Question about Brother MFC 240C All-In-One InkJet Printer
Installed black ink and the window displays no cartridge installed. Why?
    Problem Solver:
  • 7 Answers
There is problem is in ur printer carriage(the place where the cartridge putted)
Posted on Sep 08, 2009
Can I print on my hp 6122 deskjet with only a black ink cartridge? I have no color ink.
Yes, all HP Deskjet printer models feature a 'single cartridge print mode'. Just remove the cartridge you don't wish to print with; the printer will automatically revert into either greyscale printing (if color cartridge remains installed) or black only printing (if the black cartridge remains installed). However, if the installed ink cartridge is electrically damaged/defective the printer will display an alert message; it will need to be replaced with a new cartridge.
For more information on the use of refilled ink cartridges or advanced HP printer problem diagnosis please visit Inkjet411:
http://www.inkjet411.com
Sep 03, 2013 | HP Office Equipment & Supplies
Near empty black is displayed even with new black cartridge
If you replaced an ink cartridge while Near Empty was displayed on the LCD, the LCD may ask you to verify that it was
a brand new one. Example: Did You Change Blck? 1.Yes 2.No. For each new cartridge you installed, press 1 on the dial
pad to automatically reset the ink dot counter for that color. If the ink cartridge you installed is not a brand new one, please be sure to select 2.
WARNING
If ink gets in your eyes, irrigate them with water immediately and call a doctor if you are concerned.
If you wait until Ink Empty message is displayed on the LCD, the machine will automatically reset the ink dot counter.
If the Install message is on the display after you have installed ink cartridges, check that the ink cartridges are
installed properly.
Jan 01, 2011 | Brother IntelliFAX-2440c Plain Paper...
I don't know how to change the ink bought this printer from a guy at work no manual
Lift the scanner cover from the right-hand side of the MFC until
it locks securely into the open position.
If one or more ink cartridges are empty, for example Black, the
LCD shows Ink Empty Black and Cover is Open.
Pull the ink cartridge hook toward you and remove the ink
cartridge for the color shown on the LCD.
Open the new ink cartridge bag for the color shown on the LCD,
and then take out the ink cartridge.
Remove the cartridge covers.
Each color has its own correct position. Keep the ink cartridge
in an upright position when you insert it into slot. Press down on
the ink cartridge until the hook snaps over it.
Lift the scanner cover to release the lock. Gently push the
scanner cover support down and close the scanner cover.
sure to select 2.
the MFC will automatically reset the ink dot counter.
installed properly.
Hope that helps you!
Aug 12, 2009 | Brother MFC 420CN All-In-One InkJet...
HAving trouble printing
Check and make sure you did buy the right one first.
Apr 23, 2009 | Canon PIXMA MX310 All-In-One Printer
The printer doesn't recognize the new original HP color cartridge
There is a small spring that holds the ink cartridge in the ink holder. You will see it stick out from the right hand side of the ink holder where the ink cartridge slides in. If that spring isn't being held to the ink holder by two plastic tabs, (I.E. the plastic tabs are broken) the printer will never recognize the cartridge. If the printer is still under warranty I would contact HP or an authorized repair center for HP. Both the black and color ink holder has this spring. I know of no way to repair this kind of breakage.
Jan 08, 2009 | HP OfficeJet 7310 All-In-One InkJet...
Display shows: printer cartridge incorrect
It seems like you are using incorrect printer cartridges.....
Make sure that part number on ink cartridges should be :
MK990 Cartridge, Ink, Standard, Series-9, Black CTRG,INK,STD,SERIES-9,BLK 0 1 0 Yes 1 N MK991 Cartridge, Ink, Standard, Series-9, Color CTRG,INK,STD,SERIES-9,CLR 0 1 0 Yes 1 N MK992 Cartridge, Ink, High-Yield, Series-9, Black CTRG,INK,HIYLD,SERIES-9,BLK 0 1 0 Yes 1 N MK993 Cartridge, Ink, High-Yield, Series-9, Color CTRG,INK,HIYLD,SERIES-9,CLR 0 1 0 Yes 1 N MK995 Cartridge, Ink, Series-9, Photo
Nov 10, 2008 | Dell 962 Photo All-In-One InkJet Printer
Print cartridges
  1. When one or more ink cartridges are empty, for example, Black, the LCD shows “Ink Empty Black” and “Open Cover.” Close the printer’s document support and the document tray.
  2. Lift the top cover to the open position until it locks securely into place.
  3. Pull the ink cartridge hook toward the front of the printer and remove the color ink cartridge displayed on the LCD. Place the cartridge in a plastic bag as it may still contain some residual ink and may leak.
  4. Open the new ink cartridge bag for the color shown on the LCD and remove the new ink cartridge. The cartridge cover may come off when you open the bag. This is not uncommon and will not damage the cartridge.
  5. Each color has its own correct position that is clearly labeled and color coded inside the printer. Keep the ink cartridge in an upright position when you insert it into slot. It will only fit in the correct direction. Press down on the ink cartridge until the hook snaps over it.
  6. If you replaced an ink cartridge while “Near Empty” was displayed on the LCD, the LCD may ask you to verify that the replacement cartridge was brand new one. Example: “Did You Change Black? 1.Yes 2.No.” For each new cartridge you installed, press 1 on the dial pad to automatically reset the ink dot counter for that color. If the ink cartridge you installed is not a brand-new one, select 2.
Sep 16, 2008 | Brother MFC-5840CN All-In-One InkJet...
Black ink full won't print on pages
Here is resource page and "No cartridge " error info:
http://welcome.solutions.brother.com/bsc/public/us/us/en/faq/faq_top.html?reg=us&c=us&lang=en&prod=dcp110c_us
Why does my machine's LCD show "NO CARTRIDGE" even though I have already installed all the ink cartridges?
Description:
If the message "NO CARTRIDGE" remains on the LCD after you have installed the ink cartridges, then one or more of the cartridges may not be properly installed. Verify that the cartridges are installed correctly by following these steps:
Note
    Cartridges that have already been installed are no longer vacuum-sealed, so it is very important that these cartridges remain upright. If a cartridge is removed from the machine and placed on its side, air may be introduced into the ink supply tubes. As a result, repeated cleaning will likely be required before normal print quality is restored.
  1. Unplug the machine from the AC power outlet, wait approximately 10 seconds and then plug it back in.
    If the date and time appear on the display, the issue is resolved. If the display continues to show NO CARTRIDGE, continues to Step 2.
  2. Open the scanner cover by lifting it from the right-hand side until it locks securely into the open position.
  3. Remove the black ink cartridge by pulling the white plastic hook (locked over the edge of the ink cartridge) toward you, then lifting the cartridge out.
  4. The LCD should prompt you to install the black ink cartridge.
  5. Reinstall the black cartridge. Press down FIRMLY on the top of the cartridge until it is fully seated. Push the white plastic hook towards the cartridge to verify it is fully latched over the cartridge's top edge. Repeat STEPS 2 - 4 to verify each that of the color cartridges (magenta, cyan and yellow) is installed properly, then continue to STEP.
  6. Close the scanner cover. The unit should begin cleaning automatically.
  7. Good luck, Joe
  8. Please remember to rate all Techs who assist you for free :)
Jul 31, 2008 | Brother DCP-110C All-In-One InkJet Printer
Say's empty
If you still need help:
Description:
Note
Please remember to rate all Techs who assist you for free :) Joe
Jun 01, 2008 | Brother DCP-110C All-In-One InkJet Printer
PRINTER WON'T ACCEPT NEW INK CARTRIDGE
From the Brother solutions website:
Note
Dec 09, 2007 | Brother MFC 210C All-In-One InkJet Printer
Brother MFC 240C All-In-One InkJet Printer Logo
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
