Question about Delta Electronics DELTAELEC PLUG IN POWER SUPPLY DELTAELEC (DTPS340AB) Power Supply
Need to connect a source DPS-730 ABA, but not have the female connector, need to know the encoding of the output pins of the source.
6 PIN DIN to RCA Converter Cable with power for security camera
WHOA we'll kinda hard when there are 50 different camera co out there need the camera co name and camera model
Jan 27, 2014 | Home Security
I would like to know what adapter (DVI to VGA Cable Adapter) I need to connect to a Macintosh G4. Thanks
Without knowing what Model Number of MAC G4 you're referring to, I can only give you generic information.
If your MAC G4 has a DVI port it is generally the female style.
The DVI connector on the adapter will need to be a male DVI style.
The VGA end of the adapter will be either male, or female. Most VGA connectors on a monitor cable have a male VGA end.
(The DVI end will have the pins sticking out on the adapter. The VGA end will have the socket holes)
Also stated as the monitor cable end will be a DVI male. The port {Connection} on the computer is a VGA female)
Example of a DVI male to VGA female adapter,
http://sewelldirect.com/dviaftovgam.asp
Barring that you need the other style of DVI to VGA adapter, (DVI female on the monitor cable, VGA male on the computer), this is an example,
[ Note* The newer VGA connectors are also known as an HD-15 connector.
More information on the Video Graphics Array connector,
http://en.wikipedia.org/wiki/VGA_connector
More information on the DVI connector styles, and the Digital Visual Interface technology,
http://en.wikipedia.org/wiki/Digital_Visual_Interface
If you should find all of this confusing, simply state in a Comment as to what connector is on the end of the monitor cable, and what connector is at the computer.
State whether the connectors are Male (Pins sticking out), or Female (Socket holes)
Regards,
joecoolvette
Jul 16, 2011 | Computers & Internet
HOW I CAN HAVE OUTPUT FRO AUDIO LINE ROM LG 55LH5000???
Hi, sorry but Most LG's no longer have audio outputs. The easiest way to get it ,You need to take the audio output from the source i.e. "cable box output"..if you have of course...
However whether your TV has this output or not we need to make some tests..5 different connections possibilities provided below.
(not by priority..you can start with any of it ).Below ,there is a sample TV back panel picture as well
Possible CONNECTIONS:
1) 2x RCA ports red / white is audio out ( L + R ) of TV to Stereo..
2) You can get also the audio digital output from the TV to a A/V receiver. the tv's optical audio out is stereo only mainly designed for freeview or tv audio to be output,
set the audio ouput on the TV menu to Dolby Digital, connect a digital optical out directly to the A/V receiver to receive audio signals.
3) since your TV has :2 x HDMI, SCART, AV, Component Video, VGA-sub, USB 2.0, connections,you may use the SCART plug to get Audio output for your TV .
TV's SCART connector which has 21 pins and "2x Audio Output " pins should be in it.
you need to buy an adapter called " RGB Scart Male to 3 RCA AV Female Adapter Converter" that can easily be found any electronic Market..one example as found eBay URL is below..
http://cgi.ebay.com/RGB-Scart-Male-3-RCA-AV-Female-Adapter-Converter-/130389078197
After you get this adapter,you need to carry the audio signal from SCART's RCA plugs to your Receiver with a 2x RCA (white/red ) cable.(if this does not work ,mfg should state somewhere in the manual..as your TV's "SCART socket IN only" ) if you properly connect IN/OUT plugs you will able to get the audio signal of the TV thru stereo..I recommend 2 $ value "RGB-Scart-Male-3-RCA-AV-Female-Adapter-Converter" with IN/OUT switch on it.
4) use HDMI connection of TV if you have HDMI input on your stereo of course...
5) if these are not an audio-out on one of these connectors , so you'll need to use the headphone socket if you want to plug it into a stereo. you need a cable 2x RCA to 3.5mm Headphone jack.
( This is the last ditch solution , since it mutes the whole sound.) ..
NOTE: if you connect this, pls be careful,your TV voice level will drive the stereo volume....
Hope this helps!..if more help requires Would you please let me know the result ?
Take care and please
Remember to rate/vote and give me 4 Thumbs Up for us
to continue f
or Helping out the Community :)
Jul 09, 2011 | Televison & Video
Sony walkman NWZ-S754 Recharge is through computer - but can I recharge it via mains or in car.
Yes you can charge your player through main. All you need is a converter which connects to the usb cable to the plug. They are available in the market so you will need to look for it. Or you may find it at any electronic store.
Jan 20, 2011 | Sony Walkman Video NWZA818 MP3 Player
Westinghouse LF708C fault code SE. not spinning. what needs to be fixed?
SE refers to a sensor error, remedies include checking all connections plugs: § The connector (5pin, male, white) in the Wire Harness is not connected to the connector (5 pin, female) of Hall Sensor in the MOTOR. ?_? reconnect or repair the contact in the connector The electric contact between the connectors (5 pin, male in the Wire Harness and 5 pin female in the Hall Sensor) is bad or unstable. ?_ Reconnect or repair the contact in the connector ? The connector (6 pin, male, natural) in the Wire Harness is not connected to the connector (6 pin, female, natural) of PWB ASSY(Main) or the electric contact of connectors is bad/unstable. ?_ Reconnect or repair the contact in the connector ? The electric contact between the connectors ¡a6 pin, male in the Wire Harness and 6 pin female in the controller(Main)¡bis bad or unstable. ?_ Reconnect or repair the contact in the connector ? The Wire Harness between Hall Sensor in the MOTOR and PWB ASSY(Main) is cut(open circuited). ?_ Repair/replace the damaged WIRE HARNESS ? The Hall Sensor is out of order/defective. ?_ Replace the Motor ? The controller(Main) is out of order/defective. ?_ Replace the PWB ASSY(Main)
Jan 22, 2010 | Westinghouse Washing Machines
I want to connect the z2300 speakers to an LCD tv. Do I need a special cable?
try to check your speaker if what type of cable your speaker have...your LCD tv i think its a RCA connector, so you have to insert the RCA connector to the output audio label,,,then the cable which is also an RCA output must be connected to a RCA female connector ....again the output the your female connector will depend to what your speaker output have....it its minijack or RCA then the output must be female RCA of mini jack also.
Oct 19, 2009 | Logitech Z-2300 Computer Speakers
Orange & white power sw cord needs to be connected to mother board need to know where it goes
Count the number of hole that the SMPS female connector has. It would be in two rows. Look for an opposite male connector with pins in two rows. Number of pins should be the same. There is only one such male connector. Set the female connector on its counter partin such a way that the locking pins of one go into the locking slot of the other.
Aug 23, 2009 | EliteGroup P4VXASD2 Motherboard
My DPS-730AB A power supply made by delta for my server quit
I need the diagram of the output pins of the source (DELTA ELETRONICS) Model: DPS-730 ABA
Mar 21, 2009 | Delta Electronics DELTAELEC PLUG IN POWER...
5-pin TTL connector for external flash
The 5-pin TTL connector is designed to control the Olympus FL-40 dedicated flash unit (p/n 200596). To use the FL-40 with these cameras, the optional Olympus FL-CB01 cable (p/n 200 664) and FL-BK01 flash bracket (p/n 200 666) must be used. The 5-pin TTL connector can also control a PC Sync flash or strobe system by using the optional FL-CB04 flash cable (p/n 200 661). Since this type of flash/strobe is non-dedicated, the photographer will need to manually match the flash output with the camera.
Sep 04, 2005 | Olympus Camedia C-730 Digital Camera
Computers & Internet Logo
299 people viewed this question
Top Delta Electronics Computers & Internet Experts
David Payne
David Payne
Are you a Delta Electronics Computer and Internet Expert? Answer questions, earn points and help others
