Question about Dymo LetraTAG Thermal Label Printer
Hand held labeler not printing as if ink is out
Ink flaking off printed labels
your problem is not good fusing. try with a different fuser.
Apr 10, 2013 | Oki Brand Oki 62433501 C711n Laser...
We have a Dymo hand held office labeler which ran out of ink. How do you replace the ink- This machine hold the 1/2 x 13 tape
No ink required. You just got bad tape cartridge. Replace with a new cartridge. This unit burns the letters into the tape.
Sep 18, 2010 | Dymo LetraTag QX50 Thermal Label Printer
I have one line on the page that the ink does not set on my Brother MFC-9440CN. All the other ink sets, but this one line doesn't and it "smudges" when you run your hand over it.
I've just bought a brother printer and find that when I print onto cd labels i've used before, the ink is not setting. I have never had this problem before with these labels, so now am concerned that the only new addition is the printer. Why should this happen? Is it the ink they use?
Jul 23, 2010 | Brother MFC-9440CN Laser Printer
My Z4M Plus printer is not printing the label all the settings are fine no error. The ribbion shows the image but it doesnot print on the Label.
Two possiblities: 1. the darkness is not high enough for the ribbon/label combination. 2. the ribbon is on backwards. if the ribbon is on backwards, you will still see an impression on the ribbon but not on the label. This means all the ink transferred to the printhead which should then be cleaned.
The ink side of the ribbon needs to face down to the label to print so the easiest way to make sure which side has the ink is to use a label or piece of tape and touch it to the ribbon. If no ink comes up in the adhesive then that is the wrong side.
Hope that helps !
Apr 01, 2010 | Zebra Z4Mplus Label Printer
I channged the ribbon and the printer will not print tried several thing but it look like everything goes ok but there is nothing printed on the labels
Check that ribbon is installed correctly. Zebra ribbon only has ink on one side. ink side must be facing label. Use a label to check which side ink is on stick label onto ribbon and peel off.
Jun 14, 2009 | Zebra LP 2844 Thermal Printer
Ink ran out!? What to use?! or where to buy & how to use?!
Hi, the Dyno label uses no separate ink for printing. The labels are printed with thermal ink that's in the refillable label cartridge. Replace the cartridge and your back in business.
Apr 29, 2009 | Dymo LetraTAG Thermal Label Printer
Dymo Letra Tag
It runs on heat transfer. It probably needs new batterys. If youve been on a labeling spree you've most likel killed it.
Sep 24, 2007 | Dymo LetraTag 2000 Printer
Dymo LetraTag 2000 hand held printer
This Unit does NOT take ink. That is one of it's "benefits." Since it uses heat transfer, im thinking it either needs new batteries, or it's heat device has been expended. This is a cheap little maker, so it isnt made to handle the abuse of an office: it's meant for a label from week to week. If you went on a label spree all over the house, you killed it. Hope this helps!
Jul 26, 2007 | Dymo LetraTag 2000 Printer
Dymo LetraTAG Thermal Label Printer Logo
803 people viewed this question
Top Dymo Office Equipment & Supplies Experts
Jax Planet
Jax Planet
jdthefixer
Are you a Dymo Office Equipment and Supply Expert? Answer questions, earn points and help others
