My washing machine isnt washing the clothes properly they smell really musty and ive checked the filter it seemed fine although smelt horrible.
  • 15,935 Answers
The first thing to do is to CHECK IN AND AROUND THE RUBBER DOOR BOOT (called a bellow) for small articles of clothing (like socks and underwear) that may have gotten lodged in behind the rubber. Pull the rubber back where it meets the wash tub and look behind it. It is common for small items to get stuck here, become forgotten and start to mildew. You should check this area after each wash and clean it periodically to get rid of the formation of soap scum, mold, and mildew. HINT: When you get ready to wash a load of towels, take a dirty towel and clean the door boot thoroughly (including the areas behind the rubber). Immediately place the towel in the wash and run it on a sanitary cycle. This way you eliminate the need for cleaning rags.
PERIODICALLY RUN THE WASHER ON A CLEANING CYCLE. Place the washer on the hottest setting you have (usually a Sanitary cycle) with nothing but bleach in the wash tub. Some newer models actually have a "Clean Cycle" available now just for this purpose. This helps keep the wash tub, drain lines and pump sanitized.
CHECK AND CLEAN THE DRAIN PUMP FILTER. Accumulations of debris in the drain pump filter can also cause odors. HINT: If you own a shop vac, pull the drain hose from the standpipe at the wall and pull a vacuum on the line. This will drain any residual water left in the tub, pump and drain lines BEFORE you remove the drain pump cover. This will prevent a messy clean up later.
LEAVE THE DOOR OPEN IF POSSIBLE. When not in use, leave the door open to allow the tub to air out and to keep mold and mildew from forming on the door bellow. I know this may not be desirable in some households with small children. If too much mildew forms on the rubber and it cannot be removed, replacement of the bellow may be required.
NOTE: This problem is common with front loader style washing machines. The doors on these machines have an air tight/water tight seal that is great for sealing the washer during the wash cycle, but can be terrible for collecting small garments and for not allowing the tub to properly air out when not in use. Following these simple preventive measures can go a long way towards preventing harmful mold and mildew, and towards extending the life of the door bellow and pump.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 15, 2010
My GE gfwh2400loww washer, the pump filter needs to be drained every 1 or 2 times a wash is done..otherwise water stays in, and when you drain it, it smells musty and horrible. I checked the manual,
You should not have to clean filter . Check your hose for clogs ,follow the hose all the way to where it drains into the sewer line. If your sewer line is very high up the pump may not be able to pump out all water efficiently. So some water will flow back down to the pump. If there is a clog up high, the clog will not allow draining. These pumps are strong ,but not that strong. Please let me know what you find. GOOD LUCK FRIEND.
Nov 17, 2014 | Washing Machines
Washing machine smells musty
there is dirty water still in the m/c do a boil wash with nothing in it buy some nice smelling conditiner and poor some of that in it also this is a tip from my mam leave the door open when not in use to let the insides dry out
Aug 24, 2012 | Kenmore Washing Machines
My LG dryer is about a year old and suddenly smells musty and mildewy inside! The washer is just fine (that seems to be the majority of complaints) but the DRYER definately smells. I clean the lint tray...
yes I have the same problem and can't find help anywhere...it smells like mold but my husband says like a dead animal and it gets smellier by the day. I leave the door open on both the washer
Jan 02, 2010 | LG Dryers
I have never liked my lg and now it seems that
You might check the water inlet valve on the back of the machine where the water hooks up. There should be a blue plastic water valve. remove the water hose on both sides hot and cold. At the blue water inlet valve inside the connector there are small filtering screens (similar to an areator valve on your sink faucet) They may be clogged by sediment and this would cause your low water issue and possibly the smell. Simply pull out the screens with a pair of needle nosed pliers and replace. Hope this helped
Dave
Nov 05, 2009 | LG WM2016C
It makes my clothes smell really bad
I am not familar with this machine...but
it probably has a lint filter on the washer somewher inside the tub. Probably close to the front. also these front loaders have a big rubber seal, check and make sure nothing has fallen in between them. They make a specific product for cleaning these machines, sell it on same isle as detergent.
Jul 19, 2009 | Samsung WF337AA Front Load Washer
Our Clothes smell musty and the washer smells too
clogged water screens , defective water level pressure switch , clogged drain, kinked drain hose ,. defective water pump , defective water tempeerture switch, damaged water valve solenoid , water inlet valve has an interal malfunction
Oct 03, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Musty odor in laundry
I would say that you are getting a build up of soap and oil from our bodies, on the inside of your wash bowl.
The Tubs pull out of the washing machine really easy and then you can water blast the two tubs.Solves this problem?
Once you learn how to pull the tub out you can also clear a blocked pump.
I have a after market lint filter fitted to my F&P washing machine,works wonders .
ask your local whiteware Man for some hints on a Bowl removal.
A five minute job???
Jul 27, 2008 | Fisher Paykel EcoSmart GWL15
Musty smell
Make sure the door is kept open when not in use and also make shure that you do the cleaning procedure as described on the book once a month.
May 18, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Musty smell, but can't tell from where
I have the same problem with a 3 month old ge front loading washer.after 1 month it started off smelling musty..I thought it was my imagination, now at 3 months old our clothes smell so bad I think we might just have to buy new clothes! everytime I wash a load the clothes smell worse and now you can even smell it just walking into our closet 2 floors up. A new washing washing machine should NOT be doing this! so far leaving the door open in between washes has helped a little but I plan on tipping it back and finding the hidden filter today. Isn't it lovely that they don't mention a filter that needs monthly cleaning or it's location in the manuals?!
Apr 25, 2008 | GE WBVH6240F Front Load Washer
Clothes Smell Musty and Damp
It sounds like a build up of washing residue. Clean inside the door seal and do a very hot wash with a bit of washing powder and no clothes. Repeat this once a week until smell has gone.
Oct 28, 2007 | Hotpoint WMA30 Front Load Washer
Washing Machines Logo
65 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
