Question about Dryers
Dryer wont start. just clicks when you push the button
    President:
  • 1,564 Answers
Try hip checking it while you push the start button. If it starts you need a new contactor swich(relay) for the drum motor.
Posted on Sep 08, 2009
Dryer wont start just clicks what can be wrong
may be a bad thermal shut off , any error codes like F1 may also want to check ur push start button or dial with a multimeter, if its bad can get a buzzing and maybe a clicking
Sep 15, 2014 | Dryers
Wont start when button is pushed
could be a bad door switch, wen door switch goes bad it wont start the dryer thinks the door is still open.
Dec 17, 2012 | GE GTDP300EMWS Dryer
I have a power but dryer wont start after i push start button. i can hear the click sound after i push the start botton but doesnt start.
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 20, 2011 | Samsung DV419AGW Dryer
The dryer wont start when i press the start button
maybe the dry door switch or the reset button on the motor. if you here like a click noise when you push the start button then its the reset. if not then more then likely it is the switch, which means either way the front panel has to come off, screws are located inside dryer door, the top corners are clipped from the inside so a flat tip screw driver will pop the corners, then disconnect switch, if it is the switch remove switch and tape wire together, put front panel on with top clips, plug in and push start drum should turn. get new switch.the reset buttons are on the motor and when you push the reset it will click. Hope this helped Tim
Sep 23, 2010 | Kenmore 63942 Dryer
Push start button wont start dryer
This could be the non resettable thermal fuse has popped, or the door switch is not working. Open the door and press on the door switch until it clicks and push start to see if it works. If it clicks and still no start, then the thermal fuse needs replaced. UNPLUG the dryer, remove the back and you will see the white thermal that looks like a regular thermostat with 2 wires on it. It is located on the air plenum. There could be 2 depending on the exact model, but normally only one white one. These thermals usually pop when the temperature gets too hot as a warning something needs checked. Check your vent and be sure it is absolutely clear, and the flapper on the outside is not stuck with lint buildup.
Nov 27, 2009 | Kenmore 62602 Electric Dryer
Dryer wont start.
Some start buttons do not click. But it sounds like maybe the door switch.
Sep 25, 2009 | Kenmore 659 Electric Dryer
Kenmore heavy duty dryer model#86870800 wont start running
Hi ya, rkallen
Welcome to fixya.com
You said, when we push the start button, it will lightly click like it is ready to go but wont actually start. Is it the starter button that is bad? How hard is that to change ourselves? Any suggestions?
Sounds like you have a bad starter switch inside or a bad relay.
Doing it your self you will not be able to determine if it is the starter switch or the relay. You need someone who knows how to use test equipment!
Web site and schematics below. You can open them into the whole window and buy parts there too!
Thank you Huuum
Please leave a solved rating before you sign out
Jan 23, 2009 | Kenmore 63942 Dryer
Fuse
Your belt is broken, the click that you hear is a centrifugal switch that shunts your start button, so we know the motor is running. Check your belt.
Oct 09, 2008 | Kenmore 62602 Electric Dryer
Dryers Logo
79 people viewed this question
Top Dryers Experts
