ACER SCREEN IS BLACK BUT CAN FAINTLY SEE LOG IN BOX
MY ACER ASPIRE 5610z SCREEN IS BLACK. THE LOG IN BOX CAN BE SEEN BUT VERY FAINTLY!
ANY HELP WOULD BE GREAT!
thanks
  • Wingking13 Oct 25, 2008
    Monitor starts off black and then slowly comes on. Have to keep lights out for a while. It starts from left to right brightening till it works again. Im sure it will die soon for good...
  • 27 Answers
Sounds like the backlight for the LCD is dead, either the light itself or the power inverter. If you're not a tech, you should take it in for repair. If you are a tech, you can usually find replacement lamps and inverters on EBay. Hope this helps.
-kinerf
Posted on Dec 09, 2007
How to brighten screen of laptop acer aspire 5610z without keybord ?
May be there is any facility in control panel depends upon the video driver
Jul 20, 2012 | Acer Aspire One PC Notebook
ACER screen goes black after a few minutes of being on. I then close the laptop then log on again and the screen comes on then flickers off back to black, can very faintly see the desktop in the back...
Hi. This might be an LCD issue or connector inside th LCD from the motherboard is loose. You may try troubleshooting the issue first before you send the computer for repair. This process will drain the remain electrostatic energy to your motherboard which sometime causing the issue. Please follow troubleshooting steps below.
Take out the battery and unplugged the power adapter
Press and hold the pwoer buttong for 30 secs
Put everything back in
Power ON the computer
have a good one!
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
Jul 29, 2010 | Aspire Acer 7520-5071 Notebook
I have a acer 5610z, downgraded from vista to xp pro. Camera does not work, and ethernet shows errors. Seen alot of people with same problems on blogs, but saw no cures. Is there current drivers that do...
There is driver support for that model of Acer for the 32bit version of Vista.
They can be located from their support site here:
http://support.acer.com/drivers_download.aspx
Choose Notebook>Aspire>5610Z and that will get you to the driver list then choose Vista version you have.
Robert from Blitware
Jun 22, 2010 | Acer Aspire 5610 Notebook
Acer Aspire 5610Z. Upgraded to Win 7. Screen resolution changes
Your laptop was not designed to run windows 7 or be compatible with it. It may run fine with windows 7 but issues might come up sooner or later like the one you're experiencing.
[EXPERIMENTAL]
Download both of these (as I don't know which one of thsese two your laptop needs). Keep mind that doing the following could render your system inoperable and use at own risk. When downloaded, extract ZIP , open desired folder and find SETUP or INSTALL program. Right click and choose properties, then navigate to compatibility mode, then select windows Vista from the menu. Then apply changes, ok and close window and attempt to start.
Acer Aspire 5610Z VGA Intel Driver Vista
Acer Aspire 5610Z VGA NVIDIA Driver Vista
May 27, 2010 | Acer Computers & Internet
MY ACER 5610Z LAPTOP STARTS UP BUT WONT LOAD WINDOWS
WIth the limited fault description its a guess at best. you probably have a corrupted driver or hard disk fault. If you can try a replacement hard drive and reload OS you should get progress.
Sep 29, 2009 | Acer Aspire 5610-4648 Notebook
Acer aspire 5610z blank screen after power up...
Is it a black screen with a cursor?
turn on the monitor.
Jul 13, 2009 | Acer Aspire 5610-4648 Notebook
ACER ASPIRE 5610z BLACK SCREEN
You could have a defective screen - follow this to determine the fault.
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
Apr 19, 2009 | Acer Aspire 6930-6771 Laptop
Fix Acer Aspire 5610z Laptop Screen
you need a new screen!!! www.computereworld.com I can fix this for $170 total, that is a new screen and the labor. submit a request on my site, or call me 662-549-2362
Jan 08, 2009 | Acer Aspire 5610-4648 Notebook
Computers & Internet Logo
1,097 people viewed this question
Alun Cox
David Payne
David Payne
