Bang & olufsen avant vcr fault (tape stuck)
I have a bang & oulfsen avant 28'' with inbuilt vcr, this morning the tape player worked fine, this afternoon i put in a tape and it has froze, it will not play eject fast forward or anything, i have switched off tv at the mains but it will just not come out, if i push the vcr flap i hear a crackle and a purple line appears accross the screen for 30 seconds ish and then goes blank, all other functions appear ok on the tv. thanks in advance for any ideas.
Shuttle83
  • 1139 Answers
SOURCE: TV keeps turning off after 30 seconds
This is usually a sign that a function has not completed or a switch has stuck in an incorrect position. eject can only happen if the sensor (either optical or mechanical senses that a tape is present. The swich might be stuck or the sensor might be blocked or bad. You can open up the unit and try to determine if the sensors are not being blocked by any of the mechanical parts of the unit. You will need the service docs to show you where the components are located. I hope this helps. Shuttle83
Posted on Sep 06, 2007
IB4G2008
  • 3587 Answers
SOURCE: Tape stuck in VCR
could be that you're looking at a blown cartridge for that vcr tape. You may need to cut the tape, to extract that from the unit.
The play head would usually retract when the cartridge is removed, BUT could be compromised by some tape getting into the play head mechanism, and jamming.
be particularly careful with anything pointy or sharp, as the tape head does NOT like those objects near the read surface.
Posted on Mar 02, 2008
  • 139 Answers
SOURCE: VCR tape won't eject
The flap on the door stays open until the tape is ejected. There are two possible ways to remove the tape. First, with the power off, try to locate the drive pulley or gear on the side of the tape housing. It may be possible to turn it with your finger and cause the tape to eject. The eject mechanism will move VERY slowly when you use this technique.
The second way to do it should normally be done by an experienced technician, because it involves taking it even farther apart...and it may be difficult to reassemble. There are typically four screws that hold the tape mechanism in place...two near the top front and two near the back. It should be possible to remove those screws and pull the entire mechanism out of the VCR. Then you can more easily rotate the eject pulley (or gear) and remove the tape. If this sounds a little scary, I would definitely recommend placing the top back on and acting like nothing happened!
Posted on Mar 17, 2008
SOURCE: VCR plays for a few seconds and rewinds. Now, the VCR plays tape in fast forward mode
Most everyone I know had problems with the tv/vcr combo including myself. I'll never buy one again. I'm sorry you are having the same problem.
Posted on Jun 30, 2008
my tv keeps going into stanby mode and also swaps picture sizes
Posted on Aug 11, 2008
My bang and olufsen avant 32" television, when I on it works for about 3 minutes and then it becomes green and white lines appear on the screen.The sound works perfectly.please let me know the cause...
If you wish to get some details; visit the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Sep 10, 2017 | Televison & Video
Bang & Olufsen Beosound 3000 Ouveture CD Problem....Please Help!
Chances are you will need a replacement cd mech assy to fix this problem assuming you have already cleaned the laser lens(cotton bud with ethyl alcohol or isopropanol).dont know of universal remote for b&o but some specialist remote replacement companies do one for beolink1000 which will operate your product.
Feb 15, 2010 | Bang and Olufsen Beosound 4000 Shelf...
B & O Beocenter 4600: The record player won't spin
the turntable wont spin unless a record is on the platter,the centre 45 adapter weighs the record to determine 33/45.try pressing 33 and turning the platter by hand(remove expensive cartridge first!),if it starts to spin the motor leaf switch is at fault.is the belt in position.the motor pulley can become unglued.
Jan 08, 2010 | Bang and Olufsen Beocenter 9300 Shelf...
I have a Bang & Olufsen Beocenter 9000 with a missing CD spindle
You might be able to get one from online parts shop CPC, they stock B & O parts. You can worry about if you can fit it when you've got one!
Dec 24, 2009 | Bang and Olufsen Beocenter 9300 Shelf...
The sliding cover for the tape player sometimes gets stuck when opening.
if we are talking beocenter 9000/8000/9300/8500/9500 replace belt,clean and lube door guide rails
Oct 19, 2009 | Bang and Olufsen Beocenter 9300 Shelf...
Bang & Olufsen Audio Tape Player Seized Up
probably needs belts but parts are discontinued.
Dec 27, 2008 | Bang and Olufsen Beosound 2000 Shelf...
Bang and Oulfsen does not close automatically
the guide rails for glass doors become dusty and clogged with congealed grease.try cleaning rails and re-grease.
Nov 19, 2008 | Audio Players & Recorders
VCR stops, ejects, eats tapes
clean the heads and retime the gears.
Nov 24, 2007 | Symphonic WF802
Televison & Video Logo
182 people viewed this question
Top Televison & Video Experts
