Question about Whirlpool GHW9100L Front Load Washer
Red light flashing,says 'clean pump'.water not drained away either.
  • 574 Answers
Then you probably need to take pump off and see if there is something blocking it either in the hose from tub to pump or pump itself.
Posted on Sep 08, 2009
My indoor lg mini split unit the cool light flashes 4 time what's wrong
Indoor unit faults = CH04 or C4
Fascia LED's
- RED = None
- GREEN = 4 Flash
Contents = Drain Pump / Float Switch
Case of Error = Float Switch Open Circuit (High Level Water Alarm)
Indoor Status = Off
clean your condensate drain line you can do this with a shop vac,
Read more: http://dgoma.es/multisplit_lg/lg-multi-split-units-error-code/#ixzz34dr3Cu00
Follow us: dgoma on Facebook
May 26, 2014 | LG LMN127HVT LMN127HVT 12 000 BTU Ductless...
Washing Machine won't drain away water.
Hi, can you hear the pump running when you select a drain program?
Mar 11, 2013 | Washing Machines
Hoover hpe 236. water not draining, stops mid cycle, lights flash
Have you checked the pump filter, and or that the pump is actually working. if it spins o/k with no water in, then I would suspect a draining problem.
If filter clean and pump o/k, then it could be a control module fault. if this were the case, then it would probably be wiser to purchase a new washer.
Hope this is of some help to you.
Jan 16, 2010 | Hoover Washing Machines
Front louding not running . Whirlpool
You need to get inside and clean out pump assembly
Jan 14, 2010 | Whirlpool Washing Machines
Eco and fast wash lights flashing together and
this does mean draining cycle has timed out due to either blockage or faulty pump...
Dec 21, 2009 | Dishwashers
Saeco Italia SUP021 YR green lights and red water light flashing
You can't manually reset. The machine will have to do it. I had the same problem, two green flashing lights with one red (water) all 3 would just keep flashing and not turn solid. No coffee can be made or hot water. I could not pump prime. The problem was the steam wand was blocked with old milk residue. It needs unblocking or you will never pump prime. I could not unscrew the steam wand...so I let it sink in a glass full of hot water for a few minutes and then turned the water knob counter clockwise to push out the softened residue. After that, everything was good. When water started flowing out of the steam wand, the red light turned off and the green lights turned solid. The obvious answer to why you can't pump prime is there is a blockage somewhere and best to start with the steam wand. --Mabada
Sep 14, 2009 | Starbucks Saeco Italia Digital Barista...
AWM 8121 NOT DRAINING OR SPINNING PROPERLY
that isn't a good model number,open the door,look around the opening where you put the clothes in and next time send the model number off of the machine,if you can't get it to drain and water is in the machine get a shop vac,suck out the water from the tub,then go to the pump,loosen the center of the pump until water starts to come out vac it up until no more water comes out,remove the center catch and see if there's junk in there,if so this is your problem,stick the nozzle of the vac inside and clean out the inside,put it back together and see if it will drain
Sep 29, 2017 | Whirlpool AWM6120 Front Load Washer
Won't drain - drain light flashing
take drain hose off ,put end in pail, then try pump out.
if it doesnt drain check your pump
Jan 13, 2008 | KitchenAid 24 in. KUDM01TJ - Multiple...
Whirlpool GHW9100L Front Load Washer Logo
114 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
