Question about NorStar Nortel Venture EFA Phone
Norstar compact plus- can't get line access
I've just replaced an aged norstar unit in a large private house with a compact plus (System version SP:30AYF07 GP4) and an NTB30AAAA analogue trunk. There are no other cards bar an old NTBB30AF which is not used as it does not offer Caller ID, and the software card. The whole system works really well BUT I cannot get an outside line at all, the signal is fine and strong if i wire a phone to the amphenol plug in the unit. I cannot access the profile programming on this board using feature **profile and config code which then just logs out of programming. All the jumpers on this analogue line card are set to the lower position. We keep getting "No dial tone" message on the phone. I Really dont want to run costs up so any help would be appreciated.
  • 60 Answers
Make sure your wiring the co lines on the first 2 pins of the 66 then space 2 then lines 3 and 4.
Posted on Jul 29, 2009
Caller ID not working on Norstar terminal using line dedicated to fax and phone
You must have latest software to have Caller ID
You must have a Caller ID line card
Caller ID must be programmed on the phone to allow it
Caller ID signal from carrier is sent between 1st and 2nd call
FYI on the fax: Analog ports (ATA's) on the Norstar system do not show Caller ID, instead you would need to use a line share device that supports caller id such as the STICK.
Oct 25, 2012 | NorStar M7310 Corded Phone
Hi, Can any body help us? We have a M7324 on a Norstar Compact with two line pools, Pool A is on Line 1,2,3 and Pool B on Line 4,5. We want to add another line on Pool B so I tried configuring Line 6 which...
On the cross connect do you have a CO connected to that line. That is most likely the cause of no dial tone. If you don not know how to check that call a phone system expert to connect and verify your system.
Feb 15, 2011 | NorStar M7324 Telephone
We lost power and when our Meridian M8X24 phone system with T7316E phones came back up we only have access to 2 lines. How do we gain access to the other lines again.
Sounds like your norstar system needs to be reprogrammed because norstar defaults back to only 2 lines when the inturnal battery fails.If the inturnal battery has failed and you reprogram this phone system and you have another power fail you will have to have you system reprogrammed again.Time for new system.
Sep 30, 2009 | NorStar T7316E Corded Phone
NorStar ICS Caller ID Upgrade
Yes, this is correct. install the co card with cid and you should be fine.
Jun 07, 2009 | NorStar Compact Ics WithClid Trunk Mod...
Attendant still completes call after caller hangs up
Check and make sure that the disconnect clear time of ur Norstar is 800ms.
Apr 02, 2009 | Ics Norstar MICS (0x32) Modular Cartridges...
Nortel Meridian Norstar-Plus Compact ICS with #7310 phones.
I'm pretty sure CID is automatic on a CICS....IF you have a CID trunk card. You might want to post the part number on the face of the trunk and we'll see if it's the proper one.
Jan 08, 2009 | NorStar M7310 Corded Phone
Norstar Flash problem
Cycle the power on the voicemail system. If that does not work, you may have to replace the voicemail power supply, or send the voicemail system for repair.
Good Luck!
Oct 17, 2008 | NorStar Flash Voicemail Power Supply Only...
Unit will not access call pilot
Start with "Feature 9 (star) 1" from a Norstar telephone, to view the CallPilot Feature Code list. Then enter the System Administration feature code.
Good Luck.
Sep 04, 2008 | NorStar Compact Ics WithClid Trunk Mod...
Compatability Issue?
What port is the line in? You will have to look in system programming under maintenance. Look and see if the port is enabled or not?
Nov 06, 2007 | NorStar M7208 Corded Phone
NorStar Nortel Venture EFA Phone Logo
177 people viewed this question
Top NorStar Lands Phones Experts
Oloyede Monsuru
Are you a NorStar Lands Phone Expert? Answer questions, earn points and help others
