Question about Saws
Filling carb up with fuel
Sthil ts360 flooding carb when pulling start cord. just fitted carb service kit still the same,if you keep pulling start cord it just pumps fuel into carb and floods it to death
  • colr6 Sep 08, 2009
    HI Thanks for solution but does not have afloat its a diaphram changed that and needle valve still same problem
    Sergeant:
  • 302 Answers
This sounds likke the float is sticking
Posted on Sep 08, 2009
Want keep running after several times of starting it
will it continue to run on choke? if it does you have an air leak, if not then you may have a faulty carburetor that isn't stopping the flow of fuel and it is flooding itself out
Jan 11, 2013 | Stihl GUIDE BAR 16 in STHIL CHAINS
The PB-250 will not start. It was purchased last year and used little. I have fresh gas and a new properly gaped OEM plug. I do have spark. The spark plug is wet with fuel. Can one flood the engine by...
It is very easy to flood this item mind you its easy to flood all petrol trimmers. If plug is wet simply turn the switch to off and pull cord at least 15 times you should get the engine to start coughing keep pull cord but do not turn the petrol on do not prime it either. It should catch. If it does not push the primer once and pull cord
May 31, 2017 | Echo Gas Blower 135 MPH390 CFM Blower...
Hi,my zephyr 1100 keeps flooding back on carbs,fitted pilot jet kit and set floats,all started with not running bike enough,its a 1993 with only 6,800 miles,help.
onee of you carbs needle and seat is not closing all the way if you leave the gas on and remove the overflow tubes from each carb yuo should see this one leaking make sure bike is sitting up right so fuel isnt just running to one side
Feb 14, 2011 | 1993 kawasaki Zephyr 1100
When i pull the cord to start it gas is spraying out the exhaust. What is the problem
The problem is the needle valve inside the carb is stuck open causing fuel to fill the cylinder. This why gas is coming out of the muffler. You have to rebuild the carb but you have to determine if you have a walboro or zama style carb in order to get the right rebuild kit. make sure you get the full rebuild kit that comes with a new needle valve and adjust the needle valve so that its flush with the slot that it fits in. Also remove the spark plug and pull the starter until all the fuel is out of the cylinder.
Dec 07, 2010 | Poulan/Weed Eater No. Te475 952711797 17"...
Black Max 7000w 8750 surge 13hp. pulled start cord twice very hard then would no longer turn over engine, locked.
Pull the spark plug out and try pulling the cord. Sometimes it gets flooded and the cylinder fills with fuel and hydro locks. When you pull the cord and there is fuel/oil in the cylinder, it will fly out when you pull it. Stay out of the way.
If that is not the problem ( I think it is though), double check the oil level. Check the color of the oil, it should not have any silvery color. It should also not be overfull. If it is......smell it......, does it smell like gasoline? If it is overfull, and smells like gas, you have a carburetor problem. And if you do chances are you already know that, it will leak and drip, unless you shut the fuel valve off.
If everything seems fine...,and you still have a stuck motor, you will need to seperate the generator from the engine and determine which one is actually stuck.
Hope it's just a leaky needle and seat in the carb. causing your flooding.
Nov 18, 2010 | Powerware Electrical Supplies
When i start it up and let it run for the 30-60 seconds then squeeze throttle it doesn't want to run. almost like it either starves or floods.
Definitely sounds like a fuel delivery issue. It may be time to install a diaghram kit or rebuild kit on the carb. The sensitive internal parts don't last forever. You can check for flooding immediately after by pulling the plug. If it is real wet, either the plug isn't firing to its full potential or the carb is indeed flooding.Those carb kits aren't too hard to install and you may be able to get by with just the cheaper diaghram kit.
Aug 18, 2010 | Craftsman 25cc Gas Line Trimmer
Blowing out gas at the start. Drained and filled with fresh gas mixture. Cleaned spark plug and srayed carb cleaner in hole. Pull choke pull cord , blowing gas out of carb. Stuck float? Buy carb kit from...
No floats in chainsaw carbs. Severly flooded most common start problem with chainsaws. Read and follow the start procedure in your manual. Don't use choke on flooded engine (may set fast idle, set then turn off)!
Extreme Flooding by Dolfoff
Please follow this link, http://www.fixya.com/support/t3226410-no_spark_new_plug_but_continues_flood cursor down to “Best Solution”, while there click the “Was this helpful? [Yes]” button
Start Procedure
Cold:
  1. Ignition on/off to on
  2. Set compression release – optional step even if saw is equipped with a compression release
  3. Pull (close) choke, set fast idle (done when choke closed on some saws); pull starter and listen for an attempt to start. once heard (usually two pulls)
  4. Set compression release – optional step even if saw is equipped with a compression release
  5. Push (open) choke pull starter until it starts. (usually first pull)
Warm:
  3. Pull (close) choke, set fast idle (done when choke closed on some saws) - Don’t pull with choke closed.
  4. Push (open) choke, pull starter until it starts. (usually first pull)
Hope this helps
Lou
Oct 31, 2009 | McCulloch Garden
Mariner 25 hp 2 stroke hard to start then quits and won't restart
It sounds like the float is sticking in the carb. Since the carb is higher than the fuel tank it pulls the fuel in by vaccum of the engine. when running at high rpms, it can burn the fuel thats flowing into the carb, when you idle down, the bowl of the carb is filling up with fuel faster than the engine can burn it and causing it to flood. Then when it shuts off at idle it does not want to start back up because it is flooded. To make a long stary short, pull the carb and give it a good cleaning and your problems should be solved.
Aug 01, 2009 | Light Outboard Motor Boat Bass Fishing...
When start bike up,it runs on 4 then onto 3 then 2 then cuts out.have stripped carbs rebuilt,balanced them.new plugs.runs fine till warm,think may be fuel problem. changed fuel tap.ballenced carbs with 2...
Are the cabies flooding or runing out of fuel? pull the choke on dose it help if it does low fuel.
Drain the bowls and see if there is plenty of fuel.....If its flooding turn the fuel off or block it when the engine starts to drop clys if it starts to pick up after 10secs or so the carbies are flooding
Feb 23, 2009 | 1988 Suzuki GSX-R 750 J
Saws Logo
96 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Saw Expert? Answer questions, earn points and help others
