Question about Epson Stylus Photo RX620 All-In-One InkJet Printer
I have an epson rx620 paper feeding problem
I have an epson rx620 and the other day it showed a paper jam. there was not paper jamed in there and so i ran a piece of light card board through the paper feeder and it pushed a leaf out. (Don't ask me how that got there.) I ran the card board through one more time and it jamed half way through and so i pulled it out the back way, not knowing that that was a no no. Now if you try to print something, the paper starts to pull in as usual but goes too far and stops for a bit and then continues all of the way through with out printing on it. After that the screen will show paper out or feeding error please insert paper and press the color button. How do i reset this paper feed function, or is it now broke???
Thanks
Scott
My Epson R230x printer get paper james and not feed paper, how can I solve or repair this problem
i want to know. printer back side some gape i see. but i don't know which work do in this back side.
Nov 04, 2012 | Epson STYLUS R230 InkJet Photo Printer
Epson Photo RX510
Hi when you switch it on have you tried holding down the on off button for about 10 seconds as this often resets most printers.
Also when you sya thier is no paper jammed in printer are you absolutely sure their is not even i tiny bit of paper still stuck as it only takes a tiny bit of paper to make this message appear.
If you are confident in removing the paper feed witch is difficult to do as you need to make sure it goes back perfect as if it isnt the paper wont feed.
Alot of people say their is no paper jammedand they call somebody out to repair the printer and they get charged a fortune for removing a tiny bit of paper.
If holding the button down dont work then try switching the plug on whilst holding down the on off button let me know how you get on ok
Dec 10, 2007 | Epson RX620 All-In-One InkJet Photo...
Tip
RX620 Paper Feed Fix
You can fix this problem by looking down into the paper feed area and you'll see a gray rubber wheel which is used to pull the paper through. I put my hand into a sock and soaked the end of the sock in rubbing alcohol so my middle finger could both rotate the rubber wheel and wipe off the fine, almost powdery paper residue.
The wheel just needs to be cleaned so the rubber grips and pulls one sheet at time instead of 3 or 4 and then jamming.
I use matte finish paper often so the wheel gets dusted and needs cleaning every 100 sheets or less.
Epson support never offered this advise. They told me to buy Epson paper and see if it works better. By the way, this is the 3rd refurbished printer as they all had the same problem until I figured this out.
on Apr 22, 2008 | Epson RX620 All-In-One InkJet Photo...
IF PAPER HAS NOT JAMED BUT MACHINE ARE SHOW PAPER JAMED
Try cleaning the rubber paper feed rollers. If it fails to pick up the paper in a pre determined time it will show paper jam. The pick up tires must pick up paper when turning, if not the paper will not feed into the machine and it will show paper jam with no jammed paper.
Mar 16, 2011 | Canon imageRUNNER 400S Copier
Get Print error occured on screen,sounds like
check for possible paper scratch inside or in between roller, try to feed paper manually by turning roller. and observe if no abstraction when feeding also check if sensor key is working.
Apr 09, 2010 | Epson Stylus Photo RX620 All-In-One InkJet...
Alternate flashing lights on epson stylus photo 900
Reset waste ink using SSC ver 4.3. Find at indoreset.blogspot.com.
Jun 26, 2009 | Epson RX620 All-In-One InkJet Photo...
Paper jam, with no paper jam!
try to re open again your machine and look very carefully inside remember even how small the paper it will still cause for a paper jam.
if not try to send it to a service technician to give a look to the printer head and rollers.
thanks,
Jun 14, 2009 | Epson Stylus Photo RX620 All-In-One InkJet...
My epson cs7800
I had the same problem and found a small spring was loose and interfering with the paper. The Spring was on the right side as you look at the printer, near the bottom of the paper feeder. I took it out and it works fine, for now.
Jun 15, 2008 | Epson Stylus CX7800 All-In-One InkJet...
Paper jam.
In each case it seems that it is a software corruption possibly caused by a windows update.
Do the following.
Switch off the printer.
Go to Start/Printers and Faxes/ click on remove printer.
Go to Control panel add/remove software
Remove ALL Epson modules
go to Start /Run in the filed type REGEDIT
go to Edit/Find in the Field type Epson RX620
Select and delete all entries that turn up
Shut down you Internet connection.
Disable all Anti Virus and Mal-ware protection
Reinstall Epson from disc following the prompts exactly.
Restart the Computer
Dec 12, 2007 | Epson RX620 All-In-One InkJet Photo...
Epson Stylus Photo RX620 All-In-One InkJet Printer Logo
441 people viewed this question
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
