Question about Bissell 8930M Upright Steam Cleaner
What size belts do I need? - Bissell 8930M Upright Steam Cleaner
  • 268 Answers
Here is a link for your model. Scroll towards the bottom and you'll see instructions with illustrations for belt replacement and when you scroll down more, you'll see the part numbers for you model.
Hope this helps.
http://www.bissell.com/images/UserGuides/9200_908.pdf
Posted on Sep 08, 2009
What size belt??
The Eureka Whirlwind 4489 uses style U belts, and you can find the Belt Package Assembly- Style U 2pk at the following link:
http://www.vacpartswarehouse.com/Eureka-Electrolux-Sanitaire-Belt-U-Style-2-pack-p/61120.htm
The broken belt usually stays trapped within the housing, so when you remove the necessary pieces in order to access the beater bar, you should find the remnants of the original belt, which you could also use to determine the size you need for a new belt. You might even get lucky and find that the belt itself is ok, but had gotten derailed somehow! Also good to remember is that there is often a second belt sealed within the packaging and instruction manual, so you may already have a spare belt on hand if you stashed the owner's manual somewhere.
Hope that helps! Please rate as helpful if so :) Thanks!
Jul 01, 2014 | Eureka Whirlwind 4489 Upright Vacuum
What size of belt do i need for dirt devil classic M08100
Hi! This hand vacuum takes a Dirt Devil style 1 belt. I have included a link where you may go to purchase the belt if needed. Hope this helps!
Style 1 Belt 2 Pack
May 03, 2014 | Dirt Devil Classic M08100 Bagged Handheld...
Why is the new belt on my dirt devil featherlite repeatedly slipping off? Everything else on it works fine and the b elt is the correct size.
Hello! There is no other part that goes on the motor shaft after the belt is put on. The tension of the belt keeps the belt from slipping off. If you have a brand new belt that keeps slipping off you may not have the correct belt for the vacuum. Be sure you replace with a genuine Dirt Devil belt and the specified belt style for your particular unit. Hope this helps! If you still need assistance feel free to reach out to us here on Fixya, Facebook.com/dirtdevil, or Twitter @DirtDevil.
Apr 28, 2014 | Dirt Devil Vacuums
The brush does not turn on
Needed new drive belt Flip over vac take screws out of peace covering belt Can get new belt at vac shop or Canadian tire should say belt size on the belt cover does on most vac s. if not bring your old one with you
Feb 16, 2013 | Vacuums
Trying to change belt
The procedure for changing a belt will vary depending on the type of vacuum you have. However, I can give you some general guidelines. Unplug the vacuum and turn it over. Generally there will be some type of cover you need to remove to expose the beater bar. This cover can sometimes be removed by taking out screws and sometimes there are plastic tabs you need to push in with a screwdriver to loosen it. Once this cover is removed you will probably see the broken belt. You need to buy a replacement belt of the same size. You can probably look up your vacuum online to find out what size you need. You can also take the old belt to the store and match it up with the available new belts. Once you have a new belt you need to remove the beater bar. The ends of the beater bar will probably fit into some type of indentations or slots. Pull on the beater bar and it should slide out. Place the new belt around the beater bar. Also hook the belt around the metal motor stub located near the rear and to one side of the exposed underside of the vacuum. Now insert the beater bar back into its original slots. This will require pulling hard on the beater bar to stretch the belt forward and away from the metal motor stub. Replace the cover and you’re good to go. I hope this helps you out
Mar 30, 2010 | Vacuums
Riccar 8800 belt replaced but now floor brush won't spin
Are you sure that you get the right sized belt? This is the correct one you need:
Riccar 8800 Belt
Dec 15, 2009 | Riccar 8850 Vacuum
Majestic filter queen vacums
Your belt is either stretched or the wrong size or the brush bushings are worn and allowing the brush to wobble or the motor is loose in its housing. You need to check all.
Rotate the brush and try to wobble it from the pulley end.
Flip the belt inside out, it if appears cupped, cracked or shiney and slips easily on and off the brush it is stretched. Generally this unit needs anew belt evrey 6 months, broken or not, they get hot and stretch. Do not buy a new belt by matching size, a worn belt can be 20-30% oversized and not broken but totally useless.
The motor shaft should be cleaned with W/D 600 grit sand paper. Motor should have no wobble in the shaft
Sep 09, 2009 | Vacuums
The power drive belt of my hoover u3305-030 vacuum keeps falling off, what am I doing wrong?
Hello
One possible solution to your problem is you have the wrong size belt. Check your belt, it should have a letter on it, if it is old, it may be stretched out. Check in your owner's manual, near the belt area, or on the inside of any cover for the correct belt size(which is a letter). Be sure to check that you have the correct size and if not or if it is old, go to your local home depot($1.89+tax for Hoover Model belts) or any other store you know provides vaccuum belts, and purchase a replacement belt.
Hope this helps and please don't forget to rate
-Chris
May 02, 2009 | Vacuums
Bissell 8930M Upright Steam Cleaner Logo
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
