Question about Whirlpool Duet GHW9150P Front Load Washer
Rubber seal is torn and water leaks onto the floor. How do I replace this?
  • 5,911 Answers
The rubber door seal is referred to as the "bellow". The following link explains step-by-step how to replace one:
http://www.fixya.com/support/r385211-replacing_door_bellow_whirlpool_duet
If you haven't purchased a replacement yet, the following websites are good sources for parts:
searspartsdirect.com
appliancepartspros.com
pcappliancerepair.com
repairclinic.com
Use your model number (located around the door opening) for your search criteria. Shop all these sites for the best price.
If you have any questions about this repair, or need additional assistance, please let me know. I hope you find this information helpful.
Posted on Sep 09, 2009
Leak in front
see this steps and fix it. God bless you
Drain Pump
If the washer is leaking water the drain pump might have a hole or crack. Or, the bearings might be worn out. Replace the drain pump if it is leaking water, they're not repairable.
Enter your model number to see parts for your washing machine.
Help me find my model number
Tub Seal and Bearing Kit
If the washer is leaking water the tub seal and bearing might have a tear or rip and is letting water leak past. The tub seal and bearing can be replaced. This is common and relatively easy to replace.
Tub Seal Kit
If the washer is leaking water the tub seal might have a tear or rip and is letting water leak past. The tub seal can be replaced. The tub bearing often gets damaged when the seal leaks. consider replacing the tub bearing along with the tub seal.
Tub Spin Seal
If the washer is leaking water the tub spin seal might have a tear or rip and is letting water leak past. The tub spin seal can be replaced. This is common and relatively easy to replace.
Tub Seal
If the washer is leaking water the tub seal might have a tear or rip and is letting water leak past. The tub seal can be replaced. When the tub seal fails water gets into the tub bearings and usually causes the bearings to go bad also. It is a good idea to replace the tub bearings with the new tub seal.
Door Boot Seal
If the washer is leaking water the front door boot seal might have a tear or rip and is letting water leak past. The boot seal can be replaced. This part can tear when the washer is overloaded. This is common repair.
Tub to Pump Hose
If the washer is leaking water the hose from the tub to the pump might be split or torn. Don't try to cut off the bad piece of hose and stretch it to fit the pump, this will put strain on the remainder of the hose and may cause a sudden and complete failure of the hose which will dump potentially hundreds or thousands of gallons of water onto the floor because the next time the washer tries to fill all of the water will end up on the floor and so the washer will never shut off the valve. Any time there is a damaged hose, replace it completely with the OEM part.
Washing Machine Fill Hose
If the washer is leaking water, check the fill hoses on the back of the washer, this is the most common place for water to leak. If the washer still has the original black rubber fill hoses replace them with stainless steel or some other, more durable hose.
Drain Hose
If the washer is leaking water check the drain hose. The most common places for the hose to spring a leak is from the connection to the pump out to the back of the washer. Another common occurrence is when the washer gets pushed too far back against the wall.
Jul 09, 2013 | Bosch Nexxt Platinum WFMC640SUC
Leaks water
see this causes and fix it. God bless you
Drain Pump If the washer is leaking water the drain pump might have a hole or crack. Or, the bearings might be worn out. Replace the drain pump if it is leaking water, they're not repairable
Tub Seal and Bearing Kit If the washer is leaking water the tub seal and bearing might have a tear or rip and is letting water leak past. The tub seal and bearing can be replaced. This is common and relatively easy to replace.
Tub Seal Kit If the washer is leaking water the tub seal might have a tear or rip and is letting water leak past. The tub seal kit can be replaced. This is common and relatively easy to replace.
Tub Seal If the washer is leaking water the tub seal might have a tear or rip and is letting water leak past. The tub seal can be replaced. This is common and relatively easy to replace.
Tub to Pump Hose If the washer is leaking water the hose from the tub to the pump might be split or torn. Don't try to cut off the bad piece of hose and stretch it to fit the pump, this will put strain on the remainder of the hose and may cause a sudden and complete failure of the hose which will dump potentially hundreds or thousands of gallons of water onto the floor because the next time the washer tries to fill all of the water will end up on the floor and so the washer will never shut off the valve. Any time there is a damaged hose, replace it completely with the OEM part.
Washing Machine Fill Hose If the washer is leaking water, check the fill hoses on the back of the washer, this is the most common place for water to leak. If the washer still has the original black rubber fill hoses replace them with stainless steel or some other, more durable hose.
Drain Hose If the washer is leaking water check the drain hose. The most common places for the hose to spring a leak is from the connection to the pump out to the back of the washer. Another common occurrence is when the washer gets pushed too far back against the wall.
Sep 30, 2012 | Washing Machines
Leaks from underneath
Drain Pump If the washer is leaking water the drain pump might have a hole or crack. Or, the bearings might be worn out. Replace the drain pump if it is leaking water, they're not repairable.
Tub Spin Seal If the washer is leaking water the tub spin seal might have a tear or rip and is letting water leak past. The tub spin seal can be replaced. This is common and relatively easy to replace.
Sep 30, 2012 | Kenmore Elite Washing Machines
I have a 1992 Honda Accord and whenever it rains, water leak through the speaker on the passenger side door and make a big puddle on the floor. Also the water leaks into a hole in the floor by the ECU
Not comming from the speaker! Make sure that the rubber door trim aound the door is intact and not damaged. Additionally, check the rubber seal on the outside of the window where it retracts into the door. These are the only 2 ways that water can enter through the passenger door.
Feb 11, 2012 | Honda Accord Cars & Trucks
Dishwasher is leaking in front onto floor. Water level during washing seems too high. Float is not obstructed by any object. What can I do next?
if it seems to be coming from the front it may be the rubber door seal they are not to expensive and not very hard to change if it is leaking under machine it may be the seal that sits on top of motor if water is leaking around motor the seal in the bottom of the washer is damaged
Dec 17, 2009 | Washing Machines
Piece of rubber came out torn. water leaks out
door seal must have hole in it replace hole at bottomof seal
Jul 06, 2009 | Washing Machines
The rubber seal kenmore 3.8 cu ft he3t king size capacity
Our rubber seal was torn and we had a Sears repairman replace it - he said it required a special tool to install it (which he didn't have) but through some long and physical process, he was finally able to get it on.
Jan 26, 2009 | Kenmore Elite 45986 Front Load Washer
My AEG 6200 Digitronic washing machine is leaking from the front door seal down the front and onto the floor. Is this a common problem and can it be fixed? - for example by replacing the opening rubber...
Peace BeeSuit,
Happy to be of assistance,
You asked:
Your, AEG 6200 Digitronic washing machine is leaking from the front door seal down the front and onto the floor.
- for example by replacing the opening rubber seal?
Yes I believe that replacing the rubber seal is usually the answer.
How old is the unit? And is the washer working well other wise?
Is it draining and not smelling like mold in side?
Some times in an old machine the pump does not completely dran out and it could smell like moldy water! Then if it's aged. I would consider not fixing both of these to problems in a washer 10 years or older not to put good money in to bad!
But if the leak is the only problem, go for the seal!
Happy to of assisted and made a different s in your life!
Bless you,
Huuum
Please give me a good rating for my sound advice before you sigan off.
Thank You
huuum
Sep 12, 2008 | AEG Washing Machines
Ge washer
Hi.
I would check the rubber seal around the door - down at the bottom, to see if it has perished or got torn.
Does it leak only when running or all the time - that is, when powered off and idle?
If these suggestions do help you solve the problem, please give my reply a rating to help others judge my knowledge / guessing skills. If they do not, please add a comment with more details so I can try to help you further. Cheers, D
Jun 17, 2008 | GE Profile Prodigy WPSE4200A
My whirpool washer leaks onto floor.
if you can open panel see inside , and look to check where its leaking from , if you see water leaking from the center under the tub , you need to replace the rubber seal ,hope this helps AJ
May 05, 2008 | Washing Machines
Whirlpool Duet GHW9150P Front Load Washer Logo
191 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
