 | Heating & Cooling
New Valor Petrus electric top of fire, plus granite surround plus fire surround mantle get very hot, room does not. 's this a fault
If it doesn't have a blower, you may need to install a blower kit. It sounds like you need some air circulation in the room.
Jan 08, 2015 | Home
Is the Marco Fireplace 7792778E a fireplace or a fireplace insert?
Apparently the Manufacturer is out of business but there is a MARCO Distribution company. Call them for info since internet searches are failing.
call Marco Fireplace Distribution at 818 764 3366
Jan 02, 2015 | Heating & Cooling
Yes, i can seem to get an answer on weather my Marco fireplace model # 7927740 can burn gas or wood. I was told it could do both?
The best answer would be to contact Marco or their distributer directly. I have never seen a fireplace that would burn both. I have seen dual-fuel central heating furnaces.
I would not attempt burning wood without input from Marco.
Nov 19, 2014 | Heating & Cooling
I have a gaz fireplace Marco DWF36CF-3 vented and would like to know if i can burn wood in it
My name is mike. YOU DO NOT want to attempt to burn wood in a gas fireplace. The reason for it, is the venting is not designed for the fumes and high heat the wood produces. Only way you can safely burn wood, in a gas fireplace is have to make sure the piping and venting is set up correct to burn wood. Your problem is not most likely your stove or fireplace for the safety, it would be your venting. Thanks Mike
Oct 22, 2011 | Heating & Cooling
Marco gas firplace
I have a Model 792864B. Before you attempt to light the pilot light - make sure that any wall control switch or remote control for the fireplace is in the off position. Locate the gas supply line. There should be a gas supply valve to turn on the gas supply. The valve is usually painted a different color than the supply line like blue, green or yellow. Open the valve by pivoting the handle to be parallel to the gas line, usually counter-clockwise. When it is closed it is at a 90 degree angle from the supply line. Locate the pilot light assembly - this is the pilot light. There should also be a red or black ignitor button and a black or green valve control knob with the words "on" "off" and "pilot" on it. It may be located inside a black box, mine is marked heatolator, that has a lift off top. Lift off the top of the box. Push in the valve control knob and turn it until the word "pilot" is in line with the arrow (my arrow is red) or indicator line. While pressing and holding in the valve control knob - it presses in about 1/4", press the red or black ignitor button repeatedly (once per second) until the pilot ignites. Once the pilot is lit, continue to hold the valve knob in for about 30 seconds and then slowly release. The pilot should remain lit. If it remains lit, press in and turn the valve control knob to the "on" position. The on/off wall or remote control switch should now light your fireplace. If the pilot doesn't ignite, turn off gas supply valve, wait about 5 minutes and try it again.
Nov 20, 2007 | Leisure HOMEPRIDE Electric Fireplace...
Kitchen Ranges Logo
126 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
