Question about HP Computers & Internet
Hi- Ihave an HP 745/165L with a bad power supply, part# 0950-2690. It has a bad Thermistor labeled 740018 C1. Can someone tell me where I can get this part or at least the spec of this parts so I can substitute a comparable component?
SOURCE: Panasonic PT40LC12 - Blinking green power light - no lamp fire up.
Had similar issue but had high resistance across leads. replaced with thermal fuse from RadioShack in the similar temp and everything works great. Info on the original part is on this link. http://www.willas-array.com/prod/products/directory/pdf/sefuse/FUSE_SMG.PDF Hope that helps. Chris
Posted on May 29, 2007
  • 7 Answers
SOURCE: power supply "Starmen TOD0851212" for my AKAI 20
If you can do it yourself replace C31 (1000 25v) also good idea to replace C32,35 also (1000 uf 25v). Theres also C33 (680 uf 25) if you want to replace it.
Posted on Jan 18, 2008
  • 13433 Answers
SOURCE: Computer Components
the component, you need to take it with you and show it to someone in electronics repair they can possibly sell you a replacement or direct you to where to get one. I don't have and I don't think there are any service manuals available for computer powersupplys publicly as most people and shops replace them instead of trying to repair.
Posted on Oct 07, 2008
ProsunPal
  • 60 Answers
SOURCE: Problem identifying P4G533-LA motherboard electronic component
Its a diode but where can u find it ? Before replacing this check your powersupply. The parts number will be the same as beside.
Try carefully. You have a small hope.
Posted on Feb 14, 2009
  • 16 Answers
SOURCE: Gigabyte GA-8SIMLNF Rev 1 motherboard specs + help
The following power supply unit (PSU) should work just right, however, it will not fit in a company branded case such as HP, Compaq, Gateway, Dell, etc. sine they all use proprietary parts and cases:
http://www.newegg.com/Product/Product.aspx?Item=N82E16817339019
Posted on Jul 03, 2009
Magnets will not ingage
I repaired the same symtom that happend to one of the sides of my CPT-180 toaster. The magnets wouldn't engage due to a bad C1 capacitor on the circuit board that controlled that side of the toaster--the capacitor was bulged out on the bottom and turned out to be bad. I've attached some photos showing C1 bulged out compared to C1 on the good board.
C1 is the main power supply capacitor and if it goes bad, the circuit board power supply won't function correctly. This can lead to a broad spectrum of problems like the lever not staying down due to the magnets not engaging or the toasting control/timing circuits malfunctioning. If you replace the capacitor, it is best in most cases to replace with the same value as the orginal (220uf on my toaster)---you can usually get a replacement capacitor at Fry's Electronics. Replacing with a higher capacitance may be acceptable, but you should understand the impact to the rest of the circuit before you substitute a higher capacitance value. The voltage rating and temperature rating of the replacement capacitor should be the same or greater or the capacitor will fail quickly. Note the max temperature rating of capacitor C1 is +105C---toasters get hot (duh!) and the temperature around the circuit board of this model gets quite warm, so the temperature rating of the capacitor is critical. Finally, make sure the substitute capacitor fits when installed (requires soldering) and does not interfere with surrounding circuitry or other toaster mechanics when the circuit board is put back in place.
Pictures:
C1_location (next to screw)
Comparing_good_C1_with_bad_C1--note bulge on bottom of right C1
Right_orginal_C1_and_left_replacement_C1
Bad_C1 showing capacitance, voltage and max temperature ratings
5487aa4b-7e7d-4e6f-9542-cf9ff618008c.jpg2d853c87-48b6-4735-99f4-fdd5dbc60ffe.jpge1a82299-a243-46e1-b11b-4c20e0d9b304.jpg5543b7e5-8108-4b1d-bed3-90eee4600722.jpg
Mar 28, 2014 | Cuisinart CPT-180 Metal Classic 4-Slice...
The Rice cooker stop working, no heat , no power.
Looks like the thermistor pop up! Thermistor is a fuse protector, protecting ur unit from overheating. In certain (max ) temperature it will cut off the power! It usually looks like a white resistor w/ some label on the side and temp. label
If you have a continuity tester, you could replace it by urself, by opening the bottom of the cooker.
If u have no knowledge wutsoever, a simple eletrician could repair it.
Hope that helps u out!
Jun 16, 2011 | Panasonic Kitchen Appliances - Others
My toshiba regza model 32wl68p is difficult to turn on from standby.Ihave to unplug in and retry numerous times before it turns on
Please replace bad capacitors in power supply board or replace complete power supply board available HERE to solve tv problem.
Thanks.
Jun 09, 2011 | Toshiba Regza 37HL17 37 in. LCD TV
Ihave hp pavillion dv7 1245dx when you power up it acts like its locked in hibernation everything is on and the cap lights blink but the screen stays dark ...
I suggest try to do a Hard Reset on your machine by removing the Battery, unplugging the Power Cord and after that Press and Hold the Power button for about one minute without any supply on the machine. After that put it all back in and see if still doing the same problem, If its still doing the same problem count the blinking lights on your caps lock it indicates what could be the hardware that's faulty on your machine then call the manufacturer's tech support and tell them that it gives you that kind of problem.
Feb 16, 2011 | HP Pavilion dv7-1245dx Notebook
I recently got this laptop from someone who did not have the power supply with it. Can anyone tell me what the required power supply must output? I really don't want to fry this computer, so I want to make...
You need a charger with this features: 90W Laptop AC Adapter / Charger for HP Pavilion DV5-1125NR / DV5-1127CL Replacement
Diameter : 5.0 mm x 7.4 mm
Input Volt Type : AC
Input Volt: 110-220V (Worldwide Use)
Output Ampere : 4.74A
Output Power : 90 Watt
Output Volt : 19V
You can buy one at:
http://www.buy.com/prod/90w-laptop-ac-adapter-charger-for-hp-pavilion-dv5-1125nr-dv5-1127cl/q/loc/101/215845345.html
for $19.89 including shipping.
If this was helpful, please rate me.
Thank you
Jan 13, 2011 | HP Pavilion dv5-1125nr Notebook
Hi my machine has a 10.00.00 supply memory erro message can you tell me what is wrong with it please
Memory Supply Error 10.00.00 The printer is unable to read or write to the print
cartridge e-label, or the e-label is not on the cartridge.
Basically what is happening is the printer cannot read the small chip on the toner cartridge. The chip is located on toner cartridge as it is inserted into the printer. 1 - Make sure the toner is firmly seated into the printer. 2 - Power cycle the printer with the toner out of the printer. Install the toner back into the printer. 3 - Install another toner cartridge. 3 - Verify that the e-label connector is firmly seated in connector
Contact a local HP Authorized Service Center for further assistance.
Aug 03, 2010 | HP LaserJet 5550 Printer
Which power supply box goes to the HP scanjet 2200c?
It should give the voltage/wattage on the scanner and the power supply.
Voltage Required AC 110/220 V ± 10%
  • Power Consumption Operational ( Standby ) 19 Watt ( 6 Watt )
  • Jul 22, 2010 | HP ScanJet 2200C Flatbed Scanner
    HP Pavilion XT983 using a Bestec Power Supply ATX 19956D Computer will not start,no fan and the LED light is on but very dull. Does this mean that the power supply is bad or could it be the Mother Board. I...
    hi this could be that the power supply may not be powerful enough to run the laptop, as some laptops run 12v power, where as some use 9v power if you know someone with a power supply try using theirs, if your laptop is 9v and you are using a 9v then this could be a short on the system board, so the only thing i can suggest is try another power supply first before condemning your laptop...hope this helps please vote thanks
    Mar 03, 2010 | HP Computers & Internet
    Hp f2105 only stays of for 2 seconds
    Hi there mate i have a hp f2105 with the benq power supply in it which as gone faulty could u look at your power supply and tell me the numbers on the power ic which is ic651 thanks.
    Jan 13, 2009 | HP f2105 21" LCD Monitor
    HP FLAT SCREEN TV BLINKING POWER LIGHT/BLACK SCREEN
    sounds like the power supply has gone bad.
    Jan 04, 2008 | Computers & Internet
    Computers & Internet Logo
    90 people viewed this question
    Top HP Computers & Internet Experts
    Tony
    Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
