Question about Lexmark X4690 Wireless InkJet Printer
It is sayin carrier jam - Lexmark X4690 Wireless InkJet Printer
Clear carrier jam
>> Remove the print cartridges.
>> Gently move the carriage from Right to Lift, Left to Right twice.
>> Re-insert the print cartridges
>> Try printing.
It may help.
Dec 28, 2013 | Lexmark International Lexmark 5300 Series
Sx218,keeps sayin paper jam when there isnt any paper jammed
It sounds like a sensor is stuck. Sometimes a very tiny piece of paper is stuck near the sensr. I use a flash light to check. Have you tried turning off and on? Sometimes that will clear the error message.
Sep 06, 2011 | Office Equipment & Supplies
My printer keeping sayin clear carrier jam what does that mean
hi
i need to know to the model of your printer
here is a link with that same message, just to give you an idea
Lexmark, http://images.lexmark.com/publications/pdfs/2007/3500/mhs/en/d0e10275.html
Nov 12, 2010 | Office Equipment & Supplies
When i press copy the carriage shoots across and
The slamming of the carrier past the forward stop cause a reported carrier jam.
You should have the printer serviced by an authorized Lexmark Servicer.
Don
Nov 19, 2009 | Lexmark P4350 All-In-One InkJet Printer
EPSON R 300 SAYIN PAPER JAM WHEN NO PAPER JAMMED
Make sure that the paper path is completely clear and clean the paper sensors with a q tip. They get very dusty!
Aug 29, 2009 | Epson Stylus Photo R300 InkJet Printer
Hi my name is john i have a hp laserjet h470 keep sayin a paper jam
If there is NO PAPER JAM then that message really means that your printers PC board has packed up. TOO expensive to fix. NEW one is the answer
Jul 06, 2009 | HP Officejet H470 InkJet Printer
Carrier jam
From what you are saying you are getting 'clear carrier jam' because of a misalignment. The jam error message is a generic message that applies to a multitude of things. The carrier while is in right, might not be sitting right. A piece of plastic that holds the carrier might be broken or the printhead might be messed up. Anything that causes it to not sit the way it wants will cause that error message.
Feb 10, 2009 | Lexmark X4270 All-In-One InkJet Printer
Dell 942 carrier jam
This morning I replaced the cartridges in the Dell 942 printer, they jammed to the left which made a loud grinding noise and the cartridge jam error came on.
I solved the problem by turning the printer on with the top up which moved the cartridges to the right a little so I could reach back, push one down a little manually which freed them to move over to the middle.
Feb 28, 2008 | Dell 942 All-In-One InkJet Printer
'carrier path blocked'
Open up the compartment to the check for anything blocking the cartridge carrier from moving
check for correct placement of the cartridge
close the compartment
Nov 22, 2007 | Lexmark Z645 InkJet Photo Printer
Lexmark X4690 Wireless InkJet Printer Logo
140 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
