Question about Cobra Radio Communications
Radio can recieve but does not transmit - Cobra Radio Communications
  • 3 Answers
Did you try a new mic?
Posted on Sep 08, 2009
No transmit or recieve
sounds like a repair for a tech to me.
Jan 16, 2014 | Galaxy Radios SSB Echo Base Station CB...
Flashing red light on radio where it thinks its recieving. Transmits fine but does not recieve.
Three things come to mind:
1) The radio is receiving, hence the light, but you may have a different PL code than the other radio and it is muting the transmission. Check your programming to be certain both radios are programmed alike. The red light indicates activity on your frequency.
2) Your radio may have a problem with the receive side of the radio or a bad speaker.
3) The transmitting radio may have a problem with transmit. This can be a sign of a bad battery. Swap batteries and see if the problem moves to the other radio. If so, replace the battery. (It takes more energy to transmit than to receive, so loss of transmit is common with a bad battery.)
Best regards.
Apr 15, 2013 | Motorola CP200 Two Way Radio
I have a new cobra 148 with ssb, about 6 months old, while i was away there was a storm, now the radio doesnt work , recieve or transmit, i also have a cobra 29 ltd that wont transmit but it will recieve....
make sure the mic is good. If for some reason the mic went bad, it will not receive or transmit.
As for the one with no receive, it most likely needs a new final.
If lightning hit your antron, it would be in pieces.
Aug 02, 2010 | Cobra 148 GTL 120-Channels Base CB Radio
CB radio recieves but does not transmit.
I would recommend that you put an swr meter (CLICK HERE) between the radio and the antenna to see if your radio is transmitting anything at all. Also, it will check to see if your radio is correctly matched to your antenna. If your antenna is not matched correctly it will fail to transmit correctly.
Nov 09, 2009 | Radio Communications
No audio transmit or recieve adio chip 1A7217AP IC
it may not be that IC but maybe a electritic cap or a transister.
Jul 30, 2009 | Cobra 18 WX ST 40-Channels Base CB Radio
Have a new cobra 148 gtl took out of box no transmit or recieve
make sure that your [swr] hadn't changed or went higher than a 1.5, anything higher will interfere with your tranmitting an recieving. other than that with out being there to see an hear your radio this would be the first place to start.
Apr 25, 2009 | Cobra 148 GTL 120-Channels Base CB Radio
TK 380 not transmiting
Its most likely was programmed with a rx but no tx. Meaning it can recieve but not transmit, you can fix this with the programing software.
Jan 25, 2009 | Kenwood KNB-17AM, TK-280, TK-290, TK-380,...
Neither Radio Transmits or Recieves
Have you checked that both radios are in the same Channel and the same Squelch Code? are the batteries ok? any rust in the battery contacts? Some FRS radios gets a Malfuntion, and the syntom is like that, check this first
Nov 26, 2006 | BellSouth 2231TE (22 Channels) 2-Way Radio
Radio Communications Logo
116 people viewed this question
Top Cobra Radio Communications Experts
AnyMHz.com
AnyMHz.com
Steve
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
