Question about McCulloch Garden
Sawwon't start or run
I have a mcculloch chain saw. it is a mac110 model 600016c the last time i used it it wouldn't start until i primed the carb. and the would only run as long as i added fuel directly to the carb. i think the fuel line is plugged. how do i get to the fuel line to clean or replace it.also where can i get a service manuel for this saw.
    Sergeant:
  • 302 Answers
On my 110 you take off the front section of the saw body to get et the fuel tank and remove it to get at the fuel line. There isn't much room to work in there so be patient.I'll bet your carb needs new diapragms I bought my manual on e-bay.hope this helps
Posted on Sep 08, 2009
Have a McCulloch Mac110. The pull start was working fine and all of a sudden I can't get it the pull start to easily pull.
If the saw got overheated it would have that problem. Take a air hose and blow the dirt off the saw. You probably have to take a cover off and blow compressed air around the cylinder fins to clean that area. Also make sure you are using the correct gass oil mixture for the saw.
Mar 14, 2011 | McCulloch Garden
Hello,I have Mac 110 model#600016c It`s in need of a little TLC The saw is about 25yrs.old and has never hadany work done on it.I need to know what the spark plug gap should be and what the gas/oil mix...
Spark plug gap should be: 0.020" and the fuel to oil ratio is 40:1. Be sure to use fresh fuel and a modern synthetic saw oil available at home centers, hardware stores, and saw dealers. Mix well in it's own container and be sure to shake the container thoroughly each time just before filling the tank to prevent oil starvation. Hope this helps!
Dec 01, 2010 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
I have a McC Power Mac 380. I have owned it since it was new and it doesn't have a lot of hours on it. I thought I emptied and used up the gas since it's last use, but now with fresh gas and new fuel...
did you clean the jets on the carb,take the jet out counting the complete turns prime it a few times, then put the jet back in with sth same amount of complete turns. then prime and start
Sep 12, 2010 | McCulloch Garden
I have a McCulloch MAC 110, Model 600016C which
The IPL (exploded parts list) for your saw can be found here:
http://www.mymowerparts.com/pdf/McCulloch_Parts_Service_Repair_Manuals/Gas_Powered_Chain_Saws/McCulloch_Gas_Chain_Saws_Parts_Manuals_11_600016C_MAC_110_01_77_to_02_83_IPL_95807_R2.pdf
Page 6 item 21.
You have to remove the engine to access it.
ArboristSite.com Chainsaw thread (free to join)
http://www.arboristsite.com/forumdisplay.php?f=9
There is some discussion about the proceedure in the McCulloch thread. Its a good little saw. I'm awaiting oiler parts on mine. HTH
Lou
Oct 03, 2009 | Garden
No top end power
Have a set of really small screwdivers ready. First, make certain the saw hasn't set up a season and gotten all gunked up. If it has, take off the air filter and wash the carb out with carb spray cleaner. You may have to replaces all the fuel lines. Once it has fresh gas in it, and you can smell the fresh gas by pumping the bulb til the shellac smell is gone, take off the air cleaner and fire it up, even if you have to use starter fluid spraying a shot into the carb. (You'll probably need a new plug by now).
When it starts to run, hold it at high throttle and adjust the high speed mixture screw to the right until it smooths out, or if it gets worse, to the left. Once it runs smoothly, keep turning til it begins to stutter, then turn back a half turn.
After you get it to run ok at high speed, you'll need to adjust the low speed until it starts and revs up quickly.
May 18, 2009 | McCulloch Garden
McCulloch Chain Saw Manual
Found all the mcculloch manuals you could ever want on mcculloch product information site. Its run by mcculloch an you put the product weather chainsaw or strimmer whatever an the type in the next collum an press download then print it off all very easy. My manual was in german so made up i found stumbled on this.
Jan 14, 2008 | McCulloch MC1275 Steam Vacuum
Garden Logo
199 people viewed this question
Top McCulloch Garden Experts
Jim Parker
Jim Parker
roeb
Are you a McCulloch Garden Expert? Answer questions, earn points and help others
