Question about Dirt Devil Royal Sovereign 9000 BTU Portable Air Conditioner with Heater
A fine mist sometimes srays out of fan when ac is on
    President:
  • 1,564 Answers
Put an old facecloth outside the window in the tray a the base of the core on the outside, tuck it in about an inch UNDER the core do not bend or move the fins on the core(actually called a condensor) The face cloth will act as a siphon/evaporator, and remove most of the water that is colecting in the tray.
Posted on Sep 08, 2009
Where can I find replacement mister nozzles for a Hawaiian Breeze misting fan
They are not available Debbie. What is wrong with the ones in yours? If they are clogged you can clean them with CLR or white vinegar. Or set up a patio misting nozzle in front of it.
Patio misting nozzles are readily available. Your fan is discontinued.
http://www.bing.com/search?q=+Hawaiian+Breeze+misting+fan+nozzles&qs=n&form=QBRE&pq=hawaiian+breeze+misting+fan&sc=0-27&sp=-1&sk=&cvid=EBB007E7ED6D49A6BD8E6A22CCCC31E0
Jul 09, 2016 | Dryers
My 1999 Blazer has heat but will not blow air. The fuses are fine
I would check for a bad connection on the blower motor resistor.Its located on the passenger side mounted on the heat duct with 2 screws.Turn the ignition and fan switches on then wiggle and pull on the connector usally if the resistor has a poor connection it will comw on.These resistors get hot and sometimes they melt the connector causes it to loose its connection.
Jan 22, 2012 | 1999 Chevrolet Blazer
I have a frigidare ac window unit 6000 btu getting a fine mist blowing out of vents its still cool and works fine but whats causeing the mist ty in advance.
I am getting that too today... nothing wrong, just a very. very humid day....
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool...
AirConditioner Trouble - Review the Possibilities
heatman101
Aug 07, 2011 | Frigidaire Heating & Cooling
Heating AC problem
It sounds like the heater core is leaking engine coolant into the passengers side compartment. White mist could be steam from the hot coolant? The Heater fan could be damaged, or it is a short. Fill your radiator and take it to the shop or replace the heater core.
Jul 19, 2010 | 1997 Oldsmobile Cutlass Supreme
Honda acac sometimes blows some kind of dew air throught he vents
u most likely have some condensation building up in evap box ,,need to clean it out before it gets worse,,,if u are running it on low blower ,it is going to put out mist sometimes (if the air is really cold) because of the expansion valve pulling down the tempurature
Jul 06, 2009 | 1996 Honda Accord
New AC unit mist
It sounds like the unit is either level or tilted down in the front, not allowing the water to run to the back of the ac and the blower wheel is picking the water up and blowing it into the room.
You need to put a level on it and lower the back of the ac so the water the coil removes can run to the back of the unit and that should solve your problem.
Jun 07, 2009 | Friedrich WallMaster WS10B30 Air...
Family Care cold mist humidifer
cool mist humidifiers don't put out any mist. only the warm ones do. now if you put your hand over the area where it's coming out for about 2 minutes and take it away your hand should feel damp. almost clammy. if it feels like that the unit is working fine. so your not doing anything wrong. if you have any other concerns please let me know.
Mar 13, 2009 | Family Care HM1555 Humidifier
Condensation question
Yes there is a hole in the rear underneath.  Make sure that it is not plugged.  The ac needs to be cleaned every year for good workmanship.  Make sure that the ac is tilted back allittle so the water or condensation will drain.  Sometimes I've seen one where it was tilted towards the inside of the house and the fan would pickup some of the water and put a mist in the house which is not good.  If We can be anymore help let us know and thankyou1
Mar 11, 2009 | LG Goldstar GWHD5000 wall/window Air...
No mist
i would try cleaning the coils for the heat portion. if they are to scally that could be one reason why it's not making any mist. but if it looks pretty clean or if you have cleaned it and it's still not making any mist then it's something internal. now if your under warranty still that's a good thing. you can always call the manufacturer and they can replace theunit for you under warranty . if you have any other questions please let me know.
Feb 26, 2009 | Holmes Products HM500-UC 1 Gallon...
Heating & Cooling Logo
Top Dirt Devil Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
Are you a Dirt Devil Heating and Cooling Expert? Answer questions, earn points and help others
