Question about Waterway Spa Pump Executive 56 Frame 4hp Dual Speed 2" Intake 2" Discharge
I have a waterway monsterflow 6.5hp pump in my Coast Spa. I replaced the impellar and seals and the start compenstor. It works on speed two but not on speed one sany suggestions
  • 990 Answers
Check to be sure you have good power through your timer and heater as they run the low speed.
Posted on Oct 04, 2009
What is the flow rate (GPM) of an Executive 56 Waterway pump Model PF-50-2N22F?
Waterway Executive 56 Spa Pump, 5 HP, 230V
Waterway Executive 56 Frame spa pump wet end
assembled to a 56 frame, 5hp, 2-speed 230V spa motor
This Spa pump has a 2-1/2 inch intake and a 2 inch discharge for plumbing
(but measures 3-1/2 inch and 3 inch- see bottom of this page)Manufacturer Part No. 3722021-13 Other Part No. PF-50-2N22C
Features:
  • Executive spa pump wet end designed specifically for 56-frame spa motors
  • Two double shielded ball bearings with moisture resistant grease for quieter operation and longer life
  • Two speed spa motors have four sets of insulated windings for increased efficiency
  • 56 frame spa motor for added strength, cooler operating temperature and longer motor life
  • Large 2-1/2 inch intake for improved flow performance and reduced noise
  • Large 6-1/2" diameter wet end for higher head pressure
  • Split capacitor, (start and run) for less energy consumption
  • Thermally protected to extend life expectancy of hot tub motor
  • Highly versatile wet end can be rotated every 90 degrees
  • Viton seals
  • Three year manufacture's warranty on spa motor and spa pump wet end
Jun 05, 2015 | Waterway Garden
I have a Waterway Spa Pump Executive 56 Frame 4hp Dual Speed PF-40-2N22C in a Catalina spa that recently developed an issue. The pump will not start in low speed, just makes a humming noise, but it will...
the problem with the sound is the bearings inside the motor are going out. i have the same pump and i have to replace the motor. replacing the bearings is very hard and will cost you about the same after you carry the motor and new bearings to a shop to be pressed in. hope this helps!!
May 04, 2011 | Waterway Spa Pump Executive 56 Frame 4hp...
Hi , my executive 48 pump is leaking water at the shaft ...... is this some sort of bearing or seal problem ? thanks in advance for any help , andy dic
The pump seal is the problem and it can lead to bearing damage if not caught soon enough. The seal used in the waterway pump is not as easy as most seals to replace. You are better off to have it done at a pump repair shop or pool store than to tackle it yourself unless you are familiar with this seal and have the tools to fix it. A repair bill would likely be under $75 for a seal replacement at a shop and they can replace the bearings if necessary.
John
Oct 07, 2010 | Waterway Executive 48 Spa Pump 2hp 1spd 2"...
Spa Pump Executive 56 Frame 4hp Dual Speed 2" Intake 2" Discharge : My Executive 56 spa pump (1-l/2 years old) is leak...
Thank you for posting your question here on Fixya.com.
There is a seal in there that a local pump repair shop can fix for about $30 - $50 with parts and labor. Waterway pumps use a 1000 seal that is not a seal the homeowner is usually successful at replacing themselves.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. Positive feedback is appreciated once your problem is solved!
John
May 18, 2010 | Waterway Spa Pump Executive 56 Frame 4hp...
How do i remove impellor
The impeller in my 4 HP, 2-speed Waterway Executive High Performance 56 pool & spa pump has a brass coupling embedded in the back side. This coupling can be unscrewed from the motor shaft by keeping the shaft from rotating while turning the impeller in the reverse direction. Then the seal can be tapped out.
Oct 08, 2009 | Waterway Spa Pump Executive 56 Frame 4hp...
Pump will not always start in low speed but always starts in fast speed
this is a simply problem to cure. if you open the connection box on the pump, you should find 2 capacitors. you may even find one of them has melted!, replace both units, like for like, paying special attention to the values uF the two units will have different values. this should do the trick!
Jun 28, 2009 | Waterway Pump Part Seal Set Ps1000 Cd 319...
Pump will not start on low speed
It sounds to me as though there may be a problem with the small run capacitor on the motor. If that has failed the motor will fail to start on low speed.
The motor shop should know what they're doing as this is a common motor issue. Take it back to them and explain the problem to them.
Kind Regards,
Ian Kime.
http://hottub.synthasite.com
Jun 02, 2009 | Waterway Spa Pump Executive 56 Frame 4hp...
Waterway Spa Pump Executive 56 Frame 4hp Dual Speed 2" Intake 2" Discharge  Logo
819 people viewed this question
Top Waterway Garden Experts
Ian Kime
Ian Kime
Mike Raino
Level 1 Expert
john h
Are you a Waterway Garden Expert? Answer questions, earn points and help others
