Question about Reddy R155D Utility Heater
Blows smoke My heater does not fully ignite some fier but just smoke comes out and seems to be fire inside chamber
  • jinks137 Dec 16, 2007
    my reddy heater seems to be doing the same thing. it tries to start but it keeps shutting down after a few seconds. it does this on and off for a few times then just blows smoke.
  • 232 Answers
Both problems soud like fuel delivery problems. Start troubleshooting fuel delivery problems by checking and getting the air pump pressure to specs.
Posted on Dec 26, 2008
I OWN A 1996 NISSAN QUEST GXE THAT'S BLOWING BLUE SMOKE FRONT FRONT DRIVER SIDE TIRE AND I CAN SMELL ANTI FREEZE INSIDE.. I JUST BOUGHT VEHICLE AS A COMMUTER.
Sounds expensive. Blue smoke usually means oil in the combustion chambers, from worn out rings. Anti-freeze inside means leaking hoses or heater core. Not sure where the driver-side tire comes into this, unless that is where the smoke is coming from, in which case that likely a problem with a seized brake caliper.
May 21, 2016 | Nissan Cars & Trucks
Water spills out of my blower on my starite pool heater model sr33na. Is it a gasket?
Oh Oh, Not Good : (
Heat Exchanger / Tube Sheet Coil Assembly has Ruptured.
It is encased in a closed combustion chamber. Water flows thru it and it is in that chamber/tank with the fire burners, heating the water within the coil. Forced air via the Blower blows into that chamber / tank and out the exhaust vent. That's it! Only air.
If water blows out, then the "Closed" Heat Coil, has ruptured.
Start looking around page 49 & onward, and you will see the breakdown parts diagram of that chamber / tank, with the coil inside.
The Manual is here...
http://www.pentairpool.com/pdfs/MaxEThermEngOM.pdf
Good Luck to You, and sorry for being 'that' guy bringing you bad news!
Jun 13, 2015 | Sta Rite Pool & Spa
Heater blows smoke out front, wont ignite...please help!
Two things cause it ,No fire at Spark plug or low air pressure
Jan 22, 2011 | Reddy Kerosene Heater with Thermostat:...
Smoke or vapor coming from new h400fdn hayward pool heater.
Not at all uncommon. New heaters have to glaze over the file tile in the burner chamber and will often smoke and smell during the first week or so of operation.
Using a mirror, check to see that your flames are about 4" proud of the burner tubes when running. As long as they are and the color is a nice blue with little to no yellow/orange color, the heater is fine.
May 28, 2009 | Hayward H Series Pool & Spa Heater 400k...
I have an older reddy heater pro 100 kerosene space heater,
You Must set the pump pressure quickly! If allowed to run with the nose cone a "bright" cherry red the welds will deterioate to the point that the end will separate from the combustion chamber. Individual sheet metal parts of the chamber are not available.
Learn how to properly set the air pump pressure
Feb 25, 2009 | Reddy HEATER RLP100 100,000-BTU PORTABLE...
Runs a few minutes and quits
hi this could be 3 problems ? no spark so vapour not igniting so excess vapour coming out as smoke, if it ignites stays on for a while goes out the flame probe is faulty, fuel filter is blocked needs new one , the fuel pipe going into tank has a non return vavle in it ( its a plastic ball in line with pipe ) if this is missing or stuck it allows fuel to drain back into tank and causes a air lock in heater causing vapour into chamber result in smoke coming out of end, as a quick fix for that you can fill pipe with fuel bend it so its traps in fuel like fire place pipe in tank when stopping fire stick mole gripps on pipe so next time fuel is there ready
Jan 22, 2009 | Reddy Heater 60,000 BTU Kerosene...
No heat, just smoke, flame inside,
MORE THAN LIKELY NEEDS SERVICED START BY REPLACING FUEL NOZZLE WITH THE SAME NUMBERS THAT ARE ON THE OLD ONE SHOULD HAVE 2 NUMBERS ON IT DEGREE AND GPH RATING MATCH BOTH GOOD START AND LEAST EXPENSIVE AND MOST COMMON PROBLEM FOR WHAT YOU DESCRIBE
Jan 16, 2009 | Reddy Heater-30-55,000 BTU Variable
When i turn on the heater it just blows smoke
according to desatech who makes reddy heat, the air compressor on the back of the fan should put out no more than 3.5 psi to the nozzle. you could also check the air path through the combustion chamber. sounds to me that the nozzle isn't atomizing the fuel but its coming out in a stream. the nozzle is supposed to make a conical pattern if the air pressure is correct.
Dec 13, 2007 | Dayton E52 Utility Heater
Reddy R155D Utility Heater Logo
176 people viewed this question
Top Reddy Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Mack Baxter
T bone 1963
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
