Question about Reddy R155D Utility Heater
Reddy heater 150,
Just blows smoke when pluged in makes ignition and fire but not burning
  • hartfarm Jan 10, 2008
    fixed crack in air pump housing, replaced it, now have to restrict air flow to get it to light
  • 232 Answers
HAVE OLD LAWN BOY 150 BTU HEATER WONT STAY FIRED EVERY THING ELSE WORKES JUST WONT STAY BURNING ON AND OFF AS FAR AS THE BURNER
There are a number of things that will cause the symptoms described. From as simple as water in the fuel to a more complex problem such as a defective Ignition Device (transformer, Spark box).
You will need to read & follow the tips attached and attempt to narrow the problem down.
Troubleshooting tips
Nov 05, 2010 | Reddy R60A Utility Heater
Comes on and runs and after a few seconds it will go out.it still has ignition and still spraying fuel /at this time it is blowing smoke then it will burn for a short time and go out again. it is a 75000...
cdoman,
This is a common problem with Reddy Heaters after they get a few years on them. Your air/fuel mixture needs to be set. I have a tip at http://www.fixya.com/support/r4124129-yearly_maintenance_reddy_heaters which explains the problem, where to get parts and how to complete the repair.
Thanks for using FixYa and for the generous rating!!
hardrocko
Sep 09, 2010 | Reddy Heating & Cooling
My reddy heater comes on and burns perfectly for up to 30 minutes then it shuts off and blows smoke for a couple of seconds before it completely shuts down.
This doesn't help. There at least 4 60k Reddy Heaters models -some are spark plug heaters, some have the new Hot Surface Ignitor technology. All heaters have specific model. Without you knowing the model I can't help, sorry.
Mar 14, 2010 | Reddy R60A Utility Heater
When filled with kerosene then plugged in, the heater will kick on for about 3 seconds and the fan will run but it will not ignite, then it shuts off. reddy heater 55, 55000btu. runs on K1 or fuel oil.
REDDY HEATER 40 KEROSENE FIRES UP FOR A FEW SECONDS AND QUITS WITH A WHITE CLOUD OF SMOKE COMING OUT THE END
MY REDDY HEATER 35 KEROSENE RAN OUT OF FUEL AND WILL NOT RUN AT ALL WHEN PLUGGED IN
Jan 11, 2010 | Reddy Heater-30-55,000 BTU Variable
I have a R-150. starts runs and fames out in 30 seconds and continues to blow fuel for about 20 to 30 seconds and then I assume flame sensor shuts it down. Im thinking ignition coil. Any ideas. Thanx
What usually causes that is the ignition component is not hot enough to sustain a hot enough temperature to keep the fuel burning some have a spark ignition some have a hot surface ignition,try replacing it and it should work fine.
Sep 02, 2009 | Reddy Heater-30-55,000 BTU Variable
Won't ignite and fill the entire tube with flame, cold air, smoke
The deisel fuel hogged it up. Clean everything out and replace the wick. Deisel fuel is filthy to burn and it needs a lot of airflow.
Jan 16, 2009 | Reddy Heater-40,000 BTU Kerosene w/T'stat
Blows smoke
Both problems soud like fuel delivery problems. Start troubleshooting fuel delivery problems by checking and getting the air pump pressure to specs.
Dec 09, 2007 | Reddy R155D Utility Heater
Reddy R155D Utility Heater Logo
289 people viewed this question
Top Reddy Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Mack Baxter
T bone 1963
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
