Hp 4000n I continously get the 41.3 error unexpected paper size driving me crazy......HELP
  • john_barton Jan 22, 2009
    Unexpected paper sixe in tray 2, how to correct?
  • 34 Answers
Most common cause for 41.3....make sure the paper is completely up to the front of the paper tray. Right under the left and right metal clips. If it is not, adjust the block in the back of the paper tray so that the paper is fully forward.
If that does not get it you need a PAPER SIZE board installed. Easy repair.
Posted on Mar 12, 2009
The knobs on the paper size PCA is defective, or may need a little cleaning with some CRC. This board is located behind the formatter board.
Posted on Oct 14, 2008
  • 1,113 Answers
Page size of doc getting sent to printer, file, page settup, page size/papersize is set different than printers tray size via keyboard on printer, ie tray size.
Posted on Dec 09, 2007
Unexpected paper size message
go to the printer preference settings and change the paper size to A4 if you are using A4 and paper type to plain paper. and do the same on the printers settings menu.
Nov 12, 2013 | HP LaserJet 4050n Printer
What is 41.3 paper error on the hp laser jet4plus printer
41.3 is paper error on hp laserjet 4 plus is an unexpected paper size error. Check your paper guide settings.
Jul 12, 2011 | Office Equipment & Supplies
I have a HP 4000n printer and want it to print from tray 3 when tray 2 is empty. It doesn't do that now.
I don't have a 4000n, but I do have a 4200n that should be relatively similar. On the 4200n you can change this behavior by going to the menu, then Configure Device->System Setup->Tray Behavior->Use Requested Tray, then setting that value to First. My guess is you have that setting on your 4000n set to Exclusively, which will then prevent the job from going to a different tray. It also requires that you have the same type and size of paper registered in both trays if you want the job to automatically switch over.
If that menu path is different on your 4000n you just need to dig around in that menu to find the tray behavior setting.
Jun 09, 2011 | HP LaserJet 4000n Printer
Hp 4000N 41.3 unexpected paper size
Clean the sep. rollers one in the paper tray and one inside the paper tray port. Then clean the feed roller. Its behind the sep roller in the paper tray port. You must look close with a flash light. It has 4 D feed rollers. It will rotate down to clean them do not knock the spring off. Use only water on a cloth no alcohol. Steven 818-888-0006
Mar 11, 2010 | HP Office Equipment & Supplies
Unexpected Paper Size error while printing a3 size paper on HP 9300 deskjet printer
Although you have selected the paper size A3 your printer HP Deskjet show unexpected paper size.....
1. clean the carriage area ...........
2. change the carriage sensor....... If not solved
3. you need to replace carriage unit.
Oct 26, 2009 | HP Deskjet 9300 C8136A Printer
I have a Hp Laserjet 4000n printer. Whenever i try to print the paper is printed but it does not come out and is jammed under the catridge and it displays error 13.5 all the time. can someone please help...
It sounds like the fuser roller is not turning.
Remove two small caps, unscrew the fuser fuser and remove it.
Rough up the red roller with Scotch Brite
Oil the black bearings on the top roller.
Jul 11, 2009 | HP LaserJet 4000n Printer
Hp laser 4000 keeps coming up w/ 41.5 error
41.5 is a paper feed error, take out the paper tray and clean the rubber roller above where the paper goes with a cloth just damp with water. Dirt on that roller will stop it from picking up the paper.
Jul 09, 2009 | HP LaserJet 4000n Printer
Hp lj 4700 with error 41.3 unexpected paper size
Take the paper off and place the correct paper size.
If the setting is in A4 paper size please place the A4 size paper.
Jun 17, 2009 | Office Equipment & Supplies
hi ray, it's chris. i called your cell phone, but figured you might see this. replace the registration clutch. after some research, this seems to be the solution given that should solve the issue in that printer, and it's an independant part from the paper pickup assembly...
May 27, 2009 | HP Color LaserJet 3500 Printer
I have an HP 6310 all in one. I am trying to send a fax, when I hit teh number 7, a star 41 appears after the 7, I think have to hit cancel and a color report prints
Error *41 is a wrong paper size or type error. Make sure that you have chosen the correct paper size and type in the printer configuration. Easiest way to get there is through any application going FILE > PRINT > Configure.
Dec 09, 2008 | HP OfficeJet 6110 All-In-One InkJet...
413 people viewed this question
