Question about Panasonic Televison & Video
Can you help me with a vcr recording problem? Since the digital tv conversion, I have not been able to get a signal or record anything with my vcr. I bought a new digital tv (Samsung model LN32B360 C5D 32'') (TV works fine) The hookup I have is Coax coming into the house to the the vcr input and av cables from the vcr (Panasonic PV4022 purchased in June of 2002) to the tv output (also have coax from the vcr to the tv). The cable company is MDU which has a dish on top of each of our buildings and an antenna on the individual units. When I try and program the vcr it only gives me a choice of L1,L2, and ch 38 for channels. When I hit the VCR/TV button to switch to vcr, I get this message on the screen ''weak or no signal''. Is the problem that the vcr is too old or is it the cable company, or do you have an suggestions as to how i can set this up to record - preferrably recording one channel while watching another.
  • Panasonic Master
  • 5,190 Answers
Sometimes the connection cable between the devices is the cause of weak signals. If you are using coax, to carry digital signals, make certain it is the stuff they use to link up sat dishes. You can tell if it is by looking at the end. With the plastic covering cut away it should have a solid silver foil around a plastic tube which contains the wire. If it has a mesh as a screen (with holes) it should be replaced with the sat cable. This will improve the signal by over 60%.
Sometimes you can tell it's the old coax cable because it's brown in colour.
Posted on Sep 26, 2009
  • Panasonic Expert
  • 244 Answers
If the vcr is an older one then it will only have an analog tuner,so if your signal is now only digital then it will not work.
Posted on Sep 16, 2009
My vcr recorded my shows before i switched to a digital adapter now i cant get it to record anything ive tried everything
If the digital adaptor is connected to your TV, then the VCR will not get any signals to record. The VCR will also have to be converted, by adding another digital box, unless the first box has two digital tuners! You can connect another box if the VCR has two scart sockets, the second box connected to the other scart socket. To record after connection, leave the box on, set to the channel you want to record, and set the timer on the video. However when selecting the channel to record make certain that you select the scart socket with the box connected to it. Also make certain (if the VCR has it) PDC is set to OFF as it no longer works.
This way you can record shows while watching anothe channel.
Jul 16, 2011 | RCA VR525 VCR
Hi,can I record digital transmissions on my sony slv-se820g vcr barry
You can record a digital TV signal on a VHS VCR but only in analog format. The digital signal must be input to the VCR by some component which has a yellow composite video output and a white audio output such as a digital cable TV box or satellite receiver. For over-the-air digital TV, either the TV must output analog video or you need a DTV converter box connected to the VCR. Bottom line, the digital signal must be converted to analog for the VCR since VHS VCRs generally are analog recorders.
Apr 12, 2011 | Sony SLV-SE820 VHS VCR
Are you truly free? If so, then answer the
Hello. Your digital TV is all set up to recieve the digital signal that is now the standard signal coming into your home. The old analog signal is history. If you still want to use your VHS/DVD recorder you will have to get a signal conversion box, at your local walmart or radio shack. This will take the new digital signal and convert it so your old analog VHS/DVD can process it properly. Joe
please rate my answer as very helpful....and free. thanks. Joe
Apr 26, 2010 | GoVideo Go Video DVD/VCR Combo
How do I record a tv program with a Sharp A400 VCR? Videos will play on the tv, but I was not able to get it to record. Thanks.
Your VCR is no longer capable of recording "off air" tv signals. All tv stations are now broadcasting in digital format, your VCR is analog only. You can however get a digital converter box that will receive "off air" digital signals and convert them for recording on your VCR. CLICKING HERE will give you all the information you need to hook up the converter box... Good Luck!
Nov 10, 2009 | Sharp VC-A410U VCR
Are there problems recording to a vcr when using a digital converter box?
Not at all, as long as the channel selector on the back of the VCR is set to channel 3 to receive the signal and record. Connect the digital convertor box to the VCR. Connect a second co-ax cable to the TV to complete the signal loop. Tune your TV on the channel you want to watch/record. Put the VCR on channel three on the display screen. Try recording and play it back. This will ensure all your connections are correct. Hope this helps, if not let me know.
Oct 27, 2009 | Zenith VR4207HF VHS VCR
I have a Sylvanis VCR/DVDcombo and a Standard TV.
The converter box receives hte digital signals and converts them into either channel 3 or 4, or into direct video (red,white,yel). The output of the converter box must go into the VCR input for recording to work. Before the conversion, the tuner of hte VCR would receive the RF signal the same as the TV. The tuner inside the VCR is an analog tuner not digital, so it needs the conversion too. Most converters will provide both the A/V signal (R/Wh/Y) and RF (coax connector).
Hope this helps,
Dan
Sep 30, 2009 | Sylvania 6720FDG 20" TV/VCR/DVD
Comcast Digital Conversion box (cable TV)
You will have to split the signal before it goes into the digital box. The digital box is not allowing the analog signal to go to your vcr so you will only be able to record what you are watching on the cable box (on channel 4). If you split it, you will get all your analog channels back on your VCR (the way it was before the box was added).
Jun 29, 2009 | Allegro DVD/VCR ABV511
VCR will not record (PV-V4624S)
SET YOUR TO RF LEVEL " LOW" OR YOUR CABLE CONNECTION IS WRONG CHECK IT.IF THE PROBLEM REMAINS, CHECK IT ON STANDARD DEFINITION TV FOR RECORDING.IF THE PROGRAM RECORDS OK THEN IT ID NOT COMPITIBLE FOR DIGITAL SIGNALS. BUT IF NO RECORDINGS PERFORM CHECK THE VIDEO HEAD CLOGGINGS OR MAY BE MAIN "IC" PROBLEM.
Feb 21, 2009 | Panasonic PV-V4624S VCR
VCR with intermittant audio and video problems
you have to connect VCR output cable to your TV input, thats all, it will be in series, if u want to record any program then on your TV and on record switch of your VCR.
Dec 30, 2008 | Sony SLV-N55 VHS VCR
Panasonic PV-V4021 VCR.
An analog VCR can only be used the same way as an analog TV. You should be able to set the VCR to the converter boxes output channel ( 3 for example) and then set the VCR to record that channel at the correct times. Then just tune the converter box to the correct channel. Please note that if you try this while you are at home (recording one thing while watching another) you will wind up recording whatever is on the channel you change to.
Oct 11, 2008 | Panasonic PV-V4021 S-VHS VCR
Televison & Video Logo
183 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
