Question about Whirlpool 24 in. GU1500XTLS Stainless Steel Built-in Dishwasher
Whirlpool dishwasher makes loud whining noise
This is supposed to be a quiet machine - and it was until the noise started. now we can only run it when no one is home. very loud whining whirring noise the whole time. stops while the cycle changes, then starts right back with the loud whine.
GU1500 XTK(T) Quiet Partner IV Dishwasher
  • 171 Answers
SOURCE: whirlpool gold quiet partner iv will not turn on
Hi chrslndsy,
I'm Harvey the Master Plumber.
Your problem is: whirlpool gold quiet partner iv will not turn on there is no sign of life in it at all.
Usually this indicates that the power is disrupted. First check the breakers. 9 times out of 10 it's a broken, loose or burnt connection in the d/w junction box. It's located underneth the d/w behind the kick plate on the right or center, depending on model. Turn the power off at breaker and remove cover. Take each wire nut off and repair/replce as nessessary. Test before you close it up.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Posted on Oct 13, 2008
  • 11 Answers
SOURCE: Dishwasher Making Loud High Pitched Noise.
A loud high pitch whine while running the dishwasher means that there is something caught in the chopper assembly. To get to the chopper assembly you need to take the racks out and take the pump apart from the inside of the dishwasher. The chopper assembly looks like a metal grate with holes in it. And it might not even be stuck in the grate but somewhere in the pump area due to the water being pumped out, so the best idea is to take the whole thing apart and clean everywhere. However I do not recommend doing this unless you are completely certain you will remember where the screws and gaskets go, otherwise you risk damaging your pump or house from a leak or improper installation. You have been warned.
Posted on Jan 15, 2009
  • 38 Answers
SOURCE: dishwasher runs very loud
Could be something as simple as something caught in the food disposer blades. Remove the lower spray arm and filter assembly. There is a cover inside the sump that is removed and once you remove it, you will have access to the food disposer blades and pump impeller.
Posted on Feb 25, 2009
  • 38 Answers
SOURCE: Whirlpool Quiet Partner II soap door not working
Yes, you can buy the whole assembly and replace it. Replacing the assembly should fix your problem.
Posted on Mar 04, 2009
WRMtech
  • 70 Answers
SOURCE: RUN TIME ON NORMAL WASH IS ABOUT 3 HOURS
common failures on that usually are the heating element. Look at the botton and see if it is broken anywhere.
Posted on Mar 22, 2009
Why is my whirlpool dishwasher making a loud noise during drain, wash and rinse cycles?
They can be complicated to re-assemble. Best solution is to video the procedure (if you have a video camera) during disassembly and make notes and diagrams to orient things properly and make sure the correct screws go back where they shoud. Takes more time, but you'll be glad you did, it will save you a lot of aggrevation in the long run.
Aug 24, 2014 | Whirlpool 24 in. GU1500XTLS Stainless...
Whirlpool dishwasher is making a loud whine while running.
Have you found a solution to your whinning? Mine is doing the same thing. Started about two weeks ago.
Mar 21, 2009 | Bosch 24 in. SHE44C02UC / SHE44C06UC /...
Kenmore quiet pak III dishwasher has a whining noise
Most of these dishwashers have separate circulation and drain pumps and there is a good chance that there is an issue with the circulation pump impeller issue under the lower wash arm. The bottom panels under the door can be removed to check it out.
Chris Z --- www.repairclinic.com
http://www.repairclinic.com/Kenmore-Dishwasher-Parts
Jan 25, 2009 | Kenmore 24032\24036 Top Load Washer
Whirlpool Quiet Partner Doesn't finish cycle
FIX YA IS A JOKE I WOULD LIKE TO BURY THE ************** WHO CREATED IT!
Jul 30, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
debris caught iside pump assy is what it sounds like
Feb 24, 2008 | Kenmore 24 in. 17032 Built-in Dishwasher
How deep do you want to get into this?It sounds like the wash pump motor bearings that are worn.You can pull the unit out flip it over and wd40 the bearings in the motor or you can replace the bearings.Try to lube them first.
Feb 23, 2008 | Dishwashers
Dec 25, 2007 | Whirlpool 24 in. DU900PCD Built-in...
Whirlpool 24 in. GU1500XTLS Stainless Steel Built-in Dishwasher Logo
201 people viewed this question
Top Whirlpool Dishwashers Experts
Mike
Owen Barnes
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
