Question about Dewalt Air Tools & Compressors
I have an egmlo AM 80 wheelbaro 1.75, 115v, 18 amp compressor. Do you know where I can get manual/partslist for this. Cannot even find reference made to this model. Dale
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 141 Answers
You may be able to get some information from Jenny Product Inc. They took over the Emglo line from Dewalt in 2003. They may be able to get you a manual and a partslist. The contact for Jenny Product Inc. is :
Jenny Products, Inc.
850 North Pleasant Avenue Somerset, PA 15501-1069
Phone 814-445-3400 Fax 814-445-2280
www.jennyproductsinc.com
Posted on Sep 14, 2009
Testimonial: "thanks for the advice."
Looking for manual for sanborn B51-A24-80V1 model
PDF]Sanborn Black Max 5hp Air Compressor Manual B51 A24 80 1
intrigante35hindu.strictlyyouth.org/rzsatzo_sanborn-black-max-5hp-air-...
Jul 16, 2015 - Sanborn Black Max 5hp Air Compressor Manual B51 A24 80 1 ... Black Max Portable Air Compressor - 5 gallon Item #: 81527 ' Model #: BS0880504 ...Compressor Manual: $4.95: Buy Now: B51-AT24-80V,B51-A24-80V1.
Aug 28, 2015 | Air Tools & Compressors
Can I get 80 psi with dials set at 40 psi
this compressor should be able to fill your tires to 80 psi. Look for a pressure switch and adjust it so the motor shuts off at a higher pressure. Do not exceed 100 psi.
Sep 08, 2014 | Air Tools & Compressors
Need a manual for 80 gallon 4hp husky air compressor model hs7810
Go to the Campbell-Hausfeld website at http://www.chpower.com/, under the 'Service & Support' tab select 'Manuals/Parts List'. Search for your model number and you'll be presented with the parts lists and manuals for that line of compressors.
Feb 28, 2013 | Air Tools & Compressors
I dnt hve my owners manual and I need to know wht fuse and relay is connected to my compressor. Please help. 2007 sebring
i assume you are refering to you a/c compressor .----- the fuse covers under the hood & on driver's side dash should have a listing on the back side , if you don't have the covers try checking for a repair manual at your library . these fuse & relays don't normaly go bad unless the compressor is bad or a short in wires . if you a/c does't work at all it's probaly low on freon charge, there is cut-off swithes built in to the system so the compressor does't run with out lubercation that is carryed by the freon.
Jun 05, 2011 | Air Tools & Compressors
I have a craftsman oiless air compressor. All tools that I attach have low pressure to start. After I hold the attachment wide open for about 10 seconds, it will eventually break loose and the air flows...
check your hose or couplers for restiction --------- try exchaging with know good ones------- the rubber seal in the female coupler may be the culprit ------------torn// deteriated// comming apart & blocking off air flow....
May 25, 2011 | Craftsman Air Tools & Compressors
Unit powers up, fans run, no compressor start
If the fans run we know it aint the defrost timer and you are getting power to the compressor so that means you have a wire done burned off one of the compressor terminals hopefully or ya might need a compressor. Probably just a burnt wire. These are pretty tough units. Diagram and run info
Partslist
Jan 31, 2011 | Delfield 406 / 406-CA Refrigerator
Where is the a.i.r. pump located
The air pump for the secondary air system (emission control device) is located under the battery. If you do replace it, replace the check valve too, it is on top of the exhaust manifold and connected to the pump with a hose. The check valve fails and ruins the pump. Source(s): http://repairpal.com/volvo-850-1997/comm…
http://repairpal.com/air-pump-check-valv…
OR
I think they are talking about the pump to provide vacuum to the climate control when the turbo is putting boost in the intake manifold. The vacuum can come from an electric pump or from an engine driven pump, something like an old engine driven fuel pump. I needed an electric pump for my 765T, and all the wrecking yards wanted to sell me the engine driven form. (A new one was $500, and it wasn't that important to me.)
An engine that takes the engine driven pump will have a hole in it while the others will not have a hole. Source(s): 35 years maintaining my own cars, including 17 years with a 1985 765T
OR
Rear Suspension Leveling Air Compressor
RH front of vehicle, attached beneath the fascia
Rear Suspension Leveling Air Compressor Relay K19
Lower I/P, to the RH side of the steering column, on the relay box
Automatic Level Control System Operation Check
Support the rear wheels or support the rear lower control arms when certain tests require raising the vehicle on a hoist. Use two additional jack stands in order to support the rear lower control arms in the normal curb weight position when a frame type hoist is used. Refer to Trim Height Specifications in Suspension General Diagnosis.
Refer to ALC Suspension System Check for electrical troubleshooting of the Automatic Level Control (ALC) system, or if DTC's are present.
Diagnosing Leveling Complaints Without DTCs Present Procedure
Perform the following preliminary inspections before performing the system performance test:
Inspect the ignition (pin A & pin H) at the ALC sensor connector.
Ensure that the ignition (pin A & pin H) at the ALC sensor connector connection is secure.
Inspect the ground (pin E) at the ALC sensor connector.
Ensure that the ground (pin E) at the ALC sensor connector connection is secure.
Inspect the ALC sensor link.
Ensure that the ALC sensor link is properly secured to the actuator arm.
Inspect the ALC sensor actuator arm for damage.
ALC Diagnosis Table Step
Action
Value(s)
Yes
No
Has the ALC compressor assembly and the air tube been replaced?
Go to Step 7
Go to Step 2
Raise and support the vehicle. Lifting and Jacking the Vehicle in General Information.
Inspect the air tubes running from the ALC compressor to both rear shock absorbers.
Inspect the air tube connection at the ALC air dryer.
Are the air tubes damaged and/or disconnected?
Go to Step 13
Go to Step 3
Squeeze the left rear shock absorber in the middle of the air sleeve.
Did the air sleeve slightly compress?
Go to Step 5
Go to Step 4
Operate the ALC system for 60 seconds.
Test the air tube-to-air dryer connection for leaks using a soap bubble solution.
Is a leak evident?
Go to Step 20
Go to Step 5
5
Disconnect the air tube from the ALC dryer.
Connect the Pressure Gauge to the ALC dryer.
Close the toggle valve on the Pressure Gauge .
Operate the ALC compressor.
Did the pressure build to the specified value?
80 psi
Go to Step 6
Go to Step 10
6
Shut off the compressor when the pressure reaches 80 psi.
Monitor the gauge for 1 minute.
Did the pressure leak down?
Go to Step 10
Go to Step 7
7
Connect the Pressure Gauge to the right rear shock absorber. Ensure that the toggle valve on the Pressure Gauge is away from the shock absorber.
Close the toggle valve.
Pressurize the shock absorber at the toggle valve on the Pressure Gauge to 80 psi.
Did the system leak down?
Go to Step 11
Go to Step 8
8
Use the toggle valve on the Pressure Gauge in order to slowly release the air pressure.
Disconnect the Pressure Gauge from the right rear shock absorber.
Connect the Pressure Gauge to the left rear shock absorber.
Pressurize the Pressure Gauge to 80 psi.
Go to Step 12
Go to Step 9
9
Disconnect the Pressure Gauge from the left rear shock absorber.
Connect the Pressure Gauge , inline, at the tee near the rear of the vehicle.
Reconnect the air tube to the ALC dryer.
Open the toggle valve on thePressure Gauge .
Using shop air, pressurize the system to 80 psi at the service connection of the Pressure Gauge .
Monitor the pressure gauge for 1 minute.
Go to Step 14
Go to Step 20
10
Replace the following components:
• Replace the ALC compressor. Refer to Air Compressor Replacement .
• Replace the air tube. Refer to Air Tube Replacement .
Are the replacements complete?
Go to Step 20
11
Slowly open the toggle valve on the Pressure Gauge in order to relieve the air pressure.
Replace the right rear shock absorber. Refer to Shock Absorber Replacement in Rear Suspension.
Reconnect all of the air tube connections.
Is the shock absorber replaced, and are all of the air tube connections reconnected?
Go to Step 20
12
Replace the left rear shock absorber. Refer to Shock Absorber Replacement in Rear Suspension.
Go to Step 20
13
Are any of the air tubes damaged?
Go to Step 14
Go to Step 18
14
Replace the air tube that runs from the air dryer to the two rear shock absorbers.
Is the replacement complete?
Go to Step 15
15
Remove the ALC air dryer from the compressor assembly.
Shake the ALC air dryer with the head connection down.
Did water/moisture come out of the ALC air dryer when the dryer was shaken?
Go to Step 16
Go to Step 17
16
Replace the ALC air dryer. Refer to Automatic Level Control Air Dryer Replacement .
Go to Step 17
17
Replace the air compressor head. Refer to Automatic Level Control Air Compressor Head Replacement .
Go to Step 18
18
Install the ALC compressor on the vehicle.
Is the ALC compressor reinstalled, and are all of the air tube connections reconnected?
Go to Step 20
19
Repair the air tube-to-air dryer connection leak.
Is the repair complete?
Go to Step 20
20
Reconnect all of the connectors that were disconnected.
Reconnect all of the components that were removed.
Clear all of the codes with the ignition ON and with the engine OFF.
Wait at least 5 minutes.
Is the rear of the vehicle trim level?
System OK
Aug 04, 2010 | 1998 Cadillac Catera
Pls solve this question
Mass of 18 is 80; Mass of 12 is 40.
Solution is
1) M18+M12=M16, given as 120
2) Mg16=16.24x120=80
3).75M18+.5M12=80
(mult by -2)
4)-1.5M18-m12=-160
(adding 1 and 4)
5)-.5M18=-40
6) M18=80
(substituting into 1)
7) M12=40
Jun 18, 2009 | Computers & Internet
Wiring installation for ss5l5 IR 5hp 60 gallon compressor
A #10AWG wire can be use and 40Amp breaker can be use also. Your 5hp/230V/1/60hz motor amp is 30A.
May 30, 2009 | Ingersoll Rand SS5L5 Ir Electric...
Screen display for nikon d80
Hi kathryn i also have a Nikon d-80 that i just purcased, and i too would like to know how to use that feature I din't even know that it had this feature so i called Nikon and they told me that the Nikon D-80 doesn't have what is called "live View." so i hope this answers your question. FOSHEEZY.
Jan 11, 2009 | Nikon D80 Digital Camera with 18-135mm...
Air Tools & Compressors Logo
183 people viewed this question
Top Dewalt Air Tools & Compressors Experts
John Trevino
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Dewalt Air Tool and Compressor Expert? Answer questions, earn points and help others
