Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
Water wont drain and will not go into spin cycle
  • 612 Answers
You have a bad motor. Whirlpool direct drive machines, the motor runs in one direction to agitate and the other direction to spin and pump out. The pump runs all the time due to it being attached directly to the motor shaft, but only pumps when the motor is running in the direction that it runs when it spins.
Please rate solution
Posted on Sep 08, 2009
Washing machine wont drain,rinse,spin,water wont drain out start a cycle but seems not to rinse,spin,drain
Could be a failed lid switch. This is a safety switch that shuts the machine off during cycles.
May 19, 2016 | Washing Machines
Wont drain for spin cycle
in the previous statement i meant to say,if its plugged and cant drain then it wont advance to the spin cycle
Oct 16, 2010 | LG WM0642H Front Load
My machine wont drain the water or go to the spin
Drain Vlve command no activated. Or The valve is faulty. Check wiring also.
Mar 28, 2010 | Indesit W 123 Front Load Washer
Washing machine wont drain keeps bleeping ERR2
It will not spin with water in.
See if you can locate a filter, and clean same.
Jan 19, 2010 | Haier Washing Machines
Water wont drain and it wont go into the spin
if it is'nt making anny sound at all in spin its probly the lid switch
Dec 08, 2009 | Magic Chef Washing Machines
ALL FUNCTIONS OF WASH CYCLE WORK EXCEPT WATER WONT DRAIN AND SPIN CYCLE WONT WORK,
Pump is blocked or shot
Pressure switch made telling the machine it is full of water hence no spin.
Drop hose into bucket to drain the water off and the machine should spin, you may be better dragging the washer to an outside door and let all of the water run away at once .
Make sure that the drain hose is unclipped from the back of the machine so that the bottom of the hose is as low as you can get it
Jun 25, 2009 | Roper RAS8445KQ Top Load Washer
Washing machine wont drain or spin all other cycles work fine
you may have a timer problem just advanced your timer on click ahead when it happenes if it drains or spin replce your timer thanks from giles
Mar 14, 2009 | Washing Machines
Having issues with my washer Model # LSR7010PQ0. Will not perform final spin cycle. All the water is draining.. basket just wont spin. Tried the spin cycle on one of the other settings and that worked. ...
As the machine goes through the cycle, it should do what is called a neautral drain (drains water without the tub spinning) then a momentary power intreupt allows the gear to slip down and the spin begins. If this is not occouring on one cycle, it is usually a bad timer.
Jun 13, 2008 | Whirlpool Washing Machines
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
148 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
