Question about Sony KP-61HS10 61" Rear Projection Television
My sony rear projection tv lost the color yellow
  • 60 Answers
Hi, I used to work in Best Buy and one of the key things about rear projection TVs and the reason they push those service plans on you is that the tubes/colors need to be calibrated each year. You can do this yourself by checking out the following website:
http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=3229
If you are not able to adjust the convergence using the remote you will need to replace the convergence chips.
Typical Symptoms
1) Convergence menu does not work for one or more colors.
Such as: Red moves up,down, but left or right fails.
2) Screen is bowed looking.
If you have one or more of the problems above you need to replace the convergence chips. You can get a kit and instructions from www.TvRepairKits.com
Hope this helps :)
Posted on Sep 17, 2009
spqr163
  • 37 Answers
SOURCE: Rear Projection TV -- Bright spot with yellow edges on TV screen
if it is a panasonic pt-50lc14 then you will need a new bulb. you can find them online, do a yahoo or nextag search for the ty-la 1000 bulb and you can find them for around $100...
Posted on Mar 12, 2009
Ecollier2012
  • 3459 Answers
SOURCE: Sony KP-51WS500 Rear Projection TV colors are distorted.
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Posted on Mar 13, 2009
SD Tech
  • 14553 Answers
SOURCE: sony rear projection tv showing double
If you have a CONVERGENCE problem and it will not adjust---the two STK-392-150 Chips this set uses need to both be replaced and the set adjusted with the original remote control.
You can, if you are able to do the repair, buy a pair of chips for less than 14 dollars plus shipping on Ebay.
If you cannot do the repair--shop around your area--most shops are going to charge 300 or more for this kind of repair.
When you consider the cost of the parts--if you can do it or know someone who can--you can save the set and a lot of money--This repair can easily be done right in your home in about 1 hour--I know as I have done hundreds of them---did two today.
The chips (with the back off of the set) should be on two metal heat sinks on the board on the far left---they will be facing the front of the set.
All that is required to get at them is to remove all the plugs on that board and the screws that hold it in and tilt it up so the bottom of the board is in view---you unsolder both chips (about 18 pins each) and remove the 2 screws that hold each to a heat sink.
With 2 new chips you put heat sink compound on the back of each--it is a white grease to move heat quickly from the chip to the metal, and solder both chips in----put the board back down and all the plugs back(I usually mark all of them so I know where they go) and turn the set on and see what you have...
Most of the time this repairs the set--go into the customer menu and adjust the convergence and you are ready for another 5-8 years of life---this is the normal lifespan of these chips.
If you need assistance or have questions let me know--I am here to help people.
If this information helped you, rate this solution as I do this here for free.
SD TECH
Posted on Nov 08, 2009
  • 668 Answers
SOURCE: projection sony tv is yellow
Most likely it is the Optical Block. It has been a issue for most of the Sony LCD Rear Projections manufactured over the last 6 plus years. Your Model may still Qualify as a factory recall. What you need to do is to get in touch with Sony's Customer Service at 1800-222-SONY and see if it does Qualify.
If not, it is a expensive repair costing 1200.00 to a 1500.00.
I hope it still does Qualify for a recall,
Skyassoc
Posted on Jan 07, 2010
  • 69 Answers
SOURCE: Sony rear projection widescreen TV. Concave shapes & ghosting
sound like the convergence ics have failed
Posted on Feb 07, 2010
TV has multi color lines and a circle when I turn it on
Sony rear-projection TVs provide a large-screened entertainment solution for your home or office. Unfortunately, color problems and yellow and blue spots and saturation can occur on the face of the Sony rear-projection TV. These problems can be the effect of damaged cables, electronic interference from other devices or dirty lenses on the inside of the rear of the television set. You can troubleshoot for these problems and make satisfactory repairs without the help of a repairman. No experience with Sony rear-projection TVs is necessary.Step 1
Check the audio/video cable that connects the Sony rear-projection TV to the cable or satellite receiver. This black cable has a number of multi-colored plugs on each of its ends. Ensure that this cable is not visibly damaged in any way, and that each of the plugs is in good shape and is not bent. A damaged audio/video cable will negatively affect the quality of your rear-projection TV's display and may lead to yellow and blue saturation problems and various other display irregularities.
Step 2
Ensure that there are no other high-powered electronics in the close vicinity of your Sony TV. Speakers, computers and other similar electronic devices use a large amount of power and in turn may give off a lot of electronic interference. This interference can cause problems for your rear-projection TV's screen, such as color blurring and similar color issues. Move any such potential devices to an area that isn't as close to your Sony TV. The color blurring and yellow and blue saturation problems should then decrease over time.
Step 3
Unplug the TV if problems persist. Ensure that the Sony is completely disconnected from all power sources. This is for your safety.
Step 4
Place a towel on the floor of the area where you are going to operate on the TV. Carefully turn the TV facedown on the towel, so that the rear of the TV is facing upward.
Step 5
Remove all the screws from the back cover of the television set using a Phillips screwdriver. Remove the back cover piece by working around the edges with your fingers and gently prying the piece off.
Step 6
There will be three upright lenses in the back of the television. Cleaning these lenses can alleviate picture quality problems and color blurring. Use a soft cloth and soap and water to clean the lenses of the television. Avoid using any other cleaning solutions, as soap and water is the only universally recommended cleaner from rear-projection manufacturers like Sony.
Step 7
Ensure that the lenses are dried. Replace the back cover of the rear-projection TV and reinsert all screws using the Phillips screwdriver.
Jun 19, 2016 | Televison & Video
Hitachi Projection Color TV 43FWX20B - COLOR OFF
Check all cables,replaced all cables if more than couple years old.After that the same,ur tv have one dead color gun,require service.
Jan 01, 2010 | Hitachi 43FWX20B 43" Rear Projection...
Lost power to my house when it returned my sony rear projection tv screen is distored and warped with color bands seperated
It sounds convergence out ICs are defective in your Sony TV and need to be replaced.
Let me know exact model number written at back of TV to guide you further if you wish to repair TV by yourself.
Thanks.
Nov 09, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
Sony HD Projection TV - Picture bent and seeing multiple colors
This is due to failure of convergence out ICs that need to be replaced in D board.
If you are comfortable with TV repair let me know to provide you technical info to fix TV.
Apr 17, 2009 | Sony KP-46WT520 46" Rear Projection...
Picture keeps turning green or yellow
This could be the screen amp board or a picture tube shorting.
$$$ yes
Jul 11, 2008 | Sony KP-57WS520 57" Rear Projection...
Color problem
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Sony Convergence
http://www.techlore.com/blog/entry/19694/Sony-Convergence-Repair-My-Sony-TV-has-a-distorted-picture-/
http://www.techlore.com/article/19631/Sony-Convergence-Procedure/
Jan 20, 2008 | Hitachi 53UDX10B 53" Rear Projection...
Tv lost color
Your problem most likely is on the signal board is my guess. If your not a technician it would be in your best interest to have him check L2C60 on the signal board.
Nov 19, 2007 | Mitsubishi VS-60707 60" Rear Projection...
Yellow brush marking on Screen
Your problem is with the blue color,maybe some dirt is sitting on the face of the blue crt and is being projected bigger to the screen,you should try cleaning the face of all 3 tubes,if you familiar with tv service this should help,be careful when removing the back and make sure the set is unplug when you do the cleaning.Let us know how it goes.
Oct 06, 2006 | Sony Grand WEGA KDF-60XBR950 60" Rear...
Sony KP-61HS10 61" Rear Projection Television Logo
98 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
